dodge daytona turbo - Other Cars Forum
dodge daytona turbo
Saturday, September 15, 2007 6:16 PM
Ok, so my friend has a dodge daytona turbo, with an auto trans. and we were both wondering, when he hits the gas like hard, like flooring it, the transmission drops into neutral, he'll push the pedal alot, then he said after he pushes so far, it kind of pops and goes all the way, then thats when the trans. drops to neutral, anyone know what this is?? any help is appriciated, thanks
"Hondas are like tampons, every pussy has one!!!"
Re: dodge daytona turbo
Saturday, September 15, 2007 8:11 PM
I'm gonna say...I don't know. I had the same problem with my '93 Daytona Iroc with the 3.0 V6 and we just gave up on it. It'd go fine for awhile then drop to neutral or shift down to second gear. You might check the connections on the wiring harness that plugs into the transmission but other than that I don't know.
* Student of the University of Oklahoma. Go Sooners!
Sunday, September 16, 2007 12:15 AM
sounds like he is just having a really bad slip. I would have to drive it my self to determine the cause
if he has to re-shift into d to get it to go again me thinks valvebody issue
when you beat someone in a civic people wine and make excuses
when you beat someone in a cavalier they pull over and check under thier hoods
Sunday, September 16, 2007 1:55 PM
Being a Daytona Turbo automatic, I'm assuming it has the stock 3-speed auto in it, correct??? Anyways, those old 3-speeds have virtually no electronics on them whatsoever. Yeah, they have the P/N switch, the VSS on the axle extension housing, and maybe a tranny temperature switch, but there is nothing electrical there that controls shifting.
I suggest doing a tranny flush, filter, and refill, and while you are in there, adjust the clutch bands. There are two adjustments, one on the outside of the transmission, and one inside the tranny that you can access once you remove the filter and get the parking rod out of the way. It's simple enough to do and it might be a nice cheap fix. In the worst case scenario, you might be out maybe $25 and a couple hours of labor, I'd still consider it worth a shot if another tranny is your only option. Also when you pull the pan off, if you see chunks of clutch band material in the pan, save yourself the time and money and go ahead and start looking for a replacement tranny.
