Twin Cam HO Manifold Tuning help - Tuning Forum
Monday, July 13, 2009 8:31 PM
Went ahead and decided to install the HO mani to help with the HO Cams
Wondering a couple things
I also installed the 310CC injectors i had to help out also
Wondering about adjusting the AFR for Idle? Car is running in Open Loop right now cause im going to do some VE Tuning with it but its running really rich
Can't log Inj Duty cycle, still cant get it to tune for some reason
Also wondering what would trigger the Cooling fan to run all the time? Runs as normal with the 2.4 Mani on but when i put the 2.3 Manifold on my fan always runs?
Thanks
Re: Twin Cam HO Manifold Tuning help
Monday, July 13, 2009 11:19 PM
CEL's will set the fan to run all the time. i had issues with this till i disabled them.
Tuesday, July 14, 2009 7:26 AM
No CELs at all
Insight on tuning the Idle?
Tuesday, July 14, 2009 12:15 PM
you have no CEL's and ur fan runs all the time?
and all i did was raise the idle up a bit. if you wanna check out my current tune i can send it to ya, i messed with a few things but disregard pretty much everything lol.
Tuesday, July 14, 2009 2:35 PM
Have you hecked to make sure there is not a code in history that has yet to trip the CEL? This can happen.
Tuesday, July 14, 2009 5:48 PM
Will check that
Can anyone comment on adjusting the fuel for Idle?
Tuesday, July 14, 2009 9:16 PM
Tuesday, July 14, 2009 9:31 PM
Nice spoon
Don't you have a 3400 to swap into something?
Tuesday, July 14, 2009 9:46 PM
gtpsunfire wrote:
if i wasnt so busy id bend the @!#$ out of that with my mind
Wednesday, July 15, 2009 8:24 AM
D-Mac wrote:Went ahead and decided to install the HO mani to help with the HO Cams
Thanks
I had a random issue like that with my eco, fan ran by its after 1st blower install. Just ran hpt datalogger and turned fan off and never had the issue again. Fan came on at right time everytime after that.
D-Mac wrote:Will check that
what afr is your wideband feeding you @ idle?
Wednesday, July 15, 2009 2:46 PM
I usually do not mess with idle AFR too much. The ECU controlls this when car is in closed loop If you need to adjust it use a histogram.
Wednesday, July 15, 2009 6:35 PM
John Higgins wrote:I usually do not mess with idle AFR too much. The ECU controlls this when car is in closed loop If you need to adjust it use a histogram.
yep, x2 but an afr read out never hurts during any part of a tuning process, or when searching for a problem.
Wednesday, July 15, 2009 7:30 PM
AFR is about 10.5-11 at idle in Open Loop
Anyone have a Histrogram for Idle? Or do we already have one from HPT?
Wednesday, July 15, 2009 8:05 PM
are you running your car in strictly open loop or when you are tuning?
If it is while you are tuning that isn't out or order.
Wednesday, July 15, 2009 9:12 PM
Just for tuning
Doing Shifted's VE Tune
Wednesday, July 15, 2009 10:22 PM
holy crap i didnt know the fan constantly runs due to CEL's...
thats good to know... explains why my dad's 00z's fan has been constantly running for 6 years LOL
PFFT secret cams?! pm me if you want a real upgrade.
Thursday, July 16, 2009 10:51 AM
z yaaaa wrote:holy crap i didnt know the fan constantly runs due to CEL's...
lol
Friday, July 17, 2009 7:24 AM
D-Mac wrote:Just for tuning
To be honest I wouldn't worry about Idle AFR in open loop. Your running open loop for a reason. If you want though, what you can do is copy your 0% throttle table over to your idle tables or copy your Coastdown tables into your your idle table.
Friday, July 17, 2009 1:07 PM
I can send you a histogram for idle if you want, but I would not worry about it too much if you are going to put it back to closed loop after tuning.
