My 97 ga 2.4l turbo set-up consists of a vortech blazer fuel pump, accel afpr, ford brown top injectors, Garrett t04e 50 trim turbo, tial 38mm wastegate, wiseco 9:1 pistons, eagle rods, ac delco 3 bar map sensor, innovative wideband, and standard version of hpt...I know, I know, I should have bought the pro version. I tuned everything I could tune as far as the how-to's go except for the VE tables because I can't data log and don't know how to do it any other way. The car starts after turning it over for about 10-15 seconds and idles fine. The a/f ratio is reading 10.3 @ idle. The problem is when I touch the gas pedal...the car richens out to the point of killing it. The a/f drops anywhere from 1-3. If someone could help me out and point me in the right direction, I would really appreciate it. I need to adjust the main VE High RPM table, low rpm dbl, low rpm sgl, and ve offset %. Also, my tables are pretty much maxed out because of the 3 bar upgrade so I need to start knocking off a few #'s in the 1st cells. I would post my file but I'm not really sure how to on the org.
Anyone? I am going home this weekend and would really like to take the car out.
Shifted wrote:The low RPM single table is where most of your idle VE will be. You'll need to knock that down to get it into line.
I haven't touched this table yet so should I still cut it down a few?
Bp wrote:Shifted wrote:The low RPM single table is where most of your idle VE will be. You'll need to knock that down to get it into line.
yes..if you use the scanner you can tune your timing tables with it.. avoid excessive knock retard.
