I have aftermarket headers and a cat back exhaust but I want to remove my cat and exhaust system and just run the down pipe does any one know where i can get a cheater sensor for the post-cat 02 so my CEL wont go on and throw my air/fuel into wack? I've seen some online but im unsure...help would be great...
Chris Rydzik wrote:I have aftermarket headers and a cat back exhaust but I want to remove my cat and exhaust system and just run the down pipe does any one know where i can get a cheater sensor for the post-cat 02 so my CEL wont go on and throw my air/fuel into wack? I've seen some online but im unsure...help would be great...
First the downstream O2 sensor you are speaking of will not affect your air/fuel mixture. Best 2 options is getting the code turned off with HPT, or doing a manual O2 sim. You caqn find more info on the manual O2 sim in the performance section if you search. You still need the second O2 sensor, and it spaces it out from the exhaust stream so it does not get the full reading.
"headers"
I love that.
Chris
'02 Z-24 Supercharged
If you don't have hpt you can find someone with hpt..
Using a cheater sensor really doesn't do you any good. If your going to go the route of using a sensor, save some bucks and plumb your line with a bung for your existing sensor.
