will they fit - Other Cars Forum
will they fit
Tuesday, June 22, 2010 5:07 AM
My S10 has a bolt pattern on 5x120.7. the camaro bolt pattern is 5x120.65. will camaro wheels fit on an S10
z yaaaa wrote:other than the nasty hood dent, steelies, 4X4 ride heidt, crooked front license plate, body color b pillar covers, 2200, lack of tint, and overall boringness of the car id say she's perfect!
Re: will they fit
Tuesday, June 22, 2010 5:51 AM
Yes they will fit. Check the offset as well. That may cause them to not fit properly.l
Re: will they fit
Tuesday, June 22, 2010 7:02 AM
S10 and F-body cars both have a 5x4.75" bolt pattern. I'm not sure why the different metric measurement. However, the year of the F-body is important. The 4th gens have a higher offset, and will not fit the 2WD S10s. They fit the 4WD versions perfectly, though.
If you are looking at 3rd Gen wheels, like the RS or IROC style, swap the front and rears for proper offsets.
Re: will they fit
Tuesday, June 22, 2010 4:07 PM
what about corvette wheels. too big offset?
Re: will they fit
Tuesday, June 22, 2010 4:33 PM
My buddy has 3 blazers and 2 camaros. They swap.
Just be careful with the offset like said.
Vette wheels should fit btw.
Re: will they fit
Tuesday, June 22, 2010 4:36 PM
Depends on the year. C5 and C6 will have too high of an offset, but C4 and earlier will be OK. I've actually seen the first style 17" C4 rims on an S10. Not exactly a fan, but they fit well. Get some late C4 5 spokes, such as the Grand Sport ones, and it will look tits.
Re: will they fit
Tuesday, June 22, 2010 8:15 PM
^ They fit just need an adapter as they are offset way different
Re: will they fit
Sunday, June 27, 2010 8:02 AM
a friend of mine has C4 Vette rims on his MKIV jetta... not exactly sure how that works.. vettes arent 5x100 as far as i'm assuming or am i wrong?
www.driftnamiperformance.com
Re: will they fit
Sunday, June 27, 2010 8:34 AM
Corvettes are 5x120.7 but spacers = win when it comes to the offset.
as for C4 rims on MKIV jettas.. become sadly too cliche in some places.. but still look sexy
Re: will they fit
Sunday, June 27, 2010 12:55 PM
Go with the late 80's GTA snowflake rims. You will not be disappointed.
Re: will they fit
Sunday, June 27, 2010 6:31 PM
Mike Demo (Civic Eater) wrote:Go with the late 80's GTA snowflake rims. You will not be disappointed.
On a 94+ S10? I can't say that would look good at all. Slight upgrade from steelies, but that's about it.
Re: will they fit
Tuesday, June 29, 2010 8:06 AM
I have done it, you will need a drop or some correct truck tires but looks good. I had them on my 96 blazer and 97 jimmy. black with a polished lip. tits.. With drop the 245 50 zr16 was fun. on the truck for offroad, 245 or so with a 70 to 75 worked well.
Re: will they fit
Tuesday, June 29, 2010 12:03 PM
Something that may help when it comes to offset. Measure from the hub to the inner most part of your fender. Multiply that by 24.5 (theres 24.5 mm's in one inch) and thats your key number. We'll use mine for now. Its 65mm's on my IS300.
Take the width of the rim and multiply it by 24.5 (to get the number in mm's as well) 8*24.5 now divide that by two, the barrel is cut in half with the face. So we have 8*24.5 / 2 now subtract your offset from that. I'm running a 32mm so we'll use that number. Our formula looks like this now 8*24.5 / 2 - 32 = 66. Now we know 66 > than 65 so completely stock they will not fit on my car. I'll have to make up one mm (like by rolling the fenders) this can be used on any car. Just remember many things can change the variable. Excessive camber, extremely large tires.
Re: will they fit
Tuesday, June 29, 2010 9:01 PM
my s10 has 3rd gen camaro wheels on it, fits fine, looks good.. you might just look into getting the zq8 wheels instead though, they're all over, and generally easier to find in good shape
Fire is gone unfortunately! Parts 4 sale, look in Mid-Central...
Re: will they fit
Tuesday, June 29, 2010 9:03 PM
K.C. StreetFire (Casey Schaaf) wrote:my s10 has 3rd gen camaro wheels on it, fits fine, looks good.. you might just look into getting the zq8 wheels instead though, they're all over, and generally easier to find in good shape
The funny thing is that the ZQ8 wheels are the front RS wheels from the last 2-3 years of the 3rd gen Camaro, with a different centercap.
Re: will they fit
Tuesday, June 29, 2010 9:37 PM
May be a little late with the vette wheel info....C5 will fit with spacers, But you may rub at full lock...
C5 Corvette wheels
17 in. x 8.5 in., 5 x 4.75 in. Bolt Circle, 7 in. Backspace
18 in. x 9.5 in., 5 x 4.75 in. Bolt Circle, 7.50 in. Backspace
You will need to run 2" spacers on front and 2.25" on the rear
They fit on the 4WD's no problem, But on the 2WD's they may rub at full lock as stated..
Re: will they fit
Thursday, July 01, 2010 2:25 PM
this i know, but i didnt expect him to, so i said go for zq8's since they are like a 10 year newer rim, even though its the same design.. and theres more than one design of wheel that came on zq8 equipped trucks btw
