will a 5x114 wheel fit on a car that takes 5x115 since the numbers are so close? Please forgive my ignorance
i would assume not....since thats the distance between the lugs....the holes on the wheels wont match up
yes and no , if the hub of the rim clears , then it will sit flat on the drum/rotor
you will be able to lugs on and tight , but they wont seat right in the wheels , if you can find the lug nuts with the loose seat its the best way to go
its common for people to use the ford 4 1/2" pattern on the GM 5x115
alot of people will tell you to never do it , and alot will say they have never had any issues
expect to get broken studs from time to time , and keep a weekly check on the lugs to make sure they stay tight
Take your wheel off. Try and see if it fits.
ASE Certified Techician
DaimlerChrysler Certified Techician
Va Safety Inspector
Member Option D Racing
just get the right size rims, its easier.
GO PATS!!!
well the issue is that the stellies that are on it right now are rusting and i have the alloy wheels from my maxima but gm=5x115 and nissan=5x114 thats why im asking
It may work. Try it out.
Keep in mind, though, that even though the bolt patterns may be close, the backspacing and other dimensions of the wheel might not match up accurately. If that happens, you may have problems fitting around brake calipers, etc.
Best thing to do is to go ahead and try.
-John
People have been arguing about this for ages:
Most people say that a 5x114.3 lug pattern is actually the same as the 5x115
Some say they won't.
[ o ][][][][][][][][ o ] coach built xj ( o   [][][][][][][]/  o ) hid wj
In my experience, the 5x114.3 is so damn close to the 5x115 that it's a toss up as to whether or not it'll work for you personally, just try it and see.
whoever said wrong hub size u win 5 points. it was a no go
there are wheel shops that can have the center hole machined out larger , i was gonna have a set of wheels done it was 200.00 for the 4 wheels
also the tires have to be off the wheels
