How many rpm"s can my 2.4L block handle? - Tuning Forum
Wednesday, May 28, 2008 8:29 AM
Im just getting ready too tune my car for some dirt traack racing. I heard once you get over 7,000 rpm's the block starts flexing?
The only thing I rerally have on the bottom end is a good 2.3L oil pump. And this wont help if the block starts flexing? So my question is how many Rpm's can I run and be living on the edge????? Eagle Rods/weisco pistons, 2.3L oil pump
Re: How many rpm"s can my 2.4L block handle?
Wednesday, May 28, 2008 9:05 AM
Your valve train will explode before the block flexes
Wednesday, May 28, 2008 10:24 AM
I know for a fact that 7000rpm can be done for short periods on a completly stock internals 2.4. I have done it.
Wednesday, May 28, 2008 12:24 PM
Yeah, valvetrain is going to be your problem before the block is....take a gander in the performance forum, and there are lots of threads about mods being done to achieve higher reving safer, and what thier results were. What all "tuning" were you looking to do with this??
Wednesday, May 28, 2008 4:14 PM
it can handle a lot more then any cam's you will get for it will make power at.
Chris
'02 Z-24 Supercharged
Wednesday, May 28, 2008 7:03 PM
John Benham wrote:Yeah, valvetrain is going to be your problem before the block is....take a gander in the performance forum, and there are lots of threads about mods being done to achieve higher reving safer, and what thier results were. What all "tuning" were you looking to do with this??
pretty much just dump some more fuel into it, maybe rev it out 7,000 rpms try too get some more power out of it. im going from racing a 1/2 mile to a little 3/8 mile cant keep up with the dodges/ 2.2 ecotechs?? any suggestions might help/if anybody has a adjustable timing gear would be interested thanks
Wednesday, May 28, 2008 7:40 PM
LD2 cams will help the most.
get a melling oil pump, and run Mobil-1 15W50, with the 1992 LD2 cams, you should be able to make 160-170 wheel.
(with tuning.)
a HO\LO intake.
(OHHH NO"S i said to do THAT?!!!!)
Chris
Wednesday, May 28, 2008 8:50 PM
Taetsch Z-24 wrote:LD2 cams will help the most.
(with tuning.)
a HO\LO intake.
Chris
I have "secret cams" and a 2.3L oil pump?????????
Thursday, May 29, 2008 6:20 AM
95 cams?
Chris
Thursday, May 29, 2008 10:41 AM
intake= 95 "Secret Cams"
exhaust= 90 - 94
Thursday, May 29, 2008 5:14 PM
7K should be no problem.
Chris
Thursday, May 29, 2008 8:48 PM
thanks chris ill let yas know if she holds together!!
Friday, May 30, 2008 11:52 AM
you'll blow yaself ta pieces
Riddle me this... riddle me that...
Friday, May 30, 2008 7:14 PM
z yaaaa (the riddler) wrote:you'll blow yaself ta pieces
7k??
Friday, May 30, 2008 10:35 PM
i do 7k with secret cams, works just fine, need bigger cams tho
Friday, May 30, 2008 11:41 PM
gmanz24 wrote:i do 7k with secret cams, works just fine, need bigger cams tho
same here. I think zyaaaa was joking as he knows it can be done.
Saturday, May 31, 2008 12:30 AM
my LG0\W41 loves waving at 8100 RPM.....
LG0 FTW!
Chris
