Cam position sensor and cam sync generator - Tuning Forum
Wednesday, October 17, 2007 7:22 PM
I have my LD9 setup with a GM s/c running 8lbs of boost, p/p head with HO cams, 62mm throttle body, and some other mods. I am planning on using HPT but I have no cam signal (HO cams). Will the cam sync gererator help with this setup or not. I have heard it will. Any help would be apprciated.
Re: Cam position sensor and cam sync generator
Wednesday, October 17, 2007 7:39 PM
not needed, u can just run it without the cam signal, u will just not run in single fire injection mode. but the car will run fine go unplug it and drive around, u prob wont notice a thing, i didnt
Thursday, October 18, 2007 4:30 AM
The car is running extremly rich off of idle. I am using 52lbs injectors.
Thursday, October 18, 2007 2:35 PM
Will HPT help even with it in batch fire mode?
Thursday, October 18, 2007 3:40 PM
ya, under the pe section there is a table for double fire and u will prob need to play with that. im running 320cc injectors right now and the car ran fine without the signal, my ho cams will be goin in one of these weeks soon. just need to get around to it
Thursday, October 18, 2007 5:49 PM
I hope to get it tuned this weekend. I will let you know how it turns out power wise.
Thursday, October 18, 2007 7:46 PM
well sweet i cant wait to see how those ho cams compare to the babay secret cams lol. hopefully after ill pull better than a 14.7 n/a
good luck gettin it tuned, cant wait to see numbers, i just hope that charger doesnt turn into a restriction for u...
Friday, October 19, 2007 3:19 PM
I even ported the s/c a little.
Tuesday, October 23, 2007 4:38 AM
I went to the HPtuners forums and asked about that the cam signal and got no responce. I did find out about the double fire mode though.
Tuesday, October 23, 2007 8:11 PM
ya on older quads they dont have the single fire mode, and they run fine. they run batch fire all the time, they dont have the cps on the cam or a sensor to pick it up. u will just need to tune for it, so everything works correctly. i just havnt got around to all this yet to get my stuff goin, i need to get those cams in my motor like asap
Wednesday, October 24, 2007 3:19 PM
They are calling it double fire mode.
Wednesday, October 24, 2007 3:23 PM
THAY (GM) call's it BATCH fire.
LD9's will run fine in bach fire mode.
Chris
'02 Z-24 Supercharged
Wednesday, October 24, 2007 3:59 PM
Taetsch Z-24 wrote:THAY (GM) call's it BATCH fire.
Chris
yup gm = batch fire
hptuners = double fire
its the same thing potato, patato ya know haha
ps chris speaks the truth, now tell us how those ho cams work in ur set up 02z24sc
Wednesday, October 24, 2007 4:08 PM
Give me a couple of weeks and I will post the numbers and what mods I have done.
Wednesday, October 24, 2007 7:10 PM
if you want to run sfi mode, just pickup an MSD cam sync generator. I've used it and it works great
_______________________
** Flat Broke Racing Inc.**
Thursday, October 25, 2007 4:22 AM
I was thinking of getting the cam sync generator. Should I get a wide band 02 sensor and where would I get it from?
