Would it be possible to run an LD9 N/A on the GM SC flash?
Obviously the VE tables would need to be adjusted for the lack of boost.
I'm just wondering if it would be easier to tune the car with the speed density file over the alpha N file.
I'm also assuming the GM SC flash is speed density as it is map vs rpm for the VE tables.
Sorry for sounding kind of newbish, haven't played around with HPT much. Id like to get a feel for it before the turbo goes on.
I also have a copy of the 97 speed density file, would it be possible to flash to the car? I assume I would have to license the Vin for it.
I have a licensed copy of the GM flash on the HPT I'm using thats why I was wondering.
Yes, you can run a NA setup on the LD9 reflash.
If your car is a 99 i would run the 97 SD file, but that is just personal preference.
I know people have run stock GM reflashes on n/A LD9's before. Yes you can do it. one thing about tuning that way is you will loose resolution because of the lack of boost.
swap out the 2 bar map for a 1 bar and wouldn't you gain or at least maintain resolution?
backwards from the normal 'fake 2bar' tunes but if you want speed density for n/a thats a good way to go about it IMO.
DaFlyinSkwirl (Pj) v2.0 wrote:swap out the 2 bar map for a 1 bar and wouldn't you gain or at least maintain resolution?
Thats exactly what I was going to say. Run a 1 bar map and your 210 kpa column is now your 105kpa column and your 105 kpa column is now your 50 kpa column and so on.
Sponsored by:
Kronos Performance
