From GM... .
GM Plans First Light Duty V-8 Clean Diesel for North America
-High-efficiency V-8 scheduled for pickup trucks under 8,600 pounds Gross Vehicle Weight and HUMMER H2
-Low emissions, high performance and excellent fuel economy
-Expected to deliver class-leading torque, power and refinement
-Manufactured at the GM Powertrain Tonawanda engine plant
TONAWANDA, N.Y. – General Motors Corp. will introduce a new, state-of-the-art 4.5L V-8 Duramax turbo-diesel that improves engine fuel efficiency by 25 percent, reduces CO2 emissions by 13 percent and cuts particulates and NOx emissions by at least 90 percent for North American light duty trucks and the HUMMER H2 built after 2009.
The premium V-8 diesel is expected to deliver class-leading torque, power and refinement while maintaining a significant fuel efficiency advantage over comparable-output gasoline engines.
The new dual-overhead cam, four-valve V-8 diesel engine will fit within the same space of a small-block V-8 gasoline engine. This compact size is made possible by using integral cylinder head exhaust manifolds, integral cam cover intake manifolds and a narrow block.
“This new GM light duty diesel is expected to become a favorite among customers who require excellent towing ability and fuel efficiency,” said Tom Stephens, group vice president, GM Global Powertrain and Quality. “It will meet the stringent 2010 emissions standards, and it will be compliant in all 50 states, making it one of the cleanest diesel vehicles ever produced.”
Environmental benefits of the new engine include a 13-percent reduction in CO2 versus gasoline engines, and at least a 90-percent reduction in particulates and NOx compared to diesel vehicles today. This will be GM’s first engine to use a selective catalytic reduction NOx aftertreatment system with a diesel particulate filter to help achieve the Tier 2 Bin 5 and LEV 2 emissions standards.
Technical highlights of the engine include aluminum cylinder heads with integrated manifolding; a variable-vane turbocharger with intercooling; a Compacted Graphite Iron (CGI) block for a stronger and lighter engine base (compared to lower-strength aluminum or heavier grey cast iron); and fracture-split main bearing caps and connecting rods for a precise fit. An electronically controlled, ultra-high-pressure, common-rail fuel system is used, which has the ability to inject fuel five times per combustion event to control noise and emissions.
“This new V-8 is not only a clean diesel meeting the toughest emissions requirements in North America, it also delivers an effortless performance feel because of its high torque across the speed range,” said Charlie Freese, executive director of GM Powertrain Diesel Engineering. “It is also significantly quieter than other diesels on the road today, with noise and vibration performance approaching gasoline V-8 levels.”
Freese said the new V-8’s compact size enables it to fit in the envelope of a gasoline small-block engine, which provides GM the flexibility to introduce this engine in a wide variety of vehicle applications should there be future market demand.
The premium V-8 diesel engine is expected to deliver class-leading refinement, horsepower and torque and fulfill multiple vehicle applications with ratings in excess of 310 horsepower and 520 lb-ft of torque.
GM (Opel, Saab, Vauxhall and GMDAT ) currently offers 17 diesel engine variants in 45 vehicle lines around the world. GM sells more than one million diesel engines annually, with products that offer a range of choices from the 1.3L four-cylinder diesel engine sold in the Opel Agila and Corsa, up to the 6.6L V-8 Duramax diesel sold in full-size vans, heavy duty pickups and medium duty trucks in the U.S.
GM first introduced the Duramax diesel 6.6L V-8 in the U.S. in the 2001 model year and since then, customer enthusiasm for this heavy duty diesel has been outstanding. In fact, GM’s heavy duty pickup truck market share has jumped nearly tenfold in the six years that Duramax engines have been offered.
>>>For Sale? Clicky!<<<
And on related news.
From GM... .
GM To Invest $100 Million In New York Plant For Diesel Engine Production
TONAWANDA , N.Y. – General Motors Corp. will invest $100 million in its Tonawanda engine plant to produce an all-new, 4.5-liter V-8 Duramax high-output diesel engine for the Chevrolet Silverado and GMC Sierra light-duty pickup trucks and the HUMMER H2. The engine fuel efficiency improves by 25 percent when compared with gasoline engines. Environmental benefits of the new engine include a 13-percent reduction in CO2 versus gasoline engines, and at least a 90-percent reduction in particulates and NOx when compared to diesel vehicles today.
The investment includes a 200,000-square-foot facility renovation, new machinery, equipment and special tooling to bring diesel engine technology to New York. In addition to the $100 million facility investment, GM will invest an additional $41 million for vendor tooling, containers and investments at other locations necessary to support the Tonawanda operations. Construction is slated to begin later this year and production of the 4.5-liter V-8 diesel engine is scheduled to begin in the fourth quarter of 2009. The project will retain about 150 hourly jobs.
“GM is transforming its product portfolio to reduce fuel consumption and emissions, and the 4.5-liter V-8 diesel is an integral part of that transformation, as well as a component of GM’s strategy to diversify vehicle energy sources,” said John Buttermore, GM Powertrain vice president of global manufacturing. “This will be one of the most efficient and technically-
advanced diesel engines, providing a 25 percent improvement in fuel efficiency and 13 percent reduction in CO2 emissions over gasoline engines in this segment – and it does all that while still providing the performance attributes required by customers in the areas of towing and hauling loads.”
The investment announced today is in addition to a $300 million investment GM announced in January for production of an all-new, DOHC V-8 engine to power GM’s luxury cars and SUVs. Production of that engine also begins in 2009.
“GM’s investment in the Tonawanda plant, totaling $1.6 billion in the last 10 years, is a significant vote of confidence in our employees and UAW Local 774, who have demonstrated their commitment and dedication to benchmark performance that is contributing to the company’s turnaround,” Buttermore said.
The GM Powertrain Tonawanda plant management and UAW Local 774 leadership successfully negotiated a competitive operating agreement that improves operational effectiveness. The agreement also addresses processes and methods that improve production quality, efficiency and safety of the operations.
Buttermore also thanked New York ’s leaders on the federal, state, county and local levels, including New York Governor Eliot Spitzer, Erie County Executive Joel Giambra and Tonawanda Supervisor Ron Moline, for providing the business case to support GM’s investments in New York.
“General Motors has been part of the fabric of the Western New York economy for almost 70 years,” said Governor Spitzer. “The company’s expanded investment in its Tonawanda plant is a testament to the area’s highly skilled, highly motivated workforce and the role that manufacturing will continue to play in the revival of Upstate New York.”
The 4.5-liter V-8 Duramax high-output diesel engine will be GM’s first engine to use a selective catalytic reduction NOx after-treatment system with a diesel particulate filter to help achieve the Tier 2 Bin 5 and LEV 2 emissions standards. It will be compliant in all 50 states, making it one of the cleanest diesels ever produced. It is expected to deliver class-leading power and torque, and fulfill multiple vehicle applications with ratings in excess of 310 horsepower and 520 lb.-ft. of torque.
GM Powertrain’s Tonawanda engine plant opened in 1938 and has produced nearly 68 million engines. The plant covers 3.1 million square feet and employs 1,565 hourly and 260 salaried employees, with an annual payroll of $200 million. Currently, the Tonawanda engine plant builds the 2.2-liter Ecotec engine that powers the Chevrolet Cobalt and HHR; the Inline 4- and 5-cylinder engines that power the Chevrolet Colorado and GMC Canyon mid-size pickups and the HUMMER H3 SUV; the 3.5- and 3.9-liter high value V-6 engines for the Pontiac G6 and the Chevrolet Malibu and Impala; and the 8.1-liter big block V-8 engine that powers Chevrolet Kodiak and GMC TopKick medium-duty trucks – as well as marine and industrial applications.
and they said it couldnt be done, ha
prime example of what GM can do , when they want to, its too bad the government has to be the one to force innovation
I don't think its a matter of innovation, I think it's a matter of getting the car manufacturers asses into gear.
VW's had diesels for ages, there's not one reason GM can't in North America... only excuses.
Diesel's make less greenhouse gasses and, when used with low sulfur fuel, less air pollution. PLUS they go further and make a million tons of torque, which is what most American drivers like in their cars. That Oooooooooooomphhhhh!!! feeling when you press the gas, not the high-revving/top speed horsepower. It'll never be exactly the same as a gas engine, but it's not as big of a pain in the butt as a hybrid either.
In my opinion ALL trucks/SUV's/vans and Hybrids should be diesel along with most large cars.
Im pretty pumped there building it near by...its in the plant my uncle manages...hopefully it means more jobs for people around there
Hopefully it won't be a $6000 option like the Duramax
Update...
General Motors has made yet another tough call as it continues its efforts to dig itself out of the monstrous financial hole it finds itself in, this time announcing that it is indefinitely delaying the launch of its highly anticipated 4.5L Duramax turbodiesel engine for its light-duty trucks.
"We have to make tough decisions right now," says GM Powertrain spokeswoman Susan Garavaglia. A possible option for GM may be to sell the engine design to another company, Garavaglia added. The engine is reportedly far along in development and the automaker had previously announced plans to invest $100 million in its Tonawanda, New York, engine plant where it had planned to built it.
GM truck and diesel fans alike have been eagerly awaiting the arrival of the engine, which has been lauded as an innovative design. It was slated to become an option for its Chevrolet Silverado and GMC Sierra pickups.
The engine's relatively compact design features integral aluminum cylinder head exhaust manifolds, integral cam cover intake manifolds, and a narrow V-angle block. As a result, the engine can reportedly fit in the same space as a small-block V-8 gas engine.
The 4.5-liter diesel was expected to meet LEV2 emissions standards and was supposed to be sellable in all 50 states. Producing 310 horsepower and 520 lb-ft of torque, GM says the engine is designed to achieve fuel efficiency 25 percent better than comparable gas engines and is the first GM engine to employ a selective catalytic reduction NOx after-treatment system with a diesel particulate filter. GM says the new engine reduces CO2 emissions by 13 percent as well as a 90 percent reduction in particulates and NOx.
The cash-strapped automaker says it will continue to offer its 6.6L Duramax engine for its heavy-duty pickups, and that it will continue to modify it to meet future diesel standards. But that's little consolation to the thousands of diesel fans who were expecting the new 4.5L engine.
What do they consider excellent fuel economy? Unless I missed something, there were no concrete numbers there. Is this going to be a 40mpg truck engine or something? Otherwise how impressive can it be? Diesel is not new.....
Delayed is better than canceled.
booooo this was actually exciting stuff!
__________________________________________________________________
Where I work:
HP
What I take for Memory and Focus:
Focus Fast
guys guys guys... remember we are talking about GM here... so dont hold your breath!! lol
i think it'll be nice to have out there, as long as its not a 6000 addition like mentioned above
4.5L? That's pretty small for an american V8. Not nagging, it's a good thing. It can be a smaller engine and still have big torque numbers. If the fuel economy is that good, I could even see a use for that in Cadillacs and Impalas. Just imagine an Impala going to the strip with one of those under the hood.
2010 Honda Fit LX
i will definitely be looking into buying one of these...any word on pricing?
Cart My Snot wrote:4.5L? That's pretty small for an american V8. Not nagging, it's a good thing. It can be a smaller engine and still have big torque numbers. If the fuel economy is that good, I could even see a use for that in Cadillacs and Impalas. Just imagine an Impala going to the strip with one of those under the hood.
but for a DIESEL in a mid sized truck thats not bad at all. turbo diesels are alot more efficient than thier gasoline counterparts
I had to get rid of my little asian girl spinning her finger. I am now sad. she was cute; but now I have to find someone of proper bit size :-(
http://www.myspace.com/yourfavoriteprofile
