I would GREATLY appreciate if someone could log there car starting using HPTuners. Specifically a 2.4 LD9. I want to compare my log to someones that will start. Does someone want to look at my HPTuner file of my "stock" flash. Stock.....well that is what it "should" be. To see if something somehow is messed up....
Any help would be wonderful.
I can GLADLY email my files to whom ever wants to see them.
there's a few stock tunes in the repository if you wanted to compare some of the parameters. i'm reading that you think something is messed up and causing your car not to start. did you reflash it recently? maybe there was a connection loss part way through or something. i don't have a 2.4 so can't scan.
To make a VERY long story short. I got a new PCM, and my car will not start. I'm borrowing HPTuners from a buddy. I do not have access to the repository.....
email me your file. JMHZ2497@comcast.net I will see if I can get a log of my car tomorrow starting.
-MD- Enforcer wrote:To make a VERY long story short. I got a new PCM, and my car will not start. I'm borrowing HPTuners from a buddy. I do not have access to the repository.....
Sounds like a VATS/Passkey relearn issue...
P&P Tuning
420.5whp / 359.8wtq
Not a Expert per Bill Hahn Jr. wrote:email me your file. JMHZ2497@comcast.net I will see if I can get a log of my car tomorrow starting.
Will do tonight
i agree i think it is the vats.
I have tried the relean many times. My theft light never flashes at all....
I have a log of my car starting for you. Will send it when I get your file. So is the car turning over and never cranking? If so that is not theft lock. Have you flash the new ECU to your file?
The car cranks for days, but never fires.....
You have email....
Ohh i hope we get good news on the car getting started!!
Nothing yet....
I got your email and sent you a log of my car as well.
As I put in my email to you. Do you know if the injectors are firing? Pull the rail out of the head and see if they are firing. I do not think they are. You are not getting theft lock, or the car would crank and then shut off.
Looked at your tune and VATS is disabled. My question is have you tried with VATS enabled?
We had a very similar problem after a Ecotec swap into a 2001 car. When I switched the ignition switch from the donor car into the 01 it fired and then went into theft lock. Did a relearn and all was good.
I'm wondering if the new ECU is not being seen buy the other components.
I have tried vats enabled under the etc codes what should they be stock.... I'm wondering if they are keeping the vats from starting.
I'll try the injectors tomorrow probably. I'll look at the files when I get home. Thanks for the help.
Posted from iPhone.....
Vats should be enabled stock. I would enable VATS then do a relearn and see what happens. If that does nothing then see if injectors are firing (which I'm sure they are not).
damn still havent got this figured out
JGM T-SHIRTS!!!!
I'll be testing Tuesday after work. We have FEET of snow......
Jeffie, nope not yet.
I'll turn on all the Vats, and reflash.
Been working. I'll be at the cav this weekend!
so the injectors are NOT firing.....John any idea.
VATS is still not working either.
-MD- Enforcer wrote:so the injectors are NOT firing.....John any idea.
I know you have done alot trying to get the car to run. What things have your replace? Ignition switch maybe? I know you got another ECU. Have you stripped the car for any reason?
Items replaced below so far.....
Fuel side
Racetronix Fuel pump & harness
Fuel filter
Steel Gas Tank
FPR
Fuel Rail
Stock Injectors
Spark Side
ICM
Plugs
Boots
Contact springs from coils to IDI housing
New Black IDI housing
Both coils
Electrical
MAP sensor and map vacuum hose
Ignition Switch
Crank Sensor
ECU
Throttle Position Sensor
IAT Sensor
Driver door Switch on order
What I have checked....
Compression, 198-204-162-201...compression has been like this for about two-three years now. Only smokes if I beat on it.
Rings on three have been bad for a LONG time....known issue
Timing....dead balls on, chain tight
Gas was drained and replaced...
I'm sure I forgot something...I'll add when I remember.
All fuses and relays have been check under hood and inside with an ohm meter AND a test light.
I did test the car with the drivers door switch bypassed. Car has never been stripped.
When ever the car does run it should run great.
Edited 4 time(s). Last edited Monday, January 11, 2010 9:40 AM
Do you have the prginal ignition switch?
Hmm injectors not firing, are the clips fully plugged in to them(im sure you checked)
Is the fuel pump hooked up correctly as far as the relay kit? Maybe the fuel isnt getting to the rail because of the pump. i HIGHLY doubt your metal tank with the Racetronix has anything to do with it.
Man, just throwing out ideas.....
I assume the fuel pump is kicking on. I have had this problem happen when doing Ecotec swaps. Car turns over, but not injectors firing. It has been the ignition switch. It is not being seen by ECU.
Too Whiney wrote:Do you have the orginal ignition switch?
yes, it is back in again right now, and the new one is sitting on my passenger seat. I have tried the old one and new one many times.
WHITECAVY wrote:Hmm injectors not firing, are the clips fully plugged in to them(im sure you checked)
Yes, they are pushed in, but I'll check again. If I take the return line off the rail it will SHOOT gas out of the opening. I had a bad o-ring where the FPR meets the Return fuel line and sprayed gas all over the alternator. Fun times.
Too Whiney wrote:I assume the fuel pump is kicking on. I have had this problem happen when doing Ecotec swaps. Car turns over, but not injectors firing. It has been the ignition switch. It is not being seen by ECU.
The fuel pump is kicking on. I can also get it to kick on if I tell it to turn on inside HPTuners.
Side note wrote:
PASSlock
Also referred to as the Vehicle Theft Deterrent (VTD) system, PASSlock is designed to prevent vehicle theft by disabling the fuel injectors unless the lock cylinder is engaged by the correct mechanical key. The theft deterrent system uses four components for theft prevention:
- the lock cylinder
- the ignition switch
- the instrument cluster (IPC, 96-99 models) or body control module (BCM, 00-05 models)
- the powertrain control module (PCM)
When starting the engine, the PCM waits for the fuel password from the IPC/BCM. If the password is not recognized or not present, the PCM disables the fuel injectors. The vehicle will either start and then quickly stall, or fail to start entirely. If one of the four components listed above is replaced, then the PASSlock system must be reprogrammed.
There are several versions of PASSlock; J-cars use PASSlock-1 which uses three wires compared to PASSlock-2 which uses 2.
Could my cluster be the whole problem? It is working, but sometimes my odometer and trip flicker till I smack the dash......
Edited 1 time(s). Last edited Monday, January 11, 2010 12:51 PM
