got my 96 to 97 ECU swap.....i have a few questions now - Tuning Forum
Tuesday, February 26, 2008 1:46 PM
I hear HPT will work with the 97 ECU but not with the 96. I swapped my cars ECU to a 97 and it runs just fine. For me, it was simply plug and play since my car already had the 2-plug setup. Will i have any kinks or snags in HPT once i decide to get a tune after i set up my turbo?
Im still runnin with the "96" PCM and harness.
///ATLANTA~ATNALTA\\\
Re: got my 96 to 97 ECU swap.....i have a few questions now
Tuesday, February 26, 2008 1:47 PM
Im also running the OHV 2.2l motor, non-eco.
Wednesday, February 27, 2008 3:27 PM
there is only one computer in our cars 99 and down. your car is now, for the most part, a 97.
Friday, February 29, 2008 12:14 PM
Okay, good. So that means as far as me having the 96 - 97 problems, there should be none.....??
But, the ECU that i pulled the car from has the ECU manufactured in Mexico, not Canada. Ive heard that HPT some times has issues with the ECU from Mexico. My VIN# shows that my car was manufactured in Canada though. What happens if i run into some software kinks regarding that?
Saturday, March 01, 2008 6:50 AM
Did you find your ECU here?
Which one of these does it look like?
"The FACTS are always subject to CHANGE once the TRUTH is applied"
"In the entire history of man the only stupid questions are the ones that don't get asked"
Sunday, March 02, 2008 12:04 PM
Uhhh.....whoops.....No, i found a different box that has 2 plugs of wires attatched to it underneath my dashboard. I thought that the PCM was located up there underneath my front bumper, not the ECU. So, what was it that i changed out??? I coulda sworn it was the ECU that i swapped.....guess not....
So....uh i guess i need to go back to the junkyard and pull another ''ECU''....
Sunday, March 02, 2008 1:40 PM
ECU=Engine Control Unit,PCM=PowerTrain Control Module,ECM=Engine Control Module. = Same things...
Different people call them different names.
Edited 1 time(s). Last edited Sunday, March 02, 2008 2:05 PM
Sunday, March 02, 2008 9:06 PM
yeah, now i'm wondering what you chanaged...
Tuesday, March 04, 2008 12:54 PM
Yeah, i know about all the different names of the ECU/ECM/PCM etc......but, i changed something out thats NOT the ecu...?
I dont know what it is that i changed. Its a little steel box that has ABS printed on it, and has 2 harnesses attatched to it, each harness holding ~15 - 20 wires on each, and its located underneath the dashboard on the drivers side of the car. Theres not really a better way i can describe it.... Its also located next to the fuse box too.
Also, i know that when i went on the first ''test-drive'' after i installed it, when i WOT-ed the car, it shut off for a second, my headlights went off, and it turned RIGHT back on, but the open-door chime was going for ~5 seconds. I havent had a problem after that.
I coulda SWORE it was the ECU i changed though...oh well.... (i have a feeling im about to hit a brick wall in this project....aka ecu to harness issue.)
Tuesday, March 04, 2008 2:12 PM
madking411 wrote:I dont know what it is that i changed. Its a little steel box that has ABS printed on it, and has 2 harnesses attatched to it, each harness holding ~15 - 20 wires on each, and its located underneath the dashboard on the drivers side of the car. Theres not really a better way i can describe it.... Its also located next to the fuse box too.
you changed the abs (ANTILOCK BRAKING SYSTEM) module.
