Same ingenuity that goes into this.
2001 Olds Alero (LD9)
650 whp / 543 ft-lb
@turboalero
I really just don't know what to say.
JGM T-SHIRTS!!!!
That header is sweet lol
Damn they are on to my secrets
Quiklilcav wrote:
I'm sure that guy successfully matched the compression in those cylinders.
easy! grind the piston down, weigh the material that you take out, and do the same with the other pistons and make sure it weighs the same as the first one! done!
Desert Tuners
That header is sweet! I could use that flex tubing to make a turbo header to fit around the gayass auto trans! hah
i love blown ring lands.
PFFT secret cams?! pm me if you want a real upgrade.
couple this with the sand porting , and it will smooth out the piston surface
GOLDEN and SOUND idea in my book , link saved for future use
