Need some help - Tuning Forum
Need some help
Friday, April 03, 2009 9:25 PM
Does anyone have a file for HP tuners from a set up with HO cams I could have a copy of? I want somthing to start my tune off of. Thanks!
Re: Need some help
Saturday, April 04, 2009 6:23 AM
I could print screen my Ho and W41 bins if you want.
Witch tables exactly do you want?
Gilles
2.3 Ho
Re: Need some help
Saturday, April 04, 2009 9:38 PM
That would be great. Im looking for the fuel maps so i dont accidentally blow my motor from running too lean on the initial run before fine tuning.
Re: Need some help
Sunday, April 05, 2009 3:00 PM
You can run the ho cams on the stock fuel maps. It only begins to lean out above 4000.
Re: Need some help
Sunday, April 05, 2009 4:00 PM
So do I just adjust the numbers up above 4000 for the initial tuning?
Re: Need some help
Sunday, April 05, 2009 4:21 PM
Everything under 4k is good and safe to tune. Add about 10 points to everything else and begin tuning. Watch your AFR to make sure you aren't going lean. Its better to start rich. The car ran like stock on the stock tune and when i did my initial run i noticed it started to lean out above 4k. So i just added some points and everything was good. I am now waiting for a little warmer weather to finish the tuning.
Re: Need some help
Sunday, April 05, 2009 4:35 PM
OK thanks, thats what I needed to hear.
