Darryn DiSanto wrote:Yes I did forget about that.
He is correct they also have high compression. Hondas are usually 11.0:1.
This can be achieved in the ecotec in two ways. 1. Ask Cometic to make you a mls gasket that is thinner than stock. 2. Go oldschool and have the head shaved by a machine shop.
Darryn
Darryn
CHM wrote:Darryn DiSanto wrote:Yes I did forget about that.
Darryn
The LE5 already has 10.5:1
VTEC
From Wikipedia, the free encyclopedia
Jump to: navigation, search
For the education institution, see Virginia Tech.
VTEC (Variable Valve Timing and Lift Electronic Control) is a valvetrain system developed by Honda to improve the volumetric efficiency of a four-stroke internal combustion engine. This system uses two camshaft profiles and electronically selects between the profiles. This was the first system of its kind. Different types of variable valve timing and lift control systems have also been produced by other manufacturers (MIVEC from Mitsubishi, VVTL-i from Toyota, VarioCam Plus from Porsche, VVL from Nissan, etc). It was invented by Honda R&D engineer Ikuo Kajitani.[1] It can be said that VTEC, the original Honda variable valve control system, originated from REV (Revolution-modulated valve control) introduced on the CBR400 in 1983 known as HYPER VTEC.[2].
VVT
History
Fiat was the first auto manufacturer to patent a functional variable valve timing system which included variable lift. Developed by Giovanni Torazza in the late 1960s, the system used hydraulic pressure to vary the fulcrum of the cam followers (US Patent 3,641,988). The hydraulic pressure changed according to engine speed and intake pressure. The typical opening variation was 37%.
In September 1975, General Motors patented a system intended to vary valve lift. GM was interested in throttling the intake valves in order to reduce emissions. This was done by minimizing the amount of lift at low load to keep the intake velocity higher, thereby atomizing the intake charge. GM encountered problems running at very low lift, and abandoned the project.
Alfa Romeo was the first manufacturer to use a variable valve timing system in production cars (US Patent 4,231,330). The 1980 Alfa Romeo Spider 2.0 L had a mechanical VVT system in SPICA fuel injected cars sold in the USA. Later this was also used in the 1983 Alfetta 2.0 Quadrifoglio Oro models as well as other cars.
Honda's REV motorcycle engine employed on the Japanese market-only Honda CBR400F in 1983 provided a technology base for VTEC.
In 1986, Nissan developed their own form of VVT with the VG30DE(TT) engine for their Mid-4 Concept. Nissan chose to focus their NVCS (Nissan Valve-Timing Control System) mainly at low and medium speed torque production because the vast majority of the time, engine RPMs will not be at extremely high speeds. The NVCS system can produce both a smooth idle, and high amounts of low and medium speed torque. Although it can help a little at the top-end also, the main focus of the system is low and medium range torque production. The VG30DE engine was first used in the 300ZX (Z31) 300ZR model in 1987, this was the first production car to use electronically controlled VVT technology.
The next step was taken in 1989 by Honda with the VTEC system. Honda had started production of a system that gives an engine the ability to operate on two completely different cam profiles, eliminating a major compromise in engine design. One profile designed to operate the valves at low engine speeds provides good road manners, low fuel consumption and low emissions output. The second is a high lift, long duration profile and comes into operation at high engine speeds to provide an increase in power output. The VTEC system was also further developed to provide other functions in engines designed primarily for low fuel consumption. The first VTEC engine Honda produced was the B16A which was installed in the Integra, CRX, and Civic hatchback available in Japan and Europe. In 1991 the Acura/Honda NSX powered by the C30A became the first VTEC equipped vehicle available in the US. VTEC can be considered the first "cam switching" system and is also one of only a few currently in production.
In 1991, Clemson University researchers patented the Clemson Camshaft which was designed to provide continuously variable valve timing independently for both the intake and exhaust valves on a single camshaft assembly. This ability makes it suitable for both pushrod and overhead cam engine applications.[1]
In 1992 BMW introduced the VANOS system. Like the Nissan NVCS system it could provide timing variation for the intake cam in steps (or phases), the VANOS system differed in that it could provide one additional step for a total of three. Then in 1998 the Double Vanos system was introduced which significantly enhances emission management, increases output and torque, and offers better idling quality and fuel economy. Double Vanos was the first system which could provide electronically controlled, continuous timing variation for both the intake and exhaust valves. In 2001 BMW introduced the Valvetronic system. The Valvetronic system is unique in that it can continuously vary intake valve lift, in addition to timing for both the intake and exhaust valves. The precise control the system has over the intake valves allows for the intake charge to be controlled entirely by the intake valves, eliminating the need for a throttle valve and greatly reducing pumping loss. The reduction of pumping loss accounts for more than a 10% increase in power output and fuel economy.
Ford became the first manufacturer to use variable valve timing in a pickup-truck, with the top-selling Ford F-series in the 2004 model year. The engine used was the 5.4L 3-valve Triton.
In 2005 General Motors offered the first Variable Valve timing system for I-head V6 engines, LZE and LZ4.
In 2007 DaimlerChrysler became the first manufacturer to produce a cam-in-block engine with independent control of exhaust cam timing relative to the intake. The 2008 Dodge Viper uses Mechadyne's concentric camshaft assembly to help boost power output to 600 Bhp.
oldskool wrote:CHM wrote:Darryn DiSanto wrote:Yes I did forget about that.
Darryn
You beat me too it. I figured it had to be a combination of things, not just compression or just VVT. Maybe GM's most aggressive profile is still pretty wimpy?
Wouldnt going thinner than stock HG net only a very small increase in CR? I mean, you can see the difference between say a 9:1 piston vs a 12:1 piston for a given engine. I would think you would have to go with thinner HG and shave the head significantly to get any appriciable gain in CR.
Brian Whalen wrote:The largest difference between a normal 4 cylinder and a B-series or K20A, is VTEC.
The Vtec camshafts use 3 lobes per cylinder. Each camshaft serves as having two completely different cams in one engine. The two outer lobes are a mild profile used for normal driving, and the middle camshaft profile is essentially a "race only" cam profile (much higher lift than anyone here uses). At a certain rpm, a solenoid is switched that uses oil pressure to lock this bar that no longer allows the smaller lobes to open the valves, and the engine runs purely on the "race cam" profile. That is why Hondas can make some of the highest NA 4 cyl horsepower and rev to the skys while still remaining streetable. If other manufacturers were allowed to adopt this technology, a Honda wouldn't be anything special...But Honda has a patent on this, so only they can use it.
Darryn
The correct way to raise compression in a OHC engine is by changing the piston shape. Otherwise, you will lead to problems with skipping timing. On an OHV engine it's fine because all of the timing components are below the head.
EDIT: And VTEC isn't VVT. VVT involves changin the timing of the cams. VVT usually retards the cams through oil pressure to allow more top end horsepower. However, I believe the new i-VTEC motors do both VTEC and VVT.
Darkstars wrote:Vtec is over rated, Vanos FTW
JoeyDaBomb wrote:Vtec is the best when you use Hondata's reflash and lower it to 5kRPM so you use it more often
whitegoose( RedR-ZedR) wrote:JoeyDaBomb wrote:Vtec is the best when you use Hondata's reflash and lower it to 5kRPM so you use it more often
thats generally because you have done other modifications to it already, like making it breath better. without modifications like thay, it wont see as much of a benefit by lowering it that 1000 rpm.
