Shifting with HPT - Tuning Forum
Shifting with HPT
Thursday, December 06, 2007 8:25 AM
Unless I can find another way, I may just end up biting the bullit and buying the basic version of HPT just to control shifts. I really just need to know what the MAX rpm HPT will allow the trans to shift at. Thanks.
"Youth in Asia"...I don't see anything wrong with that.
Re: Shifting with HPT
Thursday, December 06, 2007 6:33 PM
seeing as people are raising their redlines higher than stock, i would assume you can increase the shift point to follow suit. call me crazy, but that just might work.
personally, i doubt your car would need to shift higher than the current redline as it probably falls on its face in the powerband much earlier than 6000 rpm.
1997 RedR - ZedR
Thursday, December 06, 2007 7:50 PM
HP Tuners limits the max shift rpm to 8192, however, GM specs the max shift rpm for the 4T40 at 6500 RPM(although I suspect there is probably a few hundred rpm safety factor in there), so be careful not to make a change you will regret later.
http://media.gm.com/division/2003_prodinfo/03_powertrain/03_auto_trans/index.html
If your car is basically stock, there is no benefit to revving the car that high, it starts losing steam around 6000 rpm.
Tire Industry Association (TIA) Advanced Tire Service Instructor
Graduate of Michelin Advanced Sales Training
Graduate of Rod Hall Off Road Driving School
Graduate of Vehicle Driving Dynamics, Michelin Laurens Proving Grounds.
2002 Ford Ranger Edge Extra Cab, Flareside
3.0L V6, 5 spd auto.
Bamachips Xcal2
160 hp, 196 ft/lbs (crank)
31X10.5R15 Bridgestone Dueler A/T 693
K&N flat panel
Custom side exit exhaust
Monroe Max Air Shocks
Infinity 6" Component Speakers
Credence 10" DVC sub
Dual Amp
Custom built passive x-over & sub enclosure
Thursday, December 06, 2007 9:16 PM
Shane Hewitt wrote:HP Tuners limits the max shift rpm to 8192, however, GM specs the max shift rpm for the 4T40 at 6500 RPM(although I suspect there is probably a few hundred rpm safety factor in there), so be careful not to make a change you will regret later.
I would only need up to about 7600-7800 max, so that's perfect. Car is far from stock and may recieve a set of sexy cams, hence the need for the higher shift point. The 4t40e has been proven to take one hell of a beating (over 100 ft-lbs more than they torque rate it). I'm curious how accurate their claims about the revs are as well.
Thanks Shane.
Edited 1 time(s). Last edited Thursday, December 06, 2007 9:17 PM
Thursday, December 06, 2007 10:57 PM
or u could make friends with someone local that has hpt. now i wonder who here has hpt within 30 mins of joliet...?!?!!
Thursday, December 06, 2007 11:34 PM
^^^ I believe you still have to pay $200 anyways to license another vehicle. I'd prefer to pay more to have full access to the hardware so I can change the points as need be (i.e. HO to HG2 cam changes and vice versa).
Friday, December 07, 2007 8:19 AM
Be very careful when modifying shift tables. There are a LOT of parameters that affect shift, not just RPM. Its actually a combination of tables like Shift Vs RPM, Shift Vs TPS, Shift Vs Speed, Desired Shift Speed, Normal, Performance, Cruise, and Hot, TCC control, Part Throttle Shift, Full Throttle Shift, Force Motor Current, Shift Pressure, Torque Management...
All of those need to combine the right way to get your desired shift. Don't be surprised if you edit the shift RPM table and it doesn't do what you want it to do.
Friday, December 07, 2007 11:11 AM
^^^^^ Thanks Ron. I'll definately keep those parameters in mind.
Saturday, December 08, 2007 1:22 PM
50 per credit, 2 credits. but ya that was the reason i got my own
