The Autopsy Of A Goat - Other Cars Forum
Sunday, April 27, 2008 7:12 PM
a 1968 GTO "Goat" to be exact
started tearing the car apart to get it ready to have the frame fixed and get the engine rebuilt
found some new rust areas and thinking I may just buy new inner fenders
Re: The Autopsy Of A Goat
Sunday, April 27, 2008 8:40 PM
nice green , lmao
frame horn is a easy fix
some nice cancer to fix
Sunday, April 27, 2008 9:02 PM
Ummm yea, i still want those heads
"Project 69'"
1969 Chevrolet C/10, 1/2 ton, 2wd
-Boosted LS1?
-Richmond ROD 6-speed(will get sometime)
-Posi 12-bolt(built w/eaton posi unit and richmond 3.73 gears)
-Disc brake and 5 lug swap
+little extras
Monday, April 28, 2008 6:52 AM
Pretty nice car. I am partial to the 66-67s though. I would get new inner fenders, cost of new vs. labor to fix the ones you have, probably be able to find some nice ones on e-bay for a deal. Get rid of the green paint. Other than that good luck with the re-build. Is it a ram air engine?
KevinP (Stabby McShankyou) wrote:
and I'm NOT a pedo. everyone knows i've got a wheelchair fetish.
Monday, April 28, 2008 7:31 AM
Harrington (Fiber Faber) wrote:Pretty nice car. I am partial to the 66-67s though. I would get new inner fenders, cost of new vs. labor to fix the ones you have, probably be able to find some nice ones on e-bay for a deal. Get rid of the green paint. Other than that good luck with the re-build. Is it a ram air engine?
performance years has them for $150 a side so I was thinking just get those
I wish it was a ram air engine but this is a 73 400 probably out of a bonnieville
Monday, April 28, 2008 9:58 AM
Good call, $150 from PY is a good deal, I would take that route. Since you are taking the engine and dog house off I would completely repaint the firewall and sides of the cowl. Eastwood sells a great kit for under hood items, correct color for the break booster and master cylinder and all that, they also sell a zinc coating paint for all the misc. fasteners and brackets. For $100.00 spent at Eastwood and a few hours time it will add substantial value to the car as a whole. Did you buy the car the way it sits or did you do the work yourself? How good of shape is the rest of the car? Was all the metal work done correctly? Have you had the car VIN ran through Pontiac Historical Services, for like $50.00 they will send you a build sheet with all the options from the factory and tell you what dealer it was send to for sale.
Sorry for the random thoughts, just a huge Poncho fan and love to see these cars taken care of the right way.
Monday, April 28, 2008 12:50 PM
car is pretty much as is when we bought it in 99. changes are hotchkis suspension and coker tires for the rally IIs I have a new core support and a new hood to go in when we start to put it back together.
Monday, April 28, 2008 3:07 PM
Post up the head codes and i can get you some info on that engine. I "scored" a set of 72cc heads at my local junkyard, but they are small valves.
"Project 69'"
-Boosted LS1?
+little extras
Monday, April 28, 2008 3:44 PM
only thing I can make out is a D and a N
Tuesday, April 29, 2008 5:16 AM
"D" and "N" hmmm, they are usually numbers and are located on the top of center exhaust runners. I dont have the website bookmarked here at work, but when i get home i'll look them up. I also have a set of heads to look up from a Catalina i found at the junkyard, i dont have too high of hopes but you never know.
If you need any help with that 400, i have some links at home to some very nice parts. Im also wanting to get rid of my Eldebrock Performer RPM intake mani. I bought it when i "thought" i knew how i wanted my 400 built. It has been installed but never ran.
"Project 69'"
-Boosted LS1?
+little extras
Tuesday, April 29, 2008 5:44 AM
this is the new core support thats waiting to go in
Tuesday, April 29, 2008 2:50 PM
Ok so the heads from that catalina i found are 1.96/1.66(small valves) and 87cc(medium chamber), but the engine is a 455 rated at 360hp. But im not finding a "D" or "N".
"Project 69'"
-Boosted LS1?
+little extras
Wednesday, April 30, 2008 3:29 PM
pulled the driver side fender well off
Thursday, May 01, 2008 4:05 AM
That last batch of pic helps me alot with your head code. "46" is your head code. When i get home i'll get the info on them.
"Project 69'"
-Boosted LS1?
+little extras
Thursday, May 01, 2008 8:06 AM
Tinkles wrote:That last batch of pic helps me alot with your head code. "46" is your head code. When i get home i'll get the info on them.
2.11/1.66 valves
170, 185 hp
98 cc
that what was listed for 1973 Pontiac 46 Heads
Thursday, May 01, 2008 10:22 AM
2.11/1.66 valves
170, 185 hp
98 cc
Eh you took the fun outta it. Those heads are ok, but they need work. 2.11 is the big intake valve, but 1.66 is the small exhaust valve. I would see how much you can mill the heads to bring that 98cc down and see if there is enough room to fit in 1.77 exhaust valves.
Im still looking for a set of 2.11/1.77, 72cc heads. I might end up having to go with a set of aftermarket aluminum heads, if i cant find a set in the junkyard(proboly will be cheaper).
I dunno what all websites you have found for Poncho stuff, but if ya want when i get home i can post the ones i have.
I have been researching these engines on and off for 4-5 years and as soon as my truck is ready for an engine, i'll be building my 400.
Also i do have a set of 1.94(small valve)/1.66, 72cc heads. If you want them. There is not enough clearance to put in bigger valves, so they are not my preffered head.
"Project 69'"
-Boosted LS1?
+little extras
Thursday, May 01, 2008 11:22 AM
well the 69 46 shows
290hp 2.11/1.77
doesnt say the cc
http://www.pontiacpower.net/headcast.html
Thursday, May 01, 2008 11:27 AM
I was frightened when a Geeds thread had the word "goat" in it.
May the border collie RIP.
1989 Z24 Convertible - Dust Covered
2006 tC - Dust Covered, but driven more
Thursday, May 01, 2008 11:32 AM
Thats a different site that i get my info from, and according to your site the heads off that catalina are what i want. I hope that catalina is still at the yard this weekend, so i can yank the heads.
"Project 69'"
-Boosted LS1?
+little extras
Thursday, May 01, 2008 11:45 AM
ZlineDavid wrote:I was frightened when a Geeds thread had the word "goat" in it.
she wasn't a border collie border collies and collies are different
Thursday, May 01, 2008 11:59 AM
She wasn't? Damn, memory is slipping in my old age.
Thursday, May 01, 2008 12:40 PM
ZlineDavid wrote:She wasn't? Damn, memory is slipping in my old age.
nope she was a regular white collie
Thursday, May 01, 2008 3:20 PM
well finished pulling the rest of the front end off
You can see some of the frame damage a bit better and next week the car will go to the shop to get it fixed and aligned right.
Also drivetrain will come out this weekend so I can take the motor to a shop to get rebuilt
Thursday, May 01, 2008 7:04 PM
Here is where i get my head info from. Also there are a few Poncho sites too. Enjoy
Head codes
Goodies
Cranks
Stuff
More cranks
"Project 69'"
-Boosted LS1?
+little extras
Friday, May 02, 2008 5:40 AM
looks good. The frame rail is an easy fix. Car is going to look hot when you get it done. Just don't cut any corners on it. There are a couple of good forums that have alot of good info on them, you might want to check them out.
http://www.pontiaczone.com/forum/index.php
Pontiac Zone is a good place with alot of good people.
http://forums.performanceyears.com/forums/index.php
Pee Why forums are good with alot of good info but I don't realy like some of the people on there, there is alot of forum politics on there.
