Neon disc swap on a beretta? - Other Cars Forum
Friday, February 22, 2008 12:56 AM
I wasn't sure if this should be in the second gen forum, suspension and brake forum, or other cars (seeing as the Beretta is so closely related to the 2nd gen cav in various components, the swap is documented in the S&B forum, and the car isn't a J), so I guessed.
Anyhow, any reason why this wouldn't work? I want to have rear disc brakes so I can get the stopping power of disc brakes (and so I can get the slotted/cross drilled rotors from Baer on the rear), and of course to remove the gheyness of drum brakes. My guess would be I'd have to change some of the machine work on the custom caliper bracket at the very least. The cable length issue may be different as well, due to the different dimensions of the car (iirc the Beretta is a little wider than a J, if it makes a difference).
2010 Honda Fit LX
Re: Neon disc swap on a beretta?
Friday, February 22, 2008 7:13 AM
yes you can Cahill has done the swap
Friday, February 22, 2008 9:32 AM
Is there anything different with the Beretta though in terms of machine work?
2010 Honda Fit LX
