Roscoe wrote:just disengaged the AWD right...
QBE (73H 800573D 0N3) wrote:he took out the front drive axles, they do it all the time in skylines for drifting
it all started when my rear diff. started to take a crap, i knew it was going to go some day because of the clicking from the rear spider gears, anyway i decided to take one of my 15 trannys laying around and build a temporary rwd tranny to blow up my rear diff. So i took my tranny apart and welded one side of the center diff, took out the viscous coupling and took out 2 of the spider gears and the one side gear that drove the front diff. i also ended taking out the front diff. (not nesscary). put all that back together and used two frost plugs to block off the front axle holes in the tranny case and put stub shafts threw the front wheel bearing to hold the preload on the bearings. Then i called my friend and told him to grab the camera and lets go blow up my rear diff. so anyways it lasted about a week. it was damn fun until i had to tow it home!
