More GM 6-speed slushboxes - Other Cars Forum
Thursday, May 18, 2006 10:53 AM
GM Launches More Fuel-Saving Six-Speed Automatic Transmissions
PONTIAC , Mich. –GM’s plan to offer one million vehicles annually with six-speed automatics by 2008 accelerates in 2006 and 2007 with nearly 40 global vehicle applications of the fuel-saving transmissions. Models of the 2007 Cadillac STS and SRX, as well as the Saturn Aura, Outlook and Pontiac G6, highlight the vehicles offered with new six-speed automatics.
Other models already on sale include the GMC Yukon Denali family, the Cadillac XLR-V, STS-V and Escalade lineup, and the Chevrolet Corvette. GM’s full-size heavy duty pickups are also equipped with an Allison 1000 six-speed automatic when equipped with the Duramax 6.6L turbo-diesel engine.
New 2007 model year six-speed automatic transmission variants include the Hydra-Matic 6T70 and 6T75 for front and all-wheel drive vehicles, as well as the Hydra-Matic 6L50 for rear and all-wheel drive vehicles. The 6L50 benefits from the expertise developed with the larger 6L80 rear-wheel drive six-speed transmission (initially in the 2006 model year), and is the second variant in the Hydra-Matic rear-wheel drive six-speed transmission family.
Advantages of a six-speed automatic include improved fuel economy, performance and a shift feel that is seamless to the customer. The six-speed automatic enables a reduced engine rpm at highway cruising speeds. A lower engine speed reduces engine wear and noise, and improves fuel economy.
“It’s a best-of-both-worlds scenario with the six-speed automatic, delivering great performance and enabling improved fuel economy,” said Jim Lanzon, executive director of transmission engineering for GM Powertrain. “It is almost like having two transmissions in one – the high numerical first gear provides tremendous off-the-line acceleration, but the transmission is able to use the six gears to evenly distribute the torque and settle at an overdrive gear that helps deliver great fuel economy.”
Vehicle performance is enhanced with a six-speed, because smaller “steps” are used between gears, compared to a conventional four-speed automatic. This allows the transmission to quickly find the best gear for the vehicle speed and road conditions – there’s less back-and-forth hunting on grades, for example. GM’s new Hydra-Matic six-speeds also use technically advanced clutch-to-clutch operation, which reduces mass, complexity and enables compact packaging. A wide, 6.04:1 overall ratio on most of GM’s six-speeds, compared to 4.0 of typical four-speed automatics, delivers both great performance and improved fuel economy.
“The mechanical simplicity of the clutch-to-clutch shift operation in our new six-speed automatic transmission families, along with a conscious effort to reduce part complexity, is providing us greater flexibility and the ability to launch with a broad application across the GM portfolio,” said Lanzon. “By 2010, GM will introduce 10 new variants of six-speed automatic transmissions, producing three million six-speeds annually.”
GM’s six-speed transmissions also provide tremendous flexibility to customize features for each vehicle brand, such as tapshift range selection, auto grade braking and a tow/haul mode.
New 6T70 and 6T75 FWD transmissions
The new Hydra-Matic 6T70 and 6T75 six-speed automatics are advanced transmissions with clutch-to-clutch shift operation for front- and all-wheel drive vehicles. The transmissions are based on a common design, with the 6T75 rated for higher torque capacity. The 6T70 debuts on the Saturn Aura and on a Pontiac G6 model; the 6T75 will be offered on the Saturn Outlook
The 6T70/75’s clutch-to-clutch operation and 6.04:1 overall ratio help the transmission deliver both performance and fuel economy, enabling up to 7 percent improved performance and up to 4 percent improved fuel economy when compared with current front-wheel drive four-speed automatics. Both transmissions use a very high numerical 4.48:1 first gear, which helps deliver exceptional launch feel, and a 0.74:1 overdrive sixth gear, which reduces engine rpms at high speeds, thereby reducing engine noise and vibrations. Fifth gear is 1:1 direct drive.
With its wide ratio and strong capacity, the 6T70/75 has the capability to transfer more torque to the drive wheels, particularly in all-wheel drive applications. It also helps vehicles, such as crossovers like the Outlook, to feel even livelier at lower speeds, particularly at launch or when pulling away from a stoplight.
The 6T70/75 offers the capability of driver shift control (DSC), which allows the driver to use tap-up/tap-down shifting to select the desired gear for specific road conditions, such as driving up a steep hill. A sophisticated transmission electro-hydraulic control module (TEHCM) is mounted inside the 6T70 and 6T75, reducing vehicle complexity. Similar to the control system used in the six-speed Hydra-Matic rear-wheel drive transmissions, the TEHCM offers improved quality through its hard-wired connections. The unit is located entirely within the transmission and operates while bathed in transmission fluid. Locating the controller internally facilitates the modular design and assembly strategy while also shielding the unit from the outside environment.
The 6T70/75 was co-developed with Ford Motor Co. Co-development of the transmission allowed it to reach production in less time and enabled each company to reduce development costs by as much as 50 percent. A common on-axis design and many common components are shared between GM and Ford Motor Co. The controls, calibrations and operation of the transmissions are unique to each company.
New 6L50 RWD and AWD six-speed
A new Hydra-Matic 6L50 six-speed transmission debuts in certain 2007 Cadillac STS rear- and all-wheel drive performance sedans and the V-8-powered SRX crossover SUV. The 6L50 is the second model of four new variants in the RWD six-speed transmission family. The 6L50 is designed with the same modular flexibility as the larger 6L80 and is fully compatible by using the same advanced electronic controls. As with the 6L80, the 6L50’s gearset configuration enables the same 6.04 wide overall ratio.
As with other GM six-speeds, the 6L50 delivers smaller steps between gears, enabling the vehicle to quickly find the best gear. A higher numerical first gear delivers strong acceleration from a standstill and two overdrive gears enable improved fuel economy through lower engine rpms at cruising speed. Also, the lower rpm achieved with the sixth gear reduces engine noise and vibration on the highway.
The 6L50 also uses the Driver Shift Control feature, which allows the driver to shift the transmission like a clutchless manual gearbox. Also, the transmission is calibrated to override the automatic gear selection during closed-throttle, high-lateral acceleration maneuvers, rapidly downshifting with nearly synchronous engine speed matching for quick power-up when the throttle is reopened. This gives the feel of a manual transmission during deceleration. Electronic safeguards prevent over-revving.
6L80 RWD six-speed
The Hydra-Matic 6L80 six-speed automatic transmission was the first of four variants in the rear-wheel drive transmission family designed with modular flexibility and compatibility with advanced electronic controls. It also features clutch-to-clutch operation, manual range selection and an integrated 32-bit electro-hydraulic controller. It debuted in 2006 on the Cadillac XLR-V, STS-V and Chevrolet Corvette, where it is offered with paddle-shift control.
The 6L80 also is tailored for the heavy-duty requirements of SUVs and trucks, and is offered on GM’s 2007 full-size SUVs equipped with the Vortec 6.2L V-8, such as the GMC Yukon Denali and Cadillac Escalade. In all applications, the 6L80 has a wide, 6.04:1 overall ratio – including two overdrive gears – that helps deliver up to 7 percent improved 0 – 60 mph performance and up to 4 percent improved fuel economy.
The 6L80’s six forward gears have smaller “steps” between them, which bolsters both performance and the feeling of smoothness. The smaller steps also enable a steep, 4.02:1 first gear, which provides an improved-performance launch feel. And with two overdrive gears, engine rpm is reduced by approximately 9 percent at 60 mph – a reduction of about 1,350 rpm.
A 32-bit electro-hydraulic control module optimizes transmission performance according to a variety of vehicle inputs, while also enabling features including tow/haul mode, auto grade braking and manual range selection. The controller is integrated within the transmission.
Tow/haul mode is a driver-selectable feature of the 6L80 that reduces shift busyness when towing or hauling a heavy load. The feature is complemented by manual range selection, which allows the driver to block out upper gears and select desired gears for unique driving conditions, such as towing on a steep grade. The manual range selection feature increases the feeling of control by holding the gear pre-selected by the driver. Electronic safeguards prevent the transmission from being shifted in a manner that could cause engine damage or loss of vehicle control. Auto grade braking is available when the tow/haul mode is selected and the transmission is not in the range selection mode.
SPECIFICATIONS: HYDRA-MATIC 6T70 / 6T75
2007 6T70 ( MH2 )/
2007 6T75 MH6 MY9
Type:
Six speed front-wheel-drive, electronically controlled, automatic overdrive transaxle with an electronically controlled torque converter clutch./
Six speed front-wheel-drive & AWD, electronically controlled, automatic overdrive transaxle with an electronically controlled torque converter clutch.
Engine range:
4.0L/
4.6L
Maximum engine torque:
280 lb-ft (380 Nm)/
301 lb-ft (406 Nm)
Maximum gearbox torque:
462 lb-ft (515Nm)/
463 lb-ft (515Nm)
Gear ratios:
First
4.48/
4.48
Second
2.87/
2.87
Third:
1.88/
1.88
Fourth:
1.47/
1.47
Fifth
1.00/
1.00
Sixth
0.74/
0.74
Reverse:
2.88/
2.88
Final drive ratio:
2.77/
3.16:1
Maximum shift speed:
1-2: 6800 rpm/
1-2: 6800 rpm
2-3: 6800 rpm/
2-3: 6800 rpm
3-4: 6800 rpm/
3-4: 6800 rpm
Maximum validated gross vehicle weight:
4850 lbs/
6384 lbs
Shifter positions:
P, R, N, M/
P, R, N, M
Case material:
die cast aluminum/
die cast aluminum
Shift pattern:
4 VBS Solenoids/
4 VBS Solenoids
Shift quality:
Variable Bleed solenoid/
Torque converter clutch:
258 mm/
258 mm
Converter size:
246 mm (reference) (diameter of torque converter turbine)/
Fluid type:
DEXRON® VI/
DEXRON® VI
Transmission weight:
wet: 102 kg/
wet: 104 kg
Fluid capacity (approximate):
9.0 L/
9.0 L
Bottom pan removal:
NA/
NA
Pressure taps available:
line pressure/
line pressure
Transfer design:
three-axis design/
three-axis design
Assembly sites:
Warren , Mich./
Warren , Mich.
Applications:
Saturn Aura
Saturn Outlook
Pontiac G6
SPECIFICATIONS: HYDRA-MATIC 6L50
2007 Hydra-Matic 6L50 (MYB)
Type:
Six speed RWD / AWD, electronically controlled automatic overdrive transmission with torque converter clutch. Clutch-to-clutch architecture, with integral Electro / Hydraulic Controls Module
Maximum engine power:
315 bhp (235 kW)
332 lb-ft (450 Nm)
480 lb-ft (651Nm)
Gear ratios:
MYB
First:
4.06
Second:
2.37
Third:
1.55
Fourth:
1.16
Fifth:
0.85
Sixth:
0.67
Reverse:
-3.2
Maximum shift speed
7000 rpm
Maximum Validated Weights: ( Target )
GVW: 6613 lb (3000 kg), GCVW: 12505 lb (5672kg)
7-position quadrant:
P, R, N, D, X, X, X ( X = available calibratable range position )
Case description:
3-piece ( Bell, main, extension)
Case material:
die cast aluminum
Shift pattern:
(2) Three-way on/off solenoids
Shift quality:
Five variable bleed solenoid
Variable Bleed Solenoid ECCC
Converter size:
258, 280mm (reference)
Fluid type:
DEXRON® VI
Fluid capacity: w/258mm converter
TBA
Transmission weight: w/258mm converter
wet: 85-90 kg (187-198 lb) estimated
line pressure
Assembly sites:
GMPT Strasbourg, France
GMPT Ypsilanti, Mich.
Applications:
Cadillac STS
Cadillac SRX
Available control features:
Multiple shift patterns (selectable or adaptive)
Driver Shift Control (Tap Up / Tap Down)
Enhanced Performance Algorithm Shifting (PAS II)
Next-generation tow / haul mode
Engine torque management on all shifts
Altitude and Temperature Compensation
Adaptive shift time
Neutral idle
Reverse lockout
Automatic grade braking
Additional features:
GM Oil Life System
OBDII / EOBD
Integral Electro/Hydraulic Controls Module -- TEHCM
Control Interface Protocol - GMLAN
SPECIFICATIONS: HYDRA-MATIC 6L80
2007 Hydra-Matic 6L80 (MYC)
Type:
Six-speed RWD / AWD, electronically controlled automatic overdrive transmission with torque converter clutch. Clutch-to-clutch architecture, with integral Electro / Hydraulic Controls Module
413 bhp (308 kW)
430 lb-ft (583 Nm)
664 lb-ft (900 Nm)
Gear ratios:
MYC
First:
4.03
Second:
2.36
Third:
1.53
Fourth:
1.15
Fifth:
0.85
Sixth:
0.67
Reverse:
-3.06
Maximum shift speed
6500 rpm
Maximum validated weightstarget )
GVW: 8600 lb (3901 kg), GCVW: 14000 lb (6350 kg)
P, R, N, D, X, X, X (X = available calibratable range position )
Case description:
Three-piece ( Bell, main, extension)
Case material:
die cast aluminum
Shift pattern:
(2) Three-way on / off solenoids
Shift quality:
Five variable bleed solenoids
Converter size:
300 mm ( reference )
Fluid type:
DEXRON® VI
Fluid capacity: w/ 258 & 300mm converter
258 mm: 9.7 L (8.22 kg), 300 mm: 11.9 L (10.1 kg)
Transmission weight: w/ 258 & 300mm converter
258 mm: Wet: 94-96 kg (207-211 lb)
300 mm: Wet: 102-104 kg (225-229 lb)
line pressure
Assembly site:
Applications:
Chevrolet Corvette
Cadillac XLR
Cadillac XLR-V
Cadillac STS-V
GMC Yukon Denali
GMC Yukon Denali XL
Cadillac Escalade
Cadillac Escalade ESV
Cadillac Escalade EXT
Available Control Features:
Altitude and temperature compensation
Adaptive shift time
Neutral idle
Reverse lockout
Additional Features:
GM Oil Life System
OBDII / EOBD
Integral Electro/Hydraulic Controls Module – TEHCM
For release 18-5-2006
>>>For Sale? Clicky!<<<
Re: More GM 6-speed slushboxes
Thursday, May 18, 2006 1:32 PM
Holy write up batman...
Ya, I think we'll all have 6 or may before long 8 speed trannies in cars.
Very good write up by the way!
Silver Stripey makes your Day!
Saturday, May 20, 2006 7:25 AM
At what point do they not decide to just go CVT?
Saturday, May 20, 2006 9:04 AM
They had them on Saturns, but because the CVT had so many problems with them, Saturn abandon them.
Tuesday, May 23, 2006 12:31 PM
Mr.Goodwrench-G.T. wrote:They had them on Saturns, but because the CVT had so many problems with them, Saturn abandon them.
Yeah I know.. the Ion was supposed to have them. So instead of sorting them out they are making 6 speed autos?
Tuesday, May 23, 2006 7:57 PM
it's not just GM tho, the new camry and i belive altima have 6spd auto's now. Doesnt benz have a 7spd already? Just seems like to many gears to me
Tuesday, May 23, 2006 9:20 PM
^And Lexus will/has 8 speeds now.
GM stop putting them in Saturns (ION/VUE) in 2005 M/Y and instead is using 5-speed automatics.
Wednesday, May 24, 2006 12:42 PM
whats going on with the lesser sized transmissions we just gonna be getting 5 speed autos for the 4 cylender powertrian
Wednesday, May 24, 2006 3:43 PM
For now, only 4 & 5 speeds will be used.
Wednesday, May 24, 2006 4:20 PM
i think its a good idea
thats why i hate my three speed auto, cause at highway speeds, the rpm's have to be hitting 4500-5000, and that hurts fuel mileage.
plus i had to unplug the TCC solenoid, and that made it worse
