need a little help - Other Cars Forum
need a little help
Wednesday, January 31, 2007 1:13 PM
so i hope everyone doesnt hate me for this BUT i recently had to get rid of my 98 Z b/c i was having a baby... so i picked up a 99 Jetta wolfsburg. Nice car.. i like it but only ONE thing wrong! everytime i come to a stop i lose all heat! It has plenty on heat while moving but as soon as i stop its blows cold air! any ideas? i'm thinking heater core... but god i hope not! Thanks guys!
Re: need a little help
Wednesday, January 31, 2007 3:02 PM
Does the blower motor still work when you are stopped, or does the blower stop spinning?
If it goes cold and still blows, it could be blockage in the header(or return) line, or heater core. It could also be something with your water pump. Maybe it is seizing up and not pumping at idle, but moves at higher rpms?
Let your car idle, and
check if it's pumping coolant. If it is, it's probably blockage in the line.
Also, double check your coolant, and make sure it's full in the rad and resivour tank when cold. (don't open the rad when it's warm/hot.)
Wednesday, January 31, 2007 4:20 PM
the blower motor runs when i'm at idle, i just lose all heat! How would i check to see if the water pump is working at idle? I just bought the car and the guy said he had a new thermostat put in it. when i picked it up on the way home the coolant light came on... i filled it back up.... i dont know if its leaking or if they filled it once and didnt refill it after the thermostat opened for the first time. Not really sure... i guess i need to check under the car in the AM when i leave
Wednesday, January 31, 2007 4:58 PM
Could be a leak, and it's low on coolant.
I've seen afew waterpumps sieze at low rpms, but work properly at higher rpms. Could be that. Does the car overheat if you let it idle?
Thursday, February 01, 2007 2:07 PM
i'm thinking a leak somewhere... i'm gonna try to get it in my friends shop this weekend to look at it better. It doesnt overheat at all.... and i sit in alot of afternoon rush hour traffic
Thursday, February 01, 2007 3:05 PM
You said you had to put coolant back in it. Did you check the coolant level again? You might of had an air pocket and coolant level dropped. Thats what it sounds like to me.
Thursday, February 01, 2007 4:38 PM
i checked it today when i got home from work... but it was hot. still seemed a lil low.... i'm gonna check it tomorrow on my break at work whens it cooled down.
Thursday, February 01, 2007 4:57 PM
im buddy had a jetta and all he had was problems. That thing was in the shop every other week.
