Might have already been talked about but i searched and didnt find what im looking for. Can you change the injector duty cycle with HP tuners? 97 2.2L
http://www.cardomain.com/ride/2090440
Speaking of this, where do you look to see what your injector duty cycle is?
Well the reason im asking is because i have the ford green tops in right now but i have to run next to 0 fuel pressure to keep it from flooding it self. So if i can change the duty cycle i can increase the fuel pressure?
Your injector duty cycle is the end result of what you set your VE tables to, and the VE tables are shifted when you alter the injector constant. IE: you change your duty cycle by changing the VE tables, and when you change the injector size, you change the injector constant to make the existing VE tables a better match, and tune from there.
15.3 @ 89.97mph - '01 SFGT
'98 Acura 1.6EL Sport 5M Y7/Y8 mini me
Oh ok thanks this dumb guy in my class said that lol... but you can change the constant with hp?
yes thats how you scale for bigger/smaller injectors
You should all be glad you dont have a MAF based PCM, its 10x harder to scale for
Rodimus Prime wrote:yes thats how you scale for bigger/smaller injectors
I'm very thankful we do not have MAF!!
