I have been told that all you need to do is put 0 any trans tables and disable any trans DTC's
Wade Jarvis wrote:I have been told that all you need to do is put 0 any trans tables and disable any trans DTC's
I have never used the GM reflash, but I have used a auto file on a manual car. Never messed with the auto tables, just disabled the DTC's for the auto tranny. Don't you have a manual reflash already?
I've compared the two before, and nearly all of the tables between the manual and auto have different values. I think I talked to Shifted about it before, and the values are different because it is tuned for the auto shift points. I have no idea, however, if it would work or not.
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
John Higgins wrote:Wade Jarvis wrote:I have been told that all you need to do is put 0 any trans tables and disable any trans DTC's
I did originally have a manual GM reflash. I bought and put in some used 440cc injectors. The guy I got the injectors from also gave me a copy of his tune. So being the HP Tuners noob that I am I figured well I will just flash the guy I bought the injectors froms tune. That way I would have the corrrect injector constant and I will tweak the tune more as I learn more. However the tune came from an automatic.
I am having some issues with the car idleing and was wondering if I should go back to the manual tune and just change the injector constant. Not sure if that would have any effect on things or what.
Edited 1 time(s). Last edited Friday, October 23, 2009 11:58 AM
I am not sure how to attach a copy of my tune.
What problems with idle are you having?
I have a couple manual files.
Also when I first went supercharger I had some issues with misfires etc... Well I used a HPT copy of the GM reflash for my car. After getting the GM reflash from GM my issues were gone. Not sure if this is the samething you are having.
Wade is this the same copy you were using with the M45?
Edited 1 time(s). Last edited Friday, October 23, 2009 12:21 PM
I've got a copy of the manual GM S/C reflash if anyone wants to take a look. I've about had it with HPTuners. I've had nothing but problems getting tunes to work right on my '99. It's just hit and miss it seems like. My winter project is to rip out all the wiring and rewire the car to run Megasquirt.
1997 GMC Sierra
2005 Honda TRX450R
John Higgins wrote:What problems with idle are you having?
I used this same tune for a few weeks right before the bash and did not have any idle problems. Once the car is fully warmed up it seems to almost stall out. It does not do it while it is still warming up though. The rpm's drop down to about 500 then it pulls back up to1200 then falls back down to 500 and just does it over and over until it finally dies. The afr hold pretty steady around 13.5 when it is doing this so I am really lost. This is going on in open loop. Nearly the same thinmg happens in closed loop except it goes way lean to where it blanks out the gauge and dies.
Edited 1 time(s). Last edited Friday, October 23, 2009 12:56 PM
It would be nice to have a manual GM reflash anyway. If somone could email it to me the email addy is z24stud@gmail
I'll try and pull it off of my laptop tonight after work. Otherwise you can download it from the HPTuners File Repository.
1997 GMC Sierra
2005 Honda TRX450R
Wade your problem sounds like IAC related. Maybe a faulty IAC, or because of the extension/adapter.
Update:
I replaced the IAC with a brand new unit just to rule it out. It made no effect on the problem. So I am focused on the tune. I went to the HPT tune repository and found a 2002 2.4 jbody manual trans completly stock copy of the GM supercharger reflash that was added by Ron (shifted). I downloaded it and only changed the injector constant for the 440cc injectors I am using. I flashed that and now my idle problem is gone.
On a side note surprisingly the AFR did not go leaner than low 12's under WOT however the car did not seem to pull as hard. I would guess that is because of the conservative timing the GM reflash has.
Bingo! That and the VE tables are not massaged to where they need to be with this size blower..... On a side note, sorry I did not call you back earlier... Its been one hell of a day...
P&P Tuning
420.5whp / 359.8wtq
wade i am looking at you're shifted tune now...
seems pretty advanced to me. comparing it my shifted tune anyway...
I must confess... I feel like a monster!
z yaaaa wrote:wade i am looking at you're shifted tune now...
Are you running meth Brad? I know Wade is, so that may explain that...
P&P Tuning
420.5whp / 359.8wtq
nope. i dont have any boost. my tune is n/a.
and wade has never ran meth. and i am almost 100% certain ron did not factor meth in...
*side note, wade i have you're tune on my computer now so i will get it sent over.
