Anyone replaced axle on 99 Escort? Tips? - Other Cars Forum
Thursday, February 14, 2008 2:39 PM
Well a friend of mine got side swiped by someone. The car needs a new fender and front clip as well. She put the car in drive and i could see the axle spinning but the car wont move.
Are there any special tools i need to replace an axle? anyone know how to do it? does the axle just snap in and out or what?
I have a good set of multiple tools such as ratchets and sockets and wrenches, screwdrivers, and what not. is there anything special i need at all? im doing her a favor in replacing it and would like to help out in doing so.
also if someone knows of a driver side fender or front clip around northern IL, let me know.
Re: Anyone replaced axle on 99 Escort? Tips?
Thursday, February 14, 2008 3:44 PM
search ford escort forums on google.Their's a fairly large community such as with the j-bodys,just not quite as large.
Good luck.
Rememeber kids... spell check is your friend
Thursday, February 14, 2008 5:16 PM
k thank you.
Thursday, February 14, 2008 7:16 PM
You basically take off the wheel, loosen the hub nut (easy to do with air tools), unbolt the balljoint(s)/strut (however the front end is set up), remove spindle, and pull the axle out of the tranny. Sounds easy, is actually harder than that, but still fairly straightforward to do.
Thursday, February 14, 2008 8:18 PM
yeah im on that forum, doesnt sound too bad really. i know the axle is broke right at the wheel since i can see it spinning in there.
Thursday, February 14, 2008 8:25 PM
A puller helps ALOT, if not use a prybar, carefully. If there is a seal in there you might as well replace it as well.
Thursday, February 14, 2008 9:22 PM
yeah im getting quite a few pointers over on that site. i just want to help her out and get the car running is all.
Friday, February 15, 2008 7:35 AM
I made a tool to do axles. a long metal pole with a smashed in end. it's curved to fit right next to the axle lttle tap and they pop right out. All to eeasy.
Saturday, February 16, 2008 11:08 PM
if you havent gotton your answer go to www.ERDTonline.com the guys there know everything about 1st, 2nd, and 3rd gen Escorts , i should know cuz im a member of the site
ShowOff Customz
03 Cavalier
73 Beetle
68 Fairlane 500
