I'm in the process of pulling my harness while my motor is out so it is ready for the new harness (97+ ecu) but I can't unload the connection that is under the brake master cylinder. I pulled and pulled and it just wont budge. This is the connection I'm talking about. Any ideas?
"sometimes the respect is more important..."
7mm bolt on the dash side of the harness, it is in the center of the plug and
I just took that off last week. If you look closely (its pretty hard to get a good look at it) the metal bracket it mounts to has a slit in it, just pull really really hard in that direction and it will slide out. Theres no bolts or clips that need to be removed, just pull hard. Once its off the mount you will be able to unscrew the 7mm bolt on the back to seperate the harness.
bradsk88 wrote:Just be a man
Haha I knew I forgot something!!! Yea I never saw a bolt but I'm sure that's what it is cause I got it out of the bracket. Thanks!!!
Once you get the bolt loose it might take a little jiggliing and prying. Mine was kind of a pain. Figure it's been stuck together for 10+ years.
theres also a bracket holding it from the backside. its a pain, literally took me an hour to undo my first time.
Underdog Racing
