Hyundai Concept Genesis Coupe - Other Cars Forum
Wednesday, November 14, 2007 4:42 PM
Dave Premium Member Online
HYUNDAI UNVEILS REAR-WHEEL DRIVE CONCEPT GENESIS COUPE
http://www.autoblog.com/photos/hyundai-concept-genesis-coupe-3/
LOS ANGELES, Nov. 14, 2007 – Hyundai unveiled its highly anticipated Concept Genesis Coupe during a press conference at the Los Angeles International Auto Show today. The concept car heralds the introduction of an all-new, rear-wheel drive 2 + 2 sports coupe scheduled to join the Hyundai lineup in the spring of 2009. Following the introduction earlier this year of the Concept Genesis sedan, Concept Genesis Coupe signals Hyundai's second step in broadening its appeal to driving enthusiasts.
The Sonic Orange concept is complemented by a Ballistic Black carbon fiber hood, roof and ground effects for reduced weight. Strong hints of the production version are highlighted in its "Z" bodylines and powerful curves. When the production sports coupe arrives, it likely will be the most affordable 300+ horsepower car on the market, and the most dynamic performance car yet from Hyundai.
"Concept Genesis Coupe is the most thrilling, most emotional Hyundai yet," said John Krafcik, vice president, product development and strategic planning, Hyundai Motor America. "When it hits the market in early 2009, we aim to deliver a driving experience that challenges cars like Infiniti G37, at prices more like Mitsubishi Eclipse."
DESIGN PROCESS
"The mission for Concept Genesis Coupe was to create a pure performance car with a design that would capture the imagination of hardcore automotive enthusiasts," said Joel Piaskowski, chief designer at the Hyundai Design Center in Irvine, Calif. "With its aggressive look from just about any angle, I think we have been able to do that."
The powerful curves, surface detail and "Z" bodyside lines come straight from the same underlying inspiration that guided two earlier, well-received concepts: the HCD9 Talus and the HCD8 sports tourer. The undulating beltline borrowed from the Talus adds intrigue while enhancing outward visibility for both the driver and rear passengers. The HCD8 sports tourer's sensual body forms influenced the overall design theme while also providing direction for the concept's assertive headlight and taillight designs.
The look of Concept Genesis Coupe was in part inspired by LeMan's race cars, drifters and by Jada Toys Dub City™ die cast vehicles. The front and rear stance of the Concept Genesis Coupe can be described as sinister.
"Beauty and danger co-exist in the design of the Concept Genesis Coupe," said Eric Stoddard, senior creative designer. "When viewed from a distance, the car is beautiful to look at. But up close it can appear a bit menacing and even a little intimidating."
The concept's rocker panels are drawn close to the ground making the bodysides extra thick and the daylight opening extremely thin, allowing the wheels to be slammed up into bulging fenders. To complete the aggressive sports car look, the depth between the fenders and the greenhouse has been maximized.
Three large heat extractors sculpted into the hood are designed to cool just about any powerful engine. When the concept becomes reality, three large openings in the front fascia will allow for better engine breathing. The dual exhaust tips integrated into the rear fascia repeat the design theme of the front cooling ducts and are surrounded by a large carbon fiber air diffuser.
An arching roofline and tapering greenhouse highlight the exterior profile and emphasize the car's broad shoulders and wide stance. Concept Genesis Coupe rides on 20-inch polished aluminum deep-dish wheels with Hankook 255/35 ZR front tires and 275/35 ZR rear tires.
CONCEPT GENESIS COUPE SPECIFICATIONS
· Configuration: Front engine, rear-wheel drive sports coupe
· Wheelbase: 2,820 mm / 111 inches
· Overall length: 4,666 mm / 183.7 inches
· Overall width: 1,902 mm / 74.9 inches
· Overall height: 1,386 mm / 54.5 inches
· Wheels: 20-inch, five-spoke
· Tires: Hankook 255/35 ZR front and 275/35 ZR rear
PRELIMINARY PRODUCTION CAR DETAILS
· Engine type: V6
· Estimated horsepower: more than 300 horsepower
· Estimated torque: more than 250 lb. ft.
· Displacement: 3.8 liters
· Block material: high pressure die cast aluminum
· Cylinder head material: aluminum
· Valvetrain: Dual Over Head Cam (DOHC)
· Valve timing: continuous variable valve timing
· Estimated 0-60 mph: under 6 seconds
· Transmission type: 6-speed manual
· Front brakes: Brembo, 340 mm disc, twin-piston calipers
· Rear brakes: Brembo, 330 mm disc, twin-piston calipers
· Limited slip differential
Edited 1 time(s). Last edited Wednesday, November 14, 2007 4:44 PM
Re: Hyundai Concept Genesis Coupe
Wednesday, November 14, 2007 6:25 PM
If that's the next Tiburon...then they just blew it. It needs to look like this....
or forget it.
that rear quarter window is retarded and totally doesn't flow with the car. It gives it a cartoonish look. As a stand alone model...which it sounds like what they are saying. It's a decent car....but i love that Tiby design above and hope they are 2 seperate models.
Wednesday, November 14, 2007 6:30 PM
i would buy that car instantly
Wednesday, November 14, 2007 8:23 PM
They say it is a completely different car then the Tiburon. The Tibby will remain a FWD car, this is a RWD vehicle.
5:32 PM: They admit enthusiastic car buffs don't usually look at Hyundai, save for a few Tiburon owners.
5:34 PM: CONFIRMED: Front-wheel-drive Tiburon replacement and rear-wheel-drive coupe are two different vehicles.
5:35 PM: Showing video of RWD test mule all covered up being thrashed on the road. Now it's being chased by a photographer on a motorcycle. We're so confused here.
5:36 PM: The sheet's pulled off. Pics are on their way, but we can tell you the vehicle is very tuner-oriented. Called the Concept Genesis Coupe. Bright orange paint and vented carbon fiber hood pop. Dropping beltline behind doors is a signature design feature, helps rear passenger see out. Carbon fiber-tipped spoiler sits out back while the front is capped by a carbon fiber fascia.
5:38 PM: Engines will be a turbo four-cylinder and the 3.8L V6 from the Genesis sedan with over 300 HP. Brembo brakes and an LSD will be offered.
5:42 PM: Hyundai reportedly used the BMW E46 M3 as a benchmark!
5:39 PM: Production version will be shown at New York Auto Show in late March.
Wednesday, November 14, 2007 9:58 PM
Yup. I'm in love.
-John
Wednesday, November 14, 2007 10:01 PM
I hate to say it... but I'd drive it.
Desert Tuners
Wednesday, November 14, 2007 10:49 PM
id pimp it on rodeo drive
Thursday, November 15, 2007 7:33 AM
my parents have a sonata 3.3L right now. @!#$s not that bad.
and that genesis may have just made me want to roll in a hyundai. that would be a sweet ass DD and then i could take the cav off the road.
it looks nothing like the original concept, and i like that. as for the rear window... no car is perfect, get it and get on with it.
haha
Thursday, November 15, 2007 8:14 AM
Hmmm. I can't really decide whether I like this more than the HCD8 concept they had a few years ago.. Are there any interior pics?
"Youth in Asia"...I don't see anything wrong with that.
Thursday, November 15, 2007 10:22 AM
Mmmmm.. I want one lol
Thursday, November 15, 2007 10:43 AM
Id rock it
Thursday, November 15, 2007 2:13 PM
The concept version is awesome! Can't wait to see the production version with the 15" wheels and 3 inch wheel gap.
Thursday, November 15, 2007 5:11 PM
i could be down for that.....after i get my LS2 solstice, of course
Friday, November 16, 2007 8:00 AM
and some of the competition
Friday, November 16, 2007 9:06 AM
Man that thing looks awesome, makes that mustang look like a joke.
Friday, November 16, 2007 11:30 AM
looks like it has a longer wheelbase than the tiburon
Friday, November 16, 2007 12:00 PM
wow i like it. whats the sticker price?
12.5@116 2.0 60ft
Friday, November 16, 2007 2:09 PM
whoops...looks like a leaked photo. that's cool. I like how they tried to put up a covering around the area and someone was still smart enough to climb up and snap a few off anyway. Well the production picture is a lot clearer and I can say now that the rear quarter window is not as bad as it appeared. I love this car, it has a baby 6-Series coupe look.
Friday, November 16, 2007 8:20 PM
That silver one looks very nice actually, kinda has some G37 styling cues in it. I'd say another step in the right direction for Hyundai.
-- John
Saturday, November 17, 2007 9:33 AM
i believe the silver non mustang is the altima coupe. my little brother is on the list at our dealership to get one.
badass looking cars.
GO PATS!!!
Saturday, November 17, 2007 10:07 AM
altima coupe?
im pretty sure nissan wouldnt let that happen
Saturday, November 17, 2007 2:15 PM
The Redneck wrote:i believe the silver non mustang is the altima coupe. my little brother is on the list at our dealership to get one.
I'm seeing an Eclipse and a Civic, no Altima there.
-- John
Saturday, November 17, 2007 2:22 PM
indibluemini3 (aka navycav3) wrote:altima coupe?
They are already Made!
Sunday, November 18, 2007 1:48 AM
ok i think we are mixed up here
the silver coupe above is a hyundai, not a nissan, and it is not a hyundai altima, because that would be infringment or copyrights
Monday, November 19, 2007 11:27 PM
Now they just need to come out with a production high powered 4 cyl turbo AWD version of th Elantra. It'd be great to be the next to give consumers a choice other than an STI or EVO. Sure, I don't expect QUITE the same caliber as those two, but Hyundai could so pull it off.
-John
