Hahn Kit afr's - Tuning Forum
Hahn Kit afr's
Saturday, March 08, 2008 8:25 AM
What kind of air/fuel ratios are maintained with the Hahn kit using the afpr and the FMU?
The stock timing tables remain in place?
Is there any knock retard?
Re: Hahn Kit afr's
Saturday, March 08, 2008 11:26 AM
Depends on how the FMU is adjusted, just about anything you want on the stock 7-8psi wastegate actuator. I had no knock retard at 7-8psi (20g), I did run into some when I bumped low octane values closer to that of the high octane.
Mitsu TD06-20g |3" Downpipe w/ Cutout | 61mm Bored TB |
HP Tuners | Innovate WB02 | Spec Stage 3 | TurboTech Upper | Full Addco Sways | Sportlines & Yellows |
Re: Hahn Kit afr's
Saturday, March 08, 2008 5:25 PM
As for AFR and knock thats kinda something you set yourself, ideal AFR is about 11:8 you could go a tad leaner but its better to be safe than very sorry, too too lean you will see knock
