John Benham wrote:
dont forget, you are going to need to tune that...i dont know what hahn gives you for tuning...
SweetnessGT wrote:Agreed with John.
I'm running 1000cc low-impedance RCEngineering injectors.
-Chris-
John Benham wrote:Ricardo Rosario wrote:So you've been running 20psi on Stock injectors?
i think your crazy if this is true...
BOOSTED BABY wrote:I called hahn racecraft to see if i could get some bigger injectors because of the amount of boost i am running. They said they do not have any bigger ones. What are people using for 15 - 20 psi? Where do i get them from. And what is my injector independence. I have the hahn stage 2 kit and i just want bigger injectors. WIll someone help me out quick so i can get these things ordered.
John Higgins wrote:John Benham wrote:Ricardo Rosario wrote:So you've been running 20psi on Stock injectors?
A good friend of mine who had the very first Ecotec Turbo car (not built by GM) ran 17-20psi on stock motor and stock injectors. Ran a perfect AFR's. Pulled 113mph in the 1/4
yea and how long did that last? lol. I could only imagine his idc. I maxxed the 34lbers out on the dyno with only 8 psi from a blower.
unless he had an afpr and a massive intank and external fuel pump. lol
SweetnessGT wrote:Using the nitrous kit as an EIC basically?
Not a brutal idea but not the greatest way to fuel the engine! lol
-Chris-
K. Vega..Mr. M62 L61 himself. wrote:SweetnessGT wrote:Using the nitrous kit as an EIC basically?
-Chris-
x2
but atleast it makes sense now lol.
John Higgins wrote:Quote:
It ran for a long time that way. We pulled the motor out of the car to build it up (it was still runing and nothing wrong with it). It was a fMU set-up. We do not know what the IDC was. This was before HPT. It was a stock FPR, stock fuel pump. The trick was he was using a nitrous kit (just the nitrous side) to get his extra fuel (I know, I know). It worked, and ran like a beast.
I would not recommend this to anyone to do.
DaFlyinSkwir(LS61) /PJ/ OEM+ wrote:John Higgins wrote:Quote:
that wasn't josh's yellow 02 was it?
