GM's 2.9L I-4 & 3.7L I-5 info - Other Cars Forum
Monday, June 19, 2006 10:23 AM
A continuation from here.
http://www.j-body.org/forums/read.php?f=6&i=125243&t=125243#125243
For the 2007 model year, GM's popular midsize trucks - Chevrolet Colorado and GMC Canyon - as well as the HUMMER H3 SUV, feature new, larger-displacement inline four- and five-cylinder engines. The new Vortec 2.9L I-4 and Vortec 3.7L I-5 deliver more horsepower and torque than the engines they replace, giving the vehicles increased performance.
The Vortec 2.9L DOHC four-cylinder with variable valve timing (VVT) replaces the previous 2.8L four-cylinder and delivers 185 horsepower (138 kW) and 190 lb.-ft. of torque (258 Nm).* The Vortec 3.7L DOHC five-cylinder with VVT replaces the previous 3.5L engine and is rated at 242 horsepower (180 kW) and 242 lb.-ft. of torque (328 Nm).*
The 2.9L engine produces approximately 6 percent more horsepower and 3 percent more torque than the previous four-cylinder, while the 3.7L offers a substantial 22-horsepower increase and 17 lb.-ft. more torque than the previous five-cylinder engine. The 2.9L is standard in all 2007 Colorado and Canyon models except 4WD Crew Cab; the 3.7L engine is standard in 4WD Crew Cab models and available on all others. The 3.7L engine is the only engine offered on the '07 HUMMER H3 and H3X.
GM's inline engines meet the diverse demands of midsize pickup and SUV customers. The I-4 engine delivers more power than many other comparable four-cylinders, while the more powerful I-5 offers comparable power and torque to many competitors' six-cylinders.
Increased bore diameter
Both new engines are based on GM's modular inline engine design, which also serves as the foundation for the award-winning 4.2L I-6 in the Chevy TrailBlazer, GMC Envoy and Saab 9-7X. They feature dual overhead camshafts, variable valve timing, electronic throttle control and other features that contribute to high levels of operating efficiency and fuel economy. Balance shafts help ensure smooth operation and reduced vibration of the engines, providing a higher level of refinement.
In addition to their larger displacement - delivered through larger, 3.76-inch (95.5 mm) bores - the 2.9L and 3.7L engines feature improved airflow in and out of the combustion chambers, which helps boost power. They also share additional upgrades and changes, compared to the previous engines:
-Larger, 1.52-inch (38.7 mm) intake valves, vs. previous 1.45-inch (37 mm) intake valves
-Larger, 1.32-inch (33.5 mm) exhaust valves, vs. previous 1.18-inch (30 mm) exhaust valves
-Revised camshaft profile optimizes valve lift and duration in accordance with larger valves
-Cylinder head airflow increased to match capabilities enabled by larger valves and revised camshaft
-New, noise-reducing oiling system uses cylinder wall squirter system enabled by a hole in each connecting rod that delivers a precise oil stream onto the cylinder wall beneath the piston
-New aluminum camshaft cover helps reduce noise
-Tighter-clearance balance shaft bushings promote quieter operation
-New, 2-megabyte powertrain control module houses new diagnostic information storage
-New cartridge-type engine block heater, which fits neatly into a specially machined block orifice; for use with available engine block heater.
-Additionally, the 3.7L five-cylinder engine has several features that help it meet new BIN 5 emissions requirements, including a larger, close-coupled catalytic converter and A.I.R. system.
VVT-enhanced performance
The new inline engines employ state-of-the-art air-fuel and spark management, including a dual-overhead cam valvetrain, four-valves-per-cylinder, variable valve timing and coil-on-plug ignition. Like the common-design engine blocks, the aluminum cylinder heads for the 2.9L and 3.7L are modified four- and five-cylinder versions of the 4.2L I-6 head. The cylinder head design includes chain-driven camshafts with large sprockets to ease the load carried by the timing chain. Also, a roller follower valvetrain reduces friction to improve engine performance and fuel economy, while reducing noise.
VVT enhances performance and improves emissions by regulating the timing of the opening and closing of the exhaust valves. With VVT, camshaft lobe profiles are selected to enhance power, torque and engine smoothness, and the valve timing is optimized for the camshaft at different rpm levels by the PCM. VVT also eliminates the need for external exhaust gas recirculation (EGR) and contributes to improved emissions. With VVT, the exhaust valves' timing can be adjusted to "retard" the exhaust cam, thereby creating internal EGR. These leftover gases are recycled into the next burn cycle, improving emissions and engine performance.
Coil-on-plug ignition delivers a high-energy spark, contributing to a cleaner, more consistent burn of the air-fuel mixture. The system uses a separate ignition coil for each cylinder, mounted above the spark plug. An electronic engine-sensing spark control system sends energy to the coils, eliminating the need for timing adjustments.
The engines also benefit from numerous quality-enhancing characteristics:
Electronic throttle control allows the tailoring of throttle position to optimize driveability, fuel economy and emissions control
Accessories - including a new, 125-amp alternator featuring Regulated Voltage Control - are mounted directly to the engine block to reduce vibrations
The air intake plenum is constructed with sound-absorbing foam to reduce noise heard in the passenger compartment
High-mounted starter is shielded from road splash
GM Oil Life System permits oil-change intervals of 5,000-15,000 miles
The engines also feature an exhaust manifold-mounted, three-way catalytic converter design. Constructed as part of the manifold, the close-coupled converter provides optimum light off (quickly reaches high temperature) to oxidize, primarily, hydrocarbon and carbon monoxide emissions.
Shared traits
The inline engines share much of their design and technology, including dual-overhead cams, four valves per cylinder, variable valve timing (VVT), sequential fuel injection and a coil-on-plug ignition system. Approximately 75 percent of the I-4 and I-5 engines' components are shared with the larger Vortec 4.2L I-6, and about 90 percent of the four- and five-cylinder engines' parts are common. This permits increased assembly efficiency that affords GM greater flexibility in adjusting the production of each engine to meet consumer demand.
The foundations of the engines' design are deep skirt, cast aluminum engine blocks. They are produced with a lost foam process that allows more precise dimensional control, while reducing necessary finish machining in oil galleries, coolant passages and other internal passages. The deep-skirt design places block material below the crankshaft centerline to enhance rigidity of the block, while the lightweight aluminum offers better control of oil temperature, eliminating the need for auxiliary oil cooling. The lighter-weight engine block enhances fuel economy, too, by reducing overall mass.
In addition to superior dimensional accuracy and less need for finish machining, lost foam casting also allows the blocks to be produced with fewer pieces and more complex shapes. Overall, fewer pieces are needed to assemble the engines, and the accuracy of the casting process results in less scrap. And because the dry sand used in the casting process requires no bonding agent, it does not have to be discarded as solid waste. In fact, the sand is re-used for future castings.
At the assembly stage, the I-4 and I-5 engine blocks are fitted with balanced crankshafts and main bearing caps that are designed to add strength and reduce noise and vibration. Also, the engines' oil pans are structural members, contributing to overall stiffness. Both the four- and five-cylinder engines' crankshafts are specially counterweighted for their unique cylinder configuration.
The 2.9L and 3.7L engines are built at GM's Tonawanda, N.Y., engine assembly plant.
SPECIFICATIONS: 2.9L I-4 and 3.7L I-5 ENGINES
Assembly site:
Tonawanda, NY
Applications:
Chevy Colorado, GMC Canyon, Hummer H3
Type:
2.9L I-4 VVT and 3.7L I-5 VVT DOHC with cam phasing
Displacement (cu in/ cc):
178 / 2921 (2.9L)
223 / 3654 (3.7L)
Bore x stroke (in x mm):
3.76 x 4 / 95.5 x 102
Block material:
A356-T6 cast aluminum
Cylinder head material:
Main bearing caps:
forged powder metal
Intake manifold:
composite
Exhaust manifolds:
high-silicon molybdenum, cast nodular iron
Compression ratio:
10:1
Valve configuration:
dual overhead camshafts, 4 valves per cylinder
Valve lifters:
Hydraulic lash adjusters with roller, finger followers
Firing order:
1-3-4-2 (2.9L)
1-3-5-4-2 (3.7L)
Fuel system:
Horsepower (hp / kW):
185 / 138 (2.9L)*
242 / 180 (3.7L)*
Torque (lb-ft / Nm):
190 / 258 (2.9L)*
242 / 328 (3.7L)*
Fuel shut-off:
6300 rpm
Emissions controls:
evaporative system, close-coupled and underfloor catalytic converters
Crankshaft:
cast nodular iron
Camshaft:
cast nodular iron
Connecting rods:
forged powder metal
Additional features:
chain-driven dual balance shafts, variable exhaust valve timing, coil-on-plug ignition, returnless fuel system, vane-type cam phaser, electronic throttle control, Iridium -tip spark plugs, Oil Life Monitoring System, extended-life coolant, structural cast aluminum oil pan, Intelli-Start
6-19-2006
>>>For Sale? Clicky!<<<
Re: GM's 2.9L I-4 & 3.7L I-5 info
Monday, June 19, 2006 7:45 PM
sweet ... i know the original Inline 5 was turbo.. what happend to that????
. member 1244or55
.http://www22.ocn.ne.jp/~cavalier
Tuesday, June 20, 2006 7:51 AM
One way GM could get ahead of the Midsize 'hybrid' Suv wave is to hook up a hybrid system to the I-5 thats in the Huumer H3's. It be a great selling tool as well since Jeep has yet to come out with a hybrid suv plus it could alleviate some of the pressure from some groups that call hummers nothing but gas hogs.
Tuesday, June 20, 2006 2:33 PM
I can only imagine what it is going to cost to replace one of those when they go bad down the road. Good god!
Love to hear VVT getting some GM love as of late. Finally getting away from the pushrod V-6's! Still a lot more work to do, General, but keep it up!
Team GREEN
Suspension Division - "Handling Before Horsepower"
Making the turns since 1999
1998 EK Civic Hatch - Yes, it's a Honda.
Tuesday, June 20, 2006 7:28 PM
i love the 3.5 in my colorado but wouldn't mind it being S/C or turbo or hell an LS2 instead hehe
