2011 Hyundai Genesis Coupe - Other Cars Forum
Saturday, July 17, 2010 10:22 AM
No pricing as of yet.
From Hyundai...
2011 HYUNDAI GENESIS COUPE
Fresh off its inaugural year in which it thumped the likes of G37, Mustang, Camaro, and Challenger in various comparison test shoot-outs while leading all competitors in residual value, Hyundai’s Genesis Coupe is back for 2011 with interior updates, a revised lineup, and its hottest model ever, the 3.8 R-Spec.
2011 GENESIS COUPE HIGHLIGHTS
Interior refinements
New soft-touch, matte-finish surfaces on door panels, center speaker grille, glove box, and lower instrument panel
New dark metalgrain accents on center stack, door handles, air vent register bezels and steering wheel trim
Padded door armrests
Softer, premium steering wheel leather
Cloth-wrapped A-pillars
Chrome finish for A/T shift gate bezel and center stack control knobs
Chrome finish gauge cluster rings
Rear coat hooks
Trunk deck lid grab handle
Enhanced multi-information display screen graphics
3.8 R-Spec model added
Navigation with Full Automatic Temperature Control now standard on Genesis Coupe 2.0T Premium
Revised model lineup featuring six flavors of Genesis Coupe: 2.0T, 2.0T Premium, 2.0T R-Spec, 3.8 R-Spec, 3.8 Grand Touring, 3.8 Track
INTERIOR DESIGN
For 2011, Genesis Coupe features several interior upgrades that reflect Hyundai’s commitment to craftsmanship and high-quality materials. The instrument panel is crafted in a seamless, soft-touch skin fully encompassing new dark metalgrain trim. Softer leather now wraps the steering wheel and padding has been added to the door armrests for increased comfort. The A-pillars are now covered in a premium fabric to match the roof liner. New information screen graphics enhance appearance and readability and the finish of the controls has also been enhanced.
“The interior upgrades, our hot new 3.8 R-Spec model, and revised lineup of six focused models show that Hyundai is meeting the demands of our customers,” said Scott Margason, director, product planning, Hyundia Motor America. “The upgraded interior is a great illustration of how Hyundai continually raises its own high benchmarks for quality."
2011 GENESIS COUPE
The 2011 Genesis Coupe is a purpose-built rear-wheel drive sport coupe featuring two performance-focused engines – a 210-horsepower, 2.0-liter turbocharged four-cylinder engine and a range-topping all-aluminum, 306-horsepower, DOHC 3.8-liter V6 engine.
306-horsepower from enhanced 3.8-liter V6 from Genesis sedan
210-horsepower turbocharged, intercooled inline four cylinder
Platform-mate and sinister sibling of the Car of the Year-winning Genesis sedan
Genesis Coupe is Hyundai’s most dynamic performance car, appealing directly to the true driving enthusiast. Genesis Coupe uses the same flexible rear-wheel drive architecture developed for the Genesis sport sedan.
POWERTRAINS
Two engines infuse Genesis Coupe with performance. The 3.8-liter Lambda DOHC V6 engine delivers 306-horsepower and 266 lb.-ft. of torque on regular unleaded. This engine will launch the Genesis Coupe from 0 to 60 miles per hour in 5.5 seconds. To maximize the power band, the 3.8-liter engine utilizes DCVVT and a new Variable Intake System (VIS) that helps cylinders breathe more efficiently at both low and high RPM. The better-breathing results in outstanding off-the-line acceleration, passing performance and remarkable fuel efficiency. The V6 engine uses an alloy block and cylinder heads for lighter weight and thermal efficiency and features durable timing chains with no scheduled maintenance.
The turbocharged, intercooled 2.0-liter DOHC inline four-cylinder benefits from Dual CVVT on both the intake and exhaust camshafts. The 2.0-liter turbo generates 210-horsepower and 223 lb.-ft. of torque. It also features a cast-aluminum cylinder block and cylinder head. Both engines feature a free-flowing dual cat-back exhaust and an available Torsen® limited-slip differential to put the power to the ground.
SPORT-TUNED SUSPENSION
Genesis Coupe employs a MacPherson® strut dual-link front suspension and a five-link independent rear suspension setup. The front suspension is mounted to the body via a solid subframe which is lighter and stronger than a multi-piece component would be. To help reduce body roll and tune the Genesis Coupe’s at-the-limit handling for maximum predictability, 24-mm diameter front and 19-mm diameter rear stabilizer bars are used.
While all Genesis Coupe models offer a sporty and involving driving experience, the high-performance Genesis Coupe R-Spec and 3.8 Track models are the most willing partners for the true enthusiast. The track-tuned suspension features a stiffer front spring rate, stiffer rear spring rate and unique shock valving. The Genesis Coupe R-Spec and 3.8 Track models deliver a substantial increase in roll control over standard versions of the Genesis Coupe. Superb structural rigidity sets the foundation for precisely-tuned handling performance in all Genesis Coupes.
TRANSMISSIONS
Both engines are mated to a standard six-speed manual transmission. The Genesis Coupe 2.0T offers an optional five-speed automatic with SHIFTRONIC® while the 3.8-liter V6 offers a ZF® six-speed automatic transmission with SHIFTRONIC to handle the additional torque. Both automatic transmissions feature steering-wheel-mounted paddle shifters.
HIGH PERFORMANCE BRAKING SYSTEMS
Brembo four-piston calipers clamp down on 13.4-inch ventilated front brake rotors and 13-inch ventilated rear rotors on R-Spec and 3.8 Track models. All other models get substantial 12.6-inch front ventilated rotors and 12.4-inch rotors in the rear with floating single-piston calipers.
INNOVATIVE TECHNOLOGIES
The 2011 Genesis Coupe 3.8 Track offers Xenon high-intensity discharge (HID) headlights. The advantages of HID headlamps include greater lighting power, daylight-type lighting and reduced power consumption.
Music lovers will welcome the 2011 Genesis Coupe’s standard auxiliary input jacks (3.5 mm mini-jack and USB input) to accommodate and charge audio devices such as iPods®. There is an optional in-dash navigation unit with a multi-gauge information display screen. This system provides new features including Bluetooth streaming audio capability. This easy-to-use unit can be controlled via 6.5-inch WVGA touchscreen or voice-recognition by headliner-mounted microphone.
SEGMENT-LEADING SAFETY TECHNOLOGIES
In keeping with Hyundai’s focus on offering segment-leading standard safety technologies across its lineup, the 2011 Genesis Coupe includes a wide range of both active and passive safety features. Standard safety technologies include driver and front passenger advanced frontal airbags, along with front seat-mounted side airbags, side air curtains and active front head restraints.
All Genesis Coupe models feature standard four-channel ABS with Electronic Brake-force Distribution (EBD) to optimize brake performance under various dynamic loading conditions. The system also includes Brake Assist, which provides maximum ABS-level braking force when a panic stop is detected.
Electronic Stability Control (ESC), one of the industry’s most effective life-saving technologies, is standard in all Genesis Coupe models.
WEIGHT EFFICIENCY
“One of the program targets for the Genesis engineering team was world-class weight efficiency,” Margason said. “When you look at the size and content of both Genesis models, you’ll find we lead all our competitors in weight efficiency. We also target leadership in power-to-weight ratio. We think that’s just smart strategy in today’s world. It pays huge dividends in both performance and fuel economy, and that’s especially important in the segments in which these cars compete.”
Vehicle
Engine
Curb Weight (lbs.)
Length (inches)
Genesis sedan
3.8-liter V6
3,748
195.9
Genesis sedan
4.6-liter V8
4,012
195.9
Genesis Coupe
2.0-liter turbo
3,294
182.3
Genesis Coupe
3.8-liter V6
3,389
182.3
Both Genesis Coupe and sedan are rich in ultra-high-strength steel, leading to world-class body rigidity. The Genesis sedan is 10-12 percent stiffer in torsion than its Lexus and Mercedes-Benz competitors, yet it is lighter than these benchmark sedans, and offers more interior room. At just 3,294 pounds, the Genesis Coupe 2.0T is hundreds of pounds lighter than all of its IRS-equipped rear-wheel drive competitors, with body-bending rigidity 24 percent higher than the BMW E46 M3.
Vehicle
Length (inches)
Curb Weight (lbs.)
Horsepower
Power-to-weight ratio
Genesis Coupe 3.8
182.3
3389
306
11.1
BMW 335i
181.1
3560
300
11.9
Infiniti G37
183.1
3627
330
11.0
Camaro LS
190.4
3780
304
12.4
Challenger
197.7
3819
250
15.3
This focus on weight efficiency pays dividends across the board. The Genesis sedan owes its ability to deliver both strong performance (0-60 mph in 5.5 seconds) and excellent fuel economy (25 mpg EPA highway rating) in great part due to its impressive weight efficiency. Similarly, the Genesis Coupe 2.0T sets a high fuel efficiency bar with a remarkable 30 mpg estimated EPA highway rating, because of its weight-efficient platform and its efficient 2.0-liter, low-pressure, turbocharged four-cylinder engine.
GENESIS COUPE PRODUCT HIGHLIGHTS
2.0T (6-speed MT or 5-speed AT)
2.0T R-Spec (6-speed manual transmission only)
2.0T Premium (5-speed AT only)
3.8 R-Spec (6-speed manual transmission only)
3.8 Grand Touring (6-speed AT only)
3.8 Track (6-speed MT or AT)
GENESIS COUPE 2.0T: A MORE EFFICIENT TAKE ON THE REAR-WHEEL DRIVE SPORT COUPE
Standard equipment includes:
2.0-liter, low-pressure, turbocharged, intercooled 4-cylinder engine with dual continuously variable valve timing delivering 210 hp, 223 lb.-ft. of torque (at just 2,000 rpm), 30 mpg EPA highway rating and a top speed of 137 mph
M6VR1 6-speed manual transmission (Optional: A5SR1 5-speed electronic automatic transmission with lockup torque converter and steering wheel-mounted paddle-shift SHIFTRONIC® controls)
18-inch Euroflange alloy wheels with staggered Bridgestone Potenza RE92A tires (225/45VR18 front, 245/45VR18 rear)
Electronic Stability Control with Traction control, ABS, Electronic Brake Force Distribution and Brake Assist
12.6-inch ventilated front rotors with 60mm single piston floating caliper
12.4-inch solid rear rotors with 43mm single piston floating caliper
Sport-tuned MacPherson strut dual-link front suspension and five-link rear independent suspension, 24mm front stabilizer bar, 19mm rear stabilizer bar
Front strut brace
Quick-ratio hydraulic steering (2.7 turns lock-to-lock)
Tire Pressure Monitoring System
Front, side-impact, side-curtain air bags
Active front head restraints
Driver’s lumbar support
Black-out front lower fascia
Air conditioning with outside temperature display
Dark metalgrain and chrome interior accents
Remote keyless entry system with alarm
Leather-wrapped steering wheel and shift knob
Power windows (one-touch up and down), door locks and mirrors
AM/FM/XM/MP3/CD audio system with six speakers
iPod/ USB/Aux jack connectivity
Steering wheel audio controls
Cruise control
Trip computer
Projector beam headlamps with auto light control
Bluetooth® hands-free connectivity with steering wheel controls
GENESIS COUPE 2.0T R-SPEC: THE ULTIMATE UPGRADEABLE, AFFORDABLE, TURBOCHARGED REAR-WHEEL DRIVE PERFORMANCE PLATFORM
R-Spec model adds or substitutes:
19-inch gunmetal-finish alloy wheels with staggered-width high-performance summer-compound Bridgestone Potenza RE050A tires (225/40YR19 front, 245/40YR19 rear)
Brembo® braking system with 13.4-inch ventilated front rotors, 42mm four-piston fixed front calipers (red), 13.0-inch ventilated rear rotors, 32mm+28mm four-piston fixed rear calipers (red)
Track-tuned suspension (higher-rate coil springs, higher-control shock absorbers, 25mm front stabilizer bar, 22mm rear stabilizer bar, front strut brace)
Torsen limited-slip differential
Black leather bolsters with red cloth insert seats
R-Spec badge
Front camber adjustment bolt (Camber bolts included but not installed. Dealer Installation of the camber bolts is optional at the customer’s discretion)
Note: Automatic transmission not available with R-Spec
To reduce cost, weight, and complexity, R-Spec eliminates some non-essential convenience equipment such as automatic headlights, cruise control and some chrome/metalgrain interior accents.
2.0T PREMIUM: HIGH DEMAND TECHNOLOGY
In addition to 2.0T standard equipment, the 2.0T Premium model adds or substitutes:
Power driver’s seat
360-watt AM/FM/XM/MP3/CD Infinity® premium audio system with 10 speakers including DVC subwoofer, eight-channel external amplifier and diversity antenna
Proximity key with push-button start
Auto-dimming mirror with HomeLink® and compass
Power tilt-and-slide sunroof
Touch-screen Navigation system
Fully automatic temperature control
GENESIS COUPE 3.8 R-SPEC
3.8 R-Spec equipment includes:
3.8-liter DOHC V6 engine with DCVVT delivering 306 hp and a top speed of 149 mph 6-speed close-ratio manual transmission
Torsen-type limited-slip differential
R-Spec badge
Front camber adjustment bolt (Camber bolts included but not installed. Dealer installation of the camber bolts is optional at the customer’s discretion)
Electronic Stability Control (ESC) w/ Traction Control System (TCS)
Anti-lock Braking System (ABS) w/ Electronic Brake-force Distribution (EBD)
4-Wheel disc brakes with Brake Assist
6 airbags: Advanced dual front airbags with Occupant Classification System (OCS), front seat-mounted side-impact airbags, and roof-mounted side-curtain airbags
Tire Pressure Monitoring System (TPMS)
Multi-information display (MID)
Fog Lights
Leather-wrapped steering wheel and shifter
AM/FM/XM®/CD/MP3 audio system
iPod®/USB and MP3 auxiliary input jacks
Steering-wheel-mounted audio controls
Bluetooth® hands-free phone system
Manual air conditioning w/ outside temperature display
Trip computer
Power windows with auto-down/up
Power Door Locks and Outside mirrors
To reduce cost, weight, and complexity, the R-Spec eliminates some non-essential convenience equipment such as automatic headlights, cruise control and some chrome/metalgrain interior accents
GENESIS COUPE 3.8 GRAND TOURING: REFINED PERFORMANCE WITH PREMIUM FEATURES
In addition to 3.8 R-Spec equipment, the 3.8 Grand Touring adds or substitutes:
ZF® 6-speed automatic transmission with steering wheel-mounted paddle-shift SHIFTRONIC® controls
Front strut brace
Premium door sill plates
Chrome front fascia accents
Power driver’s seat
Heated driver and passenger seat
Leather seating surfaces
360-watt AM/FM/XM/MP3/CD Infinity® premium audio system with 10 speakers including DVC subwoofer, eight-channel external amplifier, and diversity antenna
Touch-screen navigation system
Automatic headlights
Cruise control
Heated mirrors with outside turn signal indicators
Backup warning system
Note: Deletes track-tuned suspension, Brembo® braking system, Torsen limited-slip differential, camber adjustment bolts, and R-Spec badge
GENESIS COUPE 3.8 TRACK: ULTIMATE PERFORMANCE
The factory-tuned 3.8 Track model deletes the backup warning system and chrome front fascia accents from the Grand Touring model, and adds or substitutes:
Black leather seating surfaces
19-inch gunmetal finish alloy wheels with staggered high-performance summer-compound Bridgestone Potenza RE050A tires (225/40YR19 front, 245/40YR19 rear)
Brembo® braking system with 13.4-inch ventilated front rotors, 42mm four-piston fixed front calipers (red), 13.0-inch ventilated rear rotors, 32mm+28mm four piston fixed rear calipers (red)
Aluminum pedals
Xenon HID headlamps
Aero wipers
Rear spoiler
Lightweight temporary spare with aluminum wheel (T135/80D18)
Genesis Coupe is available in eight exterior colors:
Karussell White
Bathurst Black
Silverstone
Nordschleife Gray
Acqua Minerale Blue
Tsukuba Red
Mirabeau Blue
Interlagos Yellow
Genesis Coupe features four different interior themes:
Black environment, premium black cloth seats (2.0T, 2.0T Premium)
Black environment, black leather-bolstered seats with high-friction red cloth insert (2.0T R-Spec, 3.8 R-Spec)
Black environment, black leather seats (3.8 Track)
Black environment, saddle brown or black leather seats (3.8 Grand Touring)
>>>For Sale? Clicky!<<<
Re: 2011 Hyundai Genesis Coupe
Saturday, July 17, 2010 10:40 AM
so without reading for 4 hours...what is the advantage of the R spec?
Saturday, July 17, 2010 10:42 AM
DroptopPaul wrote:so without reading for 4 hours...what is the advantage of the R spec?
None really that I saw just another v6 package.
I <3 JGM
I think bigfoot is blurry,
that's the problem. It's not the photographer's fault. Bigfoot is blurry. And that's extra
scary to me. There's a large, out-of-focus monster, roaming the countryside.
"Run! He's fuzzy!" "Get outta here!"
Saturday, July 17, 2010 10:49 AM
eliminating the 2.0 track?? Interesting...
Their making you buy the r-spec if you want a turbo "fun" car with the performance stuff..
The only dif between the 2.0 track and 2.0 r-spec are push button start and leather that the track got...
2010 Hyundai Genesis Coupe Premium Edition
2.0 Turbo 5-Speed Automatic
Tsukuba Red
Saturday, July 17, 2010 11:45 AM
does look rather yummy in that interior. with good aftermarket support that 3.8 version could be a beast
Saturday, July 17, 2010 11:46 AM
I saw this posted and was hoping to God it was going to say they put the V8 in it this year. Very disappointing.
Saturday, July 17, 2010 11:51 AM
How is it disappointing with just a 4/6? This car has been praised up and down for being better then the camaro and mustang... hmm
Tsukuba Red
Saturday, July 17, 2010 3:26 PM
KleindlGTP wrote:How is it disappointing with just a 4/6? This car has been praised up and down for being better then the camaro and mustang... hmm
I think giving the car 3 engine choices would give it a little more credibility to it being "better" then the cars you mentioned.
To truly make this car competition to the others it should have a V8 option.
Having driven both the 2.0 and 3.8 I give them credit for being sporty but they just dont have that edge to standout in the class.
It looses alot of people who still have the "bigger is better" mentality.
I <3 JGM
Saturday, July 17, 2010 4:35 PM
these cars are really growing on me
Saturday, July 17, 2010 8:56 PM
any chance in hell that the coupe ever gets the V8
Sunday, July 18, 2010 1:46 AM
EcotecSS wrote:any chance in hell that the coupe ever gets the V8
2013/14 is the possible dates for the v8 to get dropped in but its all speculation right now. Its coming, just not now
Tsukuba Red
Sunday, July 18, 2010 7:38 AM
When they put a V8 in it, then I will no longer care for it.
Sunday, July 18, 2010 3:36 PM
a guy at work bought one when they first came out. It's already starting to look like junk. The inner front fender wells are falling apart, the paint looks like it's fading, and I guess the interior rattles quite a bit. I'll keep my Honda.
Watching you parade around my bedroom in a thong was a little like watching sea lions mate.
