I am going to start using my HP tuners with my 04 Cavalier Ecotec. Well I tried to use a custom config (cfg) file for the scanner I use with my other car however none of the histograms worked. I even tried using the defalt one HP tuners comes with however still none of the histograms worked. I was wondering if someone could send me there config file for the HP scanner? Thanks!
2000 Buick Regal GSE - "Gods Grocery Getter is powered by an L67 3800" -
333WHP
12.900 @ 109.91mph 2.166 60Ft (Fastest 1/4)
13.374 @ 110.01mph 2.467 60Ft (Fastest Trap)
2004 Chevy Cavalier - 15.7 @ 90mph (Semi-Modded)
The config files are easy enough to set up.
The reason it wasn't working was because HPT wasn't told to scan those parameters.
The histograms will only work as long as you are monitoring the x and y axes on your black and white you graph.
Admiral Jedi wrote:The config files are easy enough to set up.
Oh yes you are totally right I completely forgot to re-configure the graph for my Cavalier. Thanks
333WHP
