Ok... Seeing how the old Sticky that Ron (Shifted) made is kind of outdated with mismatched information, I am taking it upon myself to make a new guide. This guide will consist of factual information that Ron (Shifted) previously posted, along with new and updated information that myself and other experienced tuners on here can contribute. I plan on making some of it "how to" with some pictures for reference, and other information on how and why certain tables work. I do not plan to get "too technical" with all of it, but I plan on wording it so that any "novice" tuner can understand. This is going to take me a little bit to complete as I am really busy lately, but I think its time that something is done. As stated before, this will all be fact bases information that has been tested in the field by professionals. After this Sticky is made, I really think that Shifted's old thread should be unsticked so the new correct information is right at the top and is not confused with the old outdated information.
Here is what I ask of you. If you have information you would like to contribute, please PM me letting me know what that information is. If I feel is something worth while, I will have you email me the info. I will then read through it and make sure its facutal information that will be useful to others. If your information is used, I will make sure you are mentioned.
Thoughts and comments are welcomed. Please keep this drama free (I know its the org, but seriously)....
Do I have any takers?
P&P Tuning
420.5whp / 359.8wtq
You got my vote.
Save your money. It might be worth something someday.
Ryan as we talked about I thihk this is a good idea and will help in any way I can.
Do it.
If the '95 pcm's have been fully figured out, Updated info on that would be awesome too if you have it.
I think this would be great. I'm getting ready to tune my car and have basic ideas down but the more information I can read and get the better! I'm sure there are many others too intimidated to try and maybe this could help.
Great Idea
I think this is an awsome idea...I got an eco I need to tune shortly and the current sticky is hard to read and seems very outdated..
+1 for me!!
Ryan I have much respect for you . You have my vote man. I have a lot to contribute regarding tuning of the 4t40e . I will email you. Thanks.
suggestions:
open/closed loop
proper VE setup
commanded AFR values and actual
wideband setup without HPTpro (EGR, A/C pressure inputs) and how to log
1 bar vs. 2 bar vs. etc...
explaining what tables alter what
links to HPT's site/forums/faqs for more in depth explanations
beginner proofing is key
Sweet I don't know diddly about tuning but I like this.
This would be awsome! Im going to need some tuning info for HPT in the near future
"Straight roads are for fast cars, turns are for fast drivers"-Colin McRae
i think this is a great idea, im glad someone with proper knowledge is stepping forward to update. j's as a community need more information distributed with fact to help us grow and properly do things. good stuff
Yes! this would bevery helpful. Especially and updated writeup of VE tuning and the histograms.
suggestions:
open/closed loop-agree
proper VE setup-not sure what is meant by this
wideband setup without HPTpro-disagree, needs to be simple (EGR, A/C pressure inputs) and how to log
I think this needs to be a basic how to, not major indepth. More or less what the orginal is without having to read through all the old stuff to get it.
Ryan - I sent you this PM a while back - can you consider some of these thoughts and/or corrections to the OP sticky from Ron.
How about this as a follow up post - let me know what you think.
ADDING ONE COMMENT OR CORRECTION TO THIS STICKY
If we are turbocharged or supercharged, we are increasing the VE, thus we must increase the VE tables so the ECM can add fuel to match the increased mass flow.
THE OP:***WARNING***
THIS IS WHERE YOU CAN BLOW UP YOUR CAR. If you are running untuned and without added fuel, especially in boosted applications, you can go lean and blow up your motor. If you fear this, you need to richen up your car before you start. Simply reduce (CORRECT to "Increase") the VE percentage in each of the cells until you are running pig rich. Then go ahead with tuning.
New Post
I'm adding VE % starting with at least the pressure ratio increase or more safely the caculated density ratio increase over stock tables as an approximation in Low RPM Single, Double Fire, and High RPM tables.
If I'm running 5psi boost, that's about 1.34 pressure ratio (so multiply 1.34 by current VE as a start) or if intercooled add an additional 15~20% (1.34 * 1.20 = 1.61). Approximate density change being 1.61 is the number by which I multiply my stock histograms in High RPM, Low RPM single and double fire.
Caveat:
Keep idle the same, and if possible drive ahead of time in closed loop so you know your TPS and RPM of boost onset and use stock VE values at the low throttle and low rpm positions so its not too rich off boost.
Other Caveats: temp well below 50F may cause you to be a little more lean, all this assumes you followed the OP instructions with exception of the correction above mentioned.
That's a great idea Ryan. It's been needed for a while now.
this should compliment dave's new FAQ/HOW TO system he's been talking about.. (this system will replace all stickys)
i support this idea =)
Shifted isnt bad for VE tuning but it does leave out the part about disabling DCFO
ALso theres nothing in relation to things like spark advance which is huge
Rodimus Prime wrote:Shifted isnt bad for VE tuning but it does leave out the part about disabling DCFO
Agreed for the most part. The VE Tuning FAQ is kind of misleading though... Too much confusion about Paste Special Add or Multiply... As for the timing, not sure what I will incorporate there. I think maybe writing something about the effects of timing should be mentioned, but as you know, timing can make or break an engine. Most timing adjustments should be done on a dyno for proven results, although an experienced tuner could make good results on the street too.
If you have an idea or any more input, Matt, let me know!
P&P Tuning
420.5whp / 359.8wtq
I am so infavor of this the only thing stopping me from putting a turbo on my car is lack of knowledge on tuneing it via hptuners. plz help the stupid like me
This would be awesome....and eventually I could drive down by you to get a proper tune!
