Hey guys, I was wondering if anyone knew how to reset an SRS Light in a 1995 Eclipse. My girlfriend bought this car and the light won't turn off. I read that it's likely due to someone disconnecting the Airbag. Any input will help thanks!
-Anthony
Unfornutley dealerships are the only place that have the scanner codes for the airbag since they run off a seperate computer then the rest of the car.
you can try to unplug the battery for a while if you haven't but usually once the light is tripped for any reason it won't go off again until cleared by a scanner. mitsu dealerships can reload the system.
If the airbag really is disconnected then the light will stay on because it checks for an airbag everytime you start the car. So you can just pop out the gauge cluster and take out the srs light bulb. Ghetto, but it works.
When I had that happen I popped off the cover to fix the horn and cleaned the connectors while I was there. My SRS light turned off, take that for what its worth. just don't kill yourself.
dave is it a bitch to tune those 660's? im running 510's on my b16g and its no problem at all, but my old 550's were a bitch for some reason, i had to do a retune anytime the weather would change, it sucked.  but im going with 660's with my hybrid in my garage so thats why i asked.
