K my friend has a completely stock 02 WRX. He just dropped it off to me to have a few things installed.
He says that its not boosting properly, he took it to a dealer in wyoming and they said there is nothing wrong. In first gear it pulls pretty hard but in any other gear it doesnt pull as hard. I cant really say if theres a problem my self cause I've never actually driven a wrx. Any one have any ideas, im going to be taking it a dealer in denver and hopefully they will have a clue.
ecotecpower wrote:K my friend has a completely stock 02 WRX. He just dropped it off to me to have a few things installed.
well, it is AWD. AWD usually pulls hard in first then after that yo udont feel as fast as you are going.
Yeah thats what I m thinking. Anyone else??????
Whats it boosting at in 2/3? Look up what it should be at and compare. I agree, its AWD you'll feel that.
I know its not the same, but it kinda is. My explorer is the same way. Its AWD V8 and first gear just feels like its a monster after that doesn't feel that quick, but the speedo moves.
Ummm.. In any car you will never put more torque to the ground than when you are in first gear. That is purely because of what gears do (trading some torque for speed or vice versa).
<A HREF="http://www.precizion.org/forums/"><IMG SRC="http://www.brew-san.com/pics/sig.jpg" border=0></a><A HREF = "http://www.precizion.org/forums/"><IMG SRC="http://www.j-body.org/registry/kenz24/precizionsmall.gif" border=0></A>
factory boost should be around 13.5-14lbs
My Car Sucks
does he have a boost gauge? i know my friends 05 wrx, he had a boost gauge installed on his, it seems to pull hard through first and second.
-Adam
He has the stock subaru 3 gauge set-up. So I cant really tell what boost he's hitting, its all in Bar
Sounds like you buddy's car might not be hitting full boost. It definitely shouldn't feel like its lagging after 1st gear, once your into boost, it should pull pretty hard right through the gears.
Since the boost gauge is in BAR, what you can do it convert it to PSI and go from there. 1 BAR = 14.5 PSI - so it should be just just below 1 BAR, seeing as the WRX boosts around 13.5-14 PSI.
Heres the formula to help you convert, good luck
PSI = 14.5037 x Amount of BAR
My CarDomain Page
Last night when it was colder out it seemed to get closer to 1 bar than it did today when it was warmer. I realize thats normal though. I'm almost starting to think its more along the lines of that he's so used to his car that it doesnt feel as fast as it used to. I dorve the car quite a bit today and it feels fine to me. First does pull the hardest, but the rest definately arent lacking. There just smoother than first. He want me to install a dual stage boost controller so that should solve his problems
I say keep telling him you haven't found the problem and drive the @!#$ out of it. HAHA
If you are going to put a boost controller good luck they are a pain in the butt to figure out word of warning on you high boost setting dont go over 16lbs if you do this you will eventually blow the engine i am running a greddy profec b controller at 15 lbs on my wrx and the car hauls ass also i have up pipe etc but dont push the car unless you have other mods!!!
ENVIOUS C.C. PRESIDENT
I have my boost control set at 14.5. But make sure you set it in a high gear. I set it in 3rd at about 16 just to see what it would be like once. But when I got on the freeway it creeped a bit in 5th and hit the fuel cut off. -scared the crap out of me.
I also have an uppipe, and I flowmaster exhaust. I also have a Blitz short ram intake, and an HKS SSQV bov. (although that isn't a performance mod....it sounds soo nice.)
It pulls hard in most gears. It did slow down things quite a bit though when I put my 18's on. But I still walked away from a Audi twin turbo the other day. a T4 I think it was called. I don't know anything about them, but it had at least the exhaust done and it put up a pretty good fight.
<img src="http://www.j-body.org/registry/batman/personal_pic.gif">
you suck matt, come let me drive it
