'08 CTS - Other Cars Forum
'08 CTS
Sunday, January 07, 2007 11:28 PM
Link w/pics
The 2008 CTS continues as Cadillac's entry-level rear-wheel drive sedan, but is two inches wider to accommodate an optional all-wheel drive system - a first for the mid-size Caddy.
The new CTS rides on the same 113-inch wheelbase of the outgoing model, but is larger in all other dimensions. Last year's base 2.8-liter V-6 has been dropped for North America, with the 258-hp, 3.6-liter variable-valve-timing unit now serving as the base engine. An optional direct-injection version of that engine develops 300 horsepower with reduced emissions and improved fuel economy. All 2008 CTSes have six-speed transmissions, automatic or manual.
All-wheel drive models receive an active transfer case, and a limited slip differential is available. All 2008 CTS models have a strut-tower brace like that used in last year's CTS-V, as well as revised suspension, brakes, and steering.
The new CTS features full iPod integration, with USB and auxiliary input jacks located in the center console. Options will include swiveling headlights, Easy Key keyless-go with remote start, a Bose surround system, and DVD-based navigation.
The CTS now also gets the hand-stitched leather treatment familiar in the CTS-V, STS-V, and SRX, replete with French stitching. Seventeen-inch wheels are standard, eighteens optional, and we look forward to getting behind the steering wheel of Cadillac's new import fighter sometime next summer.
Re: '08 CTS
Sunday, January 07, 2007 11:47 PM
Much hotness.
they totally ironed out all the bad wrinkles and smoothed it out. Easily the best looking Caddy to date.
Re: '08 CTS
Monday, January 08, 2007 3:21 AM
amazing....that front end is just......menacing...
Re: '08 CTS
Monday, January 08, 2007 3:56 AM
that ain't half. 100x better looking than the current 3 series.
[ o ][][][][][][][][ o ] coach built xj/ wip wj
Re: '08 CTS
Monday, January 08, 2007 4:03 AM
much better than the current CTS, and i love the current CTS.
<~~~~PWN3D!!
Re: '08 CTS
Monday, January 08, 2007 6:19 AM
DAMN!
sexy as hell
Re: '08 CTS
Monday, January 08, 2007 6:58 AM
damn i want this
Re: '08 CTS
Monday, January 08, 2007 9:09 AM
I met Jim Taylor at the Escalade intro last year and upon speaking to him, i've notice that the guy knows and love Cadillac and seriously that is what we need. Because what Cadillac has been coming out is superb. And the trend continues.
Gorgeous, hi-tech, and runs on regular gas too!
Intro Video
>>>For Sale? Clicky!<<<
Re: '08 CTS
Monday, January 08, 2007 9:20 AM
So?
dumb question...
How much of this is shared with the FWD 2008 Malibu? They look alot like they are related. Are they? Or is it just they "look" related?
Re: '08 CTS
Monday, January 08, 2007 9:53 AM
CTS is RWD
Re: '08 CTS
Monday, January 08, 2007 12:18 PM
Jookycola wrote:So?
dumb question...
How?? I can' find any angle where they look at all similar.
Will the AWD be available with the manual trans?? That'd be sweet.
Re: '08 CTS
Monday, January 08, 2007 2:33 PM
thats areal nice looking caddy.
Re: '08 CTS
Monday, January 08, 2007 4:33 PM
i'm excited..
i cant wait to see what a black v series looks like...
** FOR SALE** http://www.j-body.org/forums/read.php?f=24&i=110879&t=110879
Re: '08 CTS
Monday, January 08, 2007 6:48 PM
hmmmm....i think those lines are a little bit to exagerated for my taste. Still a sick car though.
"Custom cars, custom problems."-me
Re: '08 CTS
Monday, January 08, 2007 9:06 PM
Jookycola wrote:So?
dumb question...
The engine (3.6L) and the fact they are GM made.
But like others have said, the CTS is RWD/AWD on the Sigma-2 platform.
While the Malibu is on the FWD architecture named Epsilon-2.
Re: '08 CTS
Monday, January 08, 2007 9:30 PM
Oh and here is the specs from GM.
2008 CADILLAC CTS SPECIFICATIONS
Overview
Model:
2008 Cadillac CTS
Body style / driveline:
4-door sport luxury sedan, RWD or AWD
Construction:
unitized welded steel body with direct-mounted front cradle and rubber-isolated, multi-link independent rear suspension
EPA vehicle class:
midsize car
Manufacturing location:
Lansing Grand River Assembly, Lansing, Mich.
Engines
2.8L VVT V-6
(RWD export models only)
3.6L VVT V-6
3.6L direct injection VVT V-6
Type:
2.8L V-6 VVT (variable valve timing) with port fuel injection
3.6L V-6 VVT (variable valve timing) with port fuel injection
3.6L V-6 VVT (variable valve timing) with spark-ignition, direct injection
Displacement (cu in / cc):
170 / 2792
217 / 3564
217 / 3564
Bore & stroke (in / mm):
3.5 x 2.94 / 89 x 74.8
3.7 x 3.37 / 94 x 85.6
Block material:
sand-cast aluminum with cast-in bore liners
Cylinder head material:
cast aluminum
cast aluminum
cast aluminum
Valvetrain:
DOHC, 4 valves per cylinder, variable valve timing (VVT)
Fuel delivery:
returnless sequential fuel injection
direct high-pressure fuel injection
Compression ratio:
10.0:1
10.2:1
11.4:1
Horsepower (hp / kw @ rpm):
210 / 156 @ 6500 rpm
258 / 192 @ 6200 rpm
300 / 223 @ 6700 rpm (est)
Torque (lb-ft / Nm @ rpm):
194 / 263 @ 3200 rpm
252 / 342 @ 3100 rpm
270 / 366 @ 4000 rpm (est)
Recommended fuel:
unleaded regular
unleaded regular
unleaded regular
Maximum engine speed (rpm):
7000 w / automatic trans.
7200 w / manual trans.
TBD w / automatic trans.
TBD w / manual trans.
Estimated fuel economy (mpg city / hwy / combined):
TBD
TBD
TBD
Transmissions
Aisin AY6
Hydra-Matic 6L50
Type:
Fully synchronized 6-speed manual with single overdrive
6-speed, RWD/AWD, electronically controlled, automatic overdrive with torque converter clutch
Gear ratios (:1):
First:
4.15
4.02
Second:
2.33
2.36
Third:
1.53
1.53
Fourth:
1.15
1.15
Fifth:
1.00
0.85
Sixth:
0.79
0.67
Reverse:
3.67
-3.06
Final drive ratio:
2.8L:
3.6L:
3.73
3.42
3.42
Chassis / Suspension
standard equipment
optional equipment
Drive configuration:
RWD or AWD
RWD or AWD
Front suspension:
independent SLA
independent SLA
Rear suspension:
independent multilink
Wheels:
17- x 8-inch;
alloy, 5-lug
18- x 8.5-inch;
alloy, 5-lug
Tires:
P235/55R17
Michelin H-rated
All season
P235/50R18
Michelin V-rated
all season; or
P235/50R18 Michelin Y-rated summer
Brakes:
Front rotor:
315- x 32-mm, vented
346- x 32-mm, vented
Rear rotor:
315- x 26-mm, vented
Front caliper:
aluminum, dual piston
cast iron, dual piston
Rear caliper:
aluminum, single piston
Chassis control systems:
4-channel ABS
traction control
dynamic rear brake proportioning
hydraulic brake assist
engine drag control
4-channel, four-mode StabiliTrak
Dimensions
Exterior
Wheelbase (in / mm):
113.4 / 2880
Overall length (in / mm):
191.6 / 4866
Overall width (in / mm):
72.5 / 1841
Overall height (in / mm):
58.0 / 1472
Track (in / mm):
Front:
Rear:
61.8 / 1569
62.0 / 1575
Curb weight (lb / kg):
RWD w / manual: 3861 / 1751
RWD w / auto: 3872 / 1756
AWD w / auto: 4101 / 1860
Weight distribution
(% front / rear):
RWD:
AWD:
51 / 49
52 / 48
Interior
Headroom (in / mm):
Front:
Rear:
38.8 / 986
37.2 / 944
Legroom (in / mm):
Front:
Rear:
42.4 / 1078
35.9 / 913
Shoulder room (in / mm):
Front:
Rear:
56.7 / 1441
57.4 / 1390
Hip room (in / mm):
Front:
Rear:
55.1 / 1400
54.1 / 1375
Capacities
EPA passenger volume
(cu ft / L):
98 / 2775
EPA trunk volume (cu ft / L):
13.6 / 385
Re: '08 CTS
Monday, January 08, 2007 10:11 PM
^^^ But what are the specs for the V? lol
Re: '08 CTS
Monday, January 08, 2007 11:12 PM
looks good.
i keep it gully like im havin a old friend for lunch
http://diggininthecrates.tripod.com
