going HPT after reflash? - Tuning Forum
Monday, January 19, 2009 5:43 PM
ok, so i had the reflash on my car as a band-aid(if you can call it that) so it would make it to the bash, and now with all the power i should be making its more like a ball and chain.
my question is this, since the 2bar map sensor is in there would it be more difficult to use that with hpt or would it be wise to pull it and rewire the factory map and iat in?
thanks
Built&Boosted moar
Re: going HPT after reflash?
Monday, January 19, 2009 6:23 PM
What kind of boost are you planning to run?
I have found that if you are running more than 12-15 psi use a 2 bar sensor for better timing tuning in the higher boost range. If running up to 12psi (maybe 15) use a 1 bar map.
Monday, January 19, 2009 6:25 PM
Your running an eco? Go hpt + fmu...... you can't use a 2 bar map sensor with hpt and the eco. and the fake 2bar isn't worth your time.
Monday, January 19, 2009 6:50 PM
K. Vega..Mr. M62 L61 himself. wrote:Your running an eco? Go hpt + fmu...... you can't use a 2 bar map sensor with hpt and the eco. and the fake 2bar isn't worth your time.
Sure about that.
Monday, January 19, 2009 8:22 PM
x 2
You'll need the stock MAP sensor back in.
Hahn Stage II - Mitsu TD06-20g |3" Turbo-back Exhaust | 61mm Bored TB |
HP Tuners | Innovate WB02 | Spec Stage 3 | Team Green LSD | TurboTech Upper | Full Addco Sways | Sportlines & Yellows |
Monday, January 19, 2009 8:28 PM
wow I read this whole post wrong, I thought you were speaking in reference of TUNING a 2 bar tune using the 2 bar map sensor, my fault. I'm pretty sure you can run the same map sensor.
Tuesday, January 20, 2009 5:17 PM
John Higgins wrote:What kind of boost are you planning to run?
i will be running 15-25psi..
Built&Boosted moar
Wednesday, January 21, 2009 4:15 AM
Spectra EMS...
Or MS...
Thats what i would do.
Wednesday, January 21, 2009 5:21 AM
jmarks82 wrote:Spectra EMS...
Or MS...
not exactly what i wanna do, im not a fan of owning a standalone car
Built&Boosted moar
Wednesday, January 21, 2009 5:26 AM
what turbo are you running? also external w/g or internal?
Wednesday, January 21, 2009 7:11 AM
K. Vega..Mr. M62 L61 himself. wrote:what turbo are you running? also external w/g or internal?
garrett 60trim with 38mm wg
Built&Boosted moar
Wednesday, January 21, 2009 1:09 PM
Hpt no if ands or buts. HPT + Fmu = Answer to no actual speed density tuning with a turbo charged ecotec.
Wednesday, January 21, 2009 1:25 PM
K. Vega..Mr. M62 L61 himself. wrote:Hpt no if ands or buts. HPT + Fmu = Answer to no actual speed density tuning with a turbo charged ecotec.
I tend to agree from everything I have done and seen. I don't think an FMU is necessary with low boost (If not needed why add reliability issues?).
The problem becomes when you have maxed out your VE offset and can no longer use HPT to add fuel without losing low-end tuning/driveability.
At that point you need an FMU to throw in the extra fuel for full boost.
Wednesday, January 21, 2009 2:03 PM
K. Vega..Mr. M62 L61 himself. wrote:wow I read this whole post wrong, I thought you were speaking in reference of TUNING a 2 bar tune using the 2 bar map sensor, my fault. I'm pretty sure you can run the same map sensor.
I'm kind of confused about your comments. You can use a 2 bar sensor with hpt and it will work correctly when you fake the 2 bar tune..and it is worth your time. I've done it and had it working great for about 80,000 miles with no issues. Actually mine was with the 2.5 bar sensor, but either way, as long as the math is right it should be fine.
Wednesday, January 21, 2009 2:28 PM
well any input on a fmu?
Built&Boosted moar
Wednesday, January 21, 2009 11:10 PM
Tis True
yea you can use a 2 bar if you want but its not necessary. Your giving yourself extra work for no reason. If your tune is keen and your following the input your histograms are feeding you, a fake 2 bar isn't essential at all. The stock one bar will be just fine.
Matt Gorman(ECOjunkk) wrote:well any input on a fmu?
Cartech 2025
Saturday, January 24, 2009 8:18 AM
sell me your reflash.
Sunday, February 08, 2009 5:44 AM
FMU's are GHEY.
Go back to the OEM 1bar program w/ HPT to tweak it, then get the Hahn Port Fueler man. It works, and it'll work better then any hack job FMU.
FMU = 90's tuning when no software for boost was really available.
-Trailblazer SS - not so custom 6.0L - custom intake - custom tune
- (1) 2.4L on an engine stand (1) blown trans (2) good quad trans (1) eco trans = party
Sunday, February 08, 2009 2:20 PM
SpyhunteR wrote:FMU's are GHEY When used by themselves
fixed
Sunday, February 08, 2009 4:53 PM
SpyhunteR wrote:FMU's are GHEY.
$100 dollars vs. $1800 hmmmm
By that logic your entire car is ghey, so go buy a new Corvette because a Grand Am is definitely 90s technology.
BTW FMUs have been around since at least the 1940s when the Nazi's were using them with Bosch fuel injectors to dominate the skies over Europe.
And there was no "tuning software" until after the 90s? errrrr right......
Thursday, February 19, 2009 7:11 PM
and the nazi's lost.
Thursday, February 19, 2009 8:52 PM
hey vega, i got the plug for the stock 1 bar but i dont know what to wire it into lol, so you think i can just use the tmap instead? might be a bit easier for me so i dont have to mess with wires i am unfamiliar with..kinda wanna try and tune my car with hpt this weekend but its probably too cold..
12.33 @ 111.67 mph [Oct 2009]
327.6 WHP 333.6 WTQ [10.1 AFR]
Thursday, February 19, 2009 10:08 PM
my fault bout that bro, I'll give you a call fri. classes work and family issues got me caught up. But hey we'll get that one bar in there in.
Friday, February 20, 2009 9:03 AM
SpyhunteR wrote:and the nazi's lost.
Wow someone paid attention in History class!
Friday, February 20, 2009 9:36 AM
I'd agree with K. Vega on this one
