Any tuning issues with higher Horsepower cars? - Tuning Forum
Monday, September 17, 2007 12:23 PM
With at least 4 cars now over the 400hp mark (hopefully I'll joining in soon) I was just wondering what if any problems are raising their ugly heads...
"The FACTS are always subject to CHANGE once the TRUTH is applied"
"In the entire history of man the only stupid questions are the ones that don't get asked"
Re: Any tuning issues with higher Horsepower cars?
Monday, September 17, 2007 5:12 PM
Well I soon hope to be joing that 400hp club, got my tune workin today No real issues off hand besides my stupid fuel pressure reg wants to act up every now and then.
Monday, September 17, 2007 8:26 PM
The VE tables on hpt suck. You only have 100% of VE to work with so moving the high rpm VE up kills your idle VE. Spark past 6400 and fuel past 7000. It all plays a big part and makes things difficult.
Tuesday, September 18, 2007 12:08 AM
tell me about it
SPD RCR Z - '02 Z24 420whp
SLO GOAT - '04 GTO 305whp
W41 BOI - '78 Buick Opel Isuzu W41 Swap
Tuesday, September 18, 2007 7:43 AM
Could it be a problem of running high impedence injectors? Or is it more of a HP didn't decode enough usable files?
A lot of the local "import" guys that I feel actually know what their talking about say to wire in resistors and run low impedence injectors because anytime they get over 550cc with high impedence they have problems with idling/tuning and other problems. But when they switch to low impedence they can run up to 1000cc without problems because they can react (open and close) faster.
What about Spark control? Any problems there?
I'm debating rather or not to just say screw it and go ahead and wire in the Tec3 or just go ahead and get the car back on the road now and then wire it in this winter.
Tuesday, September 18, 2007 9:06 AM
Well there is a reason that 750cc is the largest High imp injector you can find. I think we need to get the resistor box for brians car and use the 1000 cc injectors. That idle pulse you have brian could be from the injectors not closing fast enough.
Tuesday, September 18, 2007 10:45 AM
listening......
my issue right now is misfires popping up, which is my guess for not a strong enough spark along with to high of a plug gap. like i was discuessing with tom last night the thing that sucks about hpt is long flash times, and amount of time the ecu takes to learn the tune. my car idle decent with 750cc but always runs like poo when cold, i would like to know more about the resistors i have a set of 1000cc low imp. i think for the motec..... but i think for what little was changed from the gm reflash car doesnt run that bad, one of the questions i was having is has anyone tuned out rich conditions when in pe mode but no to low boost? my car goes 10.0 on the aem wb before boost kicks in
R.I.P. Brian Klocke, you will never be forgotten
Tuesday, September 18, 2007 11:23 AM
So your talking higher rpms w/o any boost?
Tuesday, September 18, 2007 2:06 PM
no im talking about during lag, i make full boost at 4k, but before that it will run 10.0 afr @ 5psi,
Tuesday, September 18, 2007 2:59 PM
Boosted2point4 wrote:no im talking about during lag, i make full boost at 4k, but before that it will run 10.0 afr @ 5psi,
we could clean up the VE around those cells..
P&P Tuning
420.5whp / 359.8wtq
Tuesday, September 18, 2007 3:07 PM
Also (even tho Protomec says its not the best way to do it) you can use the IPW multiplier vs Map, I suggest using the VE tables as well.
Tuesday, September 18, 2007 8:43 PM
ok so really need to look into the resistor thing, tom figured out that i have maxed out my 750's 104 injector duty cycle, 18msecs.
Tuesday, September 18, 2007 11:53 PM
x2. im getting spark blow out.
http://www.myspace.com/15102113
12.5@116 2.0 60ft
Wednesday, September 19, 2007 5:02 AM
Boosted2point4
10 watt x 10 ohm resistors from Radio Shack (about $6 for 4) spliced into the Grey wire on the injector should do it.
Here's a pretty good write up http://www.team-integra.net/forum/display_topic_threads.asp?ForumID=10&TopicID=172611&PageMsg=Viewing+Common+Topic
Edited 1 time(s). Last edited Wednesday, September 19, 2007 5:25 AM
Wednesday, September 19, 2007 7:49 AM
How exactly should this splicing be done? I am likely going to do this as i'm running low imp injectors on my 99. I never had an issue in the past when I was s/c but i'm sure once the boost goes up something could pop up. Would the resistor simply be spliced in line (wire ---> resistor ---> wire) ?
President/Founder - 607 Motorsports
Wednesday, September 19, 2007 7:59 AM
regardless of tune, I think idle is going to suffer slightly with 1000cc injectors
I've heard it being referred to as "trying to fill a shot glass with a garden hose"
a staged injection system like the hahn port fueler is really the best option for a high HP high boost street car
either that, or raise the idle speed to 1500 or 2000rpm. it sucks, but at least it will idle, right?
hopefully HPT will start to try and crack more of our ECU and offer us some more support.
I've been thinking that our ECUs are just the major electronic weak point of our cars. HPT can't defeat it because its just that bad. lack of flexibility stock and lack of flexibility even after a reflash.
HPT serves its purpose to an extent, but once you begin getting into more advanced tuning it just doesn't seem to cut it anymore (unless you're an LS1/ LS2 guy)
Wednesday, September 19, 2007 8:02 AM
That's how they would wire in but you shouldn't have a problem with a '99 PCM.
I'm pretty sure the injector drivers are the same in a '99 as they are in a '97-'98. You can run High impedance injectors with low impedance drivers ('97-'98-'99) but you can't run Low impedance injectors with high impedance drivers ('00> ).
Wednesday, September 19, 2007 8:08 AM
I wish I could track down my mis-fire issue..... I had it pre-boost...... and now with boost, its just gotten worse. I've checked my connections for the Injectors, replaced the 2.4 ICM, swapped to 2.2 coil conversion, new spark plugs (3 different sets), different fuel injectors (OEM, 60lb, 72lb)..... I'm going to try adding a engine ground kit, and maybe a voltage amplifier...... other then that, I'm at a loss.
I might be putting my 'recently purchased' 72lb/750cc injectors up for sale. I have a line on some 900cc injectors.... Then I guess its time to add the resistors (thanks for the info Gary).
Wednesday, September 19, 2007 10:46 AM
I found this write up for the resistor install http://www.homemadeturbo.com/tech_projects/dsm_injectors/index.html. It says to put them in the POWER WIRE FROM THE ECU which on our cars would the x color with BLACK STRIPE.
If anybody finds anything different please feel free to correct.
Wednesday, September 19, 2007 11:17 AM
misfire problems would be nice to find out... i guess im going to end up putting in the 1000cc we'll see how that goes, my neighbor works at a honda dealership and is suppose to be bringing me a resistor box
Wednesday, September 19, 2007 12:45 PM
I should have my car tuned by the end of next week. I will let you know how it went. I am only looking for 300whp though.
Darryn
2004 Cavalier coupe, 5 speed, White
GO
Hahn Stage 2, Eagle rods, Wiseco 8.9, SS Valves, Dual valve springs, valve job, Ti seats and retainers
spec stage 3, Fidanza 7.5lb flywheel, Short Shifter
Slotted and dimpled rotors, EBC green stuff
SHOW
VIS EVO CF hood, KOBE KAM 5 17", Nexxen N3000, Ebay Black tails and filler, 5% tint
Gold line springs, Tokiko D-spec struts
ELECTRONICS
Kenwood in-dash DVD and Navigation, single Kicker CompVR
http://www.cardomain.com/ride/2974835
Wednesday, September 19, 2007 6:29 PM
Listening..
1999 Grand AM SE (Beater Car)
1997 GMC Sierra
2007 Honda CBR 600RR
2005 Honda TRX450R
Wednesday, September 19, 2007 7:48 PM
ive got a 3 bar tune ready to go for brian as soon as he gets a 3 bar map so we will see how that works out.
Friday, September 21, 2007 11:29 AM
DaFlyinSkwirl (PJ) - BPU++ wrote:regardless of tune, I think idle is going to suffer slightly with 1000cc injectors
Hey guys, I browse this forum once a month or so to see what's up in the tuning section and this post caught me.
In the order of items you speak of:
You will find idle much easier to tune with a manifold referenced regulator. The vacuum at idle reducing rail pressure is nice.
There are more tables that HPT needs to make available (see EFIL), but also, part (and a very time consuming part) of a manufacturers budget for new cars is controls and calibration. Keeping it simple up front aids all around for profits. The ECUs programming for these cars is unfortunately very basic, and even with access to more of the relevant tables, shortcomings will abound. All we are tuning is data tables for fixed programming, and if the fixed programming is not there, nothing outside of a custom OS can fix this... So that's a wall. The LSx crowd benefited from the fact that the control system for the first LS1 (and those to follow) started on a flagship car (vette, duh!) that gets a much larger developement budget than a j-bod. Then, in the years to follow, the vette would share PCM architecture with the F-body. These vehicles (and v8 vehicles to follow) have all benefited.
Personally, unless supercharged, if I were pushing the stock bottom end or working with a built engine, I'd be running mega-squirt along with the stock PCM. It's cheap and it does all that you want and more (for the most part )
Friday, September 21, 2007 12:32 PM
can anybody post screen shots from EFI Live? i want to see teh diff.
