Brown Eye wrote:why haven't any of the big auto manufacturers done this yet? the only real downside to an all-electric car is limited range... well, throw a gas-powered generator on board and use it to charge the batteries during extended highway jaunts, and you have the best of everything.It costs a fortune...
OHV notec wrote:Brown Eye wrote:why haven't any of the big auto manufacturers done this yet? the only real downside to an all-electric car is limited range... well, throw a gas-powered generator on board and use it to charge the batteries during extended highway jaunts, and you have the best of everything.It costs a fortune...
Reliability is questionable...
Batteries have numerous problems by themselves...
It's heavy...
Requires more space...
Still, this Volt is coming, so we'll see who follows that.
GAM (The Kilted One) wrote:The Volt uses that kind of a setup.I already said that
GAM (The Kilted One) wrote:Reliability on any new technology is going to be a little questionable. Proofing takes time.An elaboration never hurt anyone I suppose.
GAM (The Kilted One) wrote:The only real problem with LiPo batteries is the propensity for the dielectric to catch fire when it's superheated or under heavy load and expanding. NiMH batteries have a better tolerance to this, but they're a lower energy density... it's a trade-off. The Battery, regenerative brakes and engines (including the recharger) would weigh roughly the same as an IC engine, transmission, brakes and a full tank of gas.I've always wondered about this but never followed through with any research lol. Do they not use mechanical brakes at all? Wouldn't the battery storage have the potential to 'overcharge'?
GAM (The Kilted One) wrote:I seem to remember someone that did an electric engine conversion to a Fiero with lead-acid batteries about 10 years ago, and the electric components weighed about 60 lbs less than the 2.5 Iron Duke, tranny and a full tank of gas.That's nuts, 10 lead-acid batteries would probably weigh 400#+ by themselves (most homemade jobs seem to use about 10).
Quote:To my knowledge, no, and no. About the Volt, I have really no idea, though I would imagine so, there's no reason to waste the kinetic energy to heat unless you absolutely must. There would likely also be a way to halt charging of the unit at X% (I'd figure about 90% of capacity) so that any great amount of braking would just go into the battery to be used as normal, and in any case there would likely be a circuit breaker to stop charging or over charge would flow into a supercapacitor. The braking system can be made into an analog for the regular disc-brakes.
Don't forget that the batteries must be manufactured, and eventually disposed of. This can be a major problem if all the cars suddenly use them...
