MazdaSpeed 3, all you need to know - Other Cars Forum
Saturday, May 06, 2006 11:53 AM
sadly the car is only going to be offered as a 5 door, which means im not really interested in it. . .
OVERVIEW
2007 MAZDASPEED3: INFUSED WITH A DOUBLE DOSE OF ZOOM-ZOOM
-- New MAZDASPEED3 to be one of the quickest front-wheel drive cars in the world –
NEW YORK – Making its North American debut at the 2006 New York International Auto Show, the 2007 MAZDASPEED3 will be the flagship of the MAZDA3 range when it launches in Fall 2006. With its compact, lightweight body and more than 250-horsepower from a 2.3-liter DISI (Direct Injection Spark Ignition) Turbo engine, MAZDASPEED3 will be one of the highest performance front-wheel drive cars in the world when it hits the highway.
MAZDASPEED3 is the fourth vehicle to carry the MAZDASPEED name in the US, following the 2003 and 2003.5 MAZDASPEED Protegé, 2004 and 2005 MAZDASPEED MX-5 and 2006 MAZDASPEED6. This will be the first time that two MAZDASPEED-branded vehicles will be sold in North American dealers at the same time. MAZDASPEED3 is called MAZDA3 MPS – Mazda Performance Series – in Europe and MAZDASPEED Axela in Japan.
MAZDA3 debuted in Summer 2003 and has gone on to enjoy enormous popularity worldwide. Since launch, it has quickly become Mazda’s best-selling model globally with over 750,000 vehicles produced in just30 months.
"MAZDASPEED3 dramatically reinforces the acclaimed dynamics of the original MAZDA3 and deliver s maximum driving pleasure through outstanding engine performance and a superior chassis ,” said Tatsuo Maeda, Program Manager for development of the MAZDA3 series.
To create this new benchmark, Maeda’s team focused on three requirements:
• Driving Fun: Formidable performance from the 2.3-liter DISI Turbo engine, along with sharp, responsive handling
• Ownership Delight: Exterior styling that gives an immediate impression of driving fun, and an interior with a quality feel that exceeds expectations
• Everyday, User-Friendly Convenience: Balancing driving pleasure with everyday functionality and comfort
As a result, the flagship of the MAZDA3 range features a stylishly sophisticated look combined with performance levels that make it one of the quickest and fastest front-wheel drive vehicles in the world. MAZDASPEED3 offers strong acceleration from a standing start, superior passing acceleration and one of the highest top speeds in its class.
POWER AND HANDLING
Under the hood of the MAZDASPEED3 is a version of the turbocharged and intercooled 2.3-liter four-cylinder direct-injection gasoline engine that powers the highly regarded MAZDASPEED6 sport sedan and the CX-7 crossover SUV. Engineered to deliver high performance at all speeds, along with low exhaust emissions and excellent fuel economy, Mazda’s MZR 2.3 DISI (Direct Injection Spark Ignition) turbo -charged engine produce s in excess of 250-hp in the MAZDASPEED3. Final horsepower numbers will be available closer to launch.
Key building blocks are aluminum block and head construction with forged internal components — crankshaft and connecting rods — for long-lasting durability. Balance shafts curb noise and vibration. A large air-to-air intercooler and direct fuel injection cool temperature inside the cylinder. Shifting gasoline’s change in state from liquid to vapor from the intake manifold to the cylinder provides the substantial cooling effect. The low charge temperature permits use of a high 9.5:1 compression ratio which bo o sts low- and mid-range torque by approximately 10-percent over conventional turbo engines.
The DISI Turbo engine is engineered to achieve three aspects of performance that are difficult to realize with conventional manifold injection engines: good fuel-economy and low exhaust-gas emissions, powerful acceleration thanks to the turbocharger, and a full and flat torque curve throughout the rev range for exceptional engine response.
Tuning of the exhaust system focused on sounds in the low frequency range, while tuning of engine sound focused on the mid frequency range produced at high engine speeds to deliver an enjoyably sporty sound.
HIGH-LEVEL TORQUE MANAGEMENT
To increase drivability in what is a very powerful front-wheel drive car, intake volume and boost pressure-control suppress sudden torque peaks, assuring smooth, linear torque delivery. Additionally, torque characteristics from first through third gears are electronically controlled to deliver appropriate power delivery, minimizing torque-steer and wheel-spin. More information about this system will be available closer to launch.
Torque control is also linked to the steering angle, and the stiffness of the left and right drive shafts is balanced, also working to minimize torque-steer. A newly-developed limited slip differential also minimizes wheel-spin on the inner wheel during hard cornering for smooth, predictable power delivery.
SIX-SPEED MANUAL TRANSMISSION
The new MAZDASPEED3 employs the six-speed manual transmission shared with the MAZDASPEED6 , providing the driver with full control over the vehicle’s high power, while contributing to a quiet ride and strong fuel economy. A compact three-shaft design made it possible to keep the overall length the same as the five-speed manual transmission used in the standard MAZDA3. In addition, MAZDASPEED3's six-speed transmission uses wide gear ratios to fully exploit the wide torque band of the direct-injection turbocharged engine.
HIGH BODY RIGIDITY AND SPECIALLY TUNED CHASSIS
Like the updated 2007 MAZDA3 , the new MAZDASPEED3 features a body with increased rigidity. The MAZDASPEED version is based on the MAZDA3 5-Door, with local reinforcements added to produce a body sufficiently stiff to stand up to the demands of 250-plus horsepower. Suspension and brakes have also been specially tuned.
Body rigidity has been increased by several features, including a reinforced front cowl member that is joined directly to a plate in the top section of the front shock mount, assuring the same rigidity as a car fitted with strut tower bars. This prevents deformation of the front suspension towers and maintains correct suspension geometry. In the lower body, a large closed section member is employed to reinforce the floor tunnel which improves the torsional rigidity of the whole body. At the rear, the gusset introduced at the bottom end of the rear suspension towers restrains the tendency of the towers to displace inwards which maintains the correct suspension geometry under all cornering loads.
Both the MacPherson strut front suspension and multi-link rear suspension have higher spring rates and larger diameter stabilizer bars than the standard MAZDA3. Damping force on both compression and rebound is raised approximately six-times at low piston speed, and about 1.3-times at moderate piston speed. In combination with the reinforced springs and stabilizer bars, this produces60-percent more roll stiffness than the standard MAZDA3.
ENGINEERED AERODYNAMICS
Special attention was paid to achieve aerodynamic performance that supports stable straight running, lane changing and overtaking at high speeds. A wide variety of underfloor parts were employed to achieve the superior aerodynamic performance targets, and the result is a Cd of 0.32.
MAZDASPEED DESIGN DNA
MAZDASPEED3's styling pursues a look of strength and solidity in a design that conveys the car's dynamic performance. Its form is characterized by boldly flared front fenders and effective use of strong edges on the hood. These combine with the functional forms of the bumpers, spoilers and other parts developed for aerodynamic performance. Overall, MAZDASPEED3's design is sporty and strong, befitting a high-performance model, without exaggerated styling cues.
EXTERIOR DESIGN
Choosing the MAZDA3 5-Door model as the starting point reinforces the MAZDASPEED3’s Zoom-Zoom spirit. Front fenders are widened by 20-mm to provide clearance for the large tires and to evoke a well-planted stance. And to forge a uniform identity for the MAZDASPEED series, two design elements are shared with the MAZDASPEED6 : strong lines flowing back along the hood from the upper part of the five-point grille used as the air intake for the intercooler, and the aerodynamically shaped front bumper and large lower grille serving as the air intake for the radiator. An athletic yet elegant side view is created by aerodynamic side skirts and 18-inch, 10-spoke aluminum alloy wheels.
The rear view is characterized by the design of the rear bumper, the large-diameter tailpipe and the roof spoiler with integrated high-mounted LED brake light.
INTERIOR DESIGN
A high-quality black finish sets the tone of the interior, accented by red stitching on the seats, steering wheel, and the six-speed manual transmission shift knob to create a sporty yet refined look. The instrument panel includes a matte black decorative insert panel finished with a hairline treatment to underscore the vehicle’s personality. A leather-wrapped shift knob, aluminum pedals and stainless steel scuff plates further contribute to the sporty, high quality feel that distinguishes MAZDASPEED models, while semi-bucket front seats provide firm support and comfort.
UPGRADED BRAKE SYSTEM TO MATCH THE HIGH POWER
Large diameter four-wheel disc brakes, vented in front, and a large diameter master cylinder provide powerful and stable braking. Standard equipment includes four-wheel-ABS, electronic brakeforce distribution (EBD) with brake assist and dynamic stability control (DSC), all of which provide active safety in a range of driving scenarios.
For protection during collisions, MAZDASPEED3 employs the unique Mazda Advanced Impact-energy Distribution and Absorption System to deliver a robust and safe body structure. Inside the cabin, dual frontal airbags, as well as seat-mounted side and roof-mounted curtain airbags, are all standard. A collapsible brake pedal and steering column structure reduce the risk of injury to the driver's lower legs.
Headquartered in Irvine, Calif., Mazda North American Operations oversees the sales, marketing, parts and customer service support of Mazda vehicles in the United States, Canada and Mexico through nearly 900 dealers. Operations in Canada are managed by Mazda Canada, Inc., located in Ontario, Canada, and in Mexico by Mazda Motor de Mexico in Mexico City.
2006 Black Cobalt SS Supercharged G85
13.91@102.77
Re: MazdaSpeed 3, all you need to know
Saturday, May 06, 2006 1:10 PM
pics?
LE61T PTE6262 Powered
Saturday, May 06, 2006 2:49 PM
Saturday, May 06, 2006 3:06 PM
mmmmmm....6 speed. wait, i can't drive a stick, dammit!!
whats the little knob deal by the shifter, don't tell me there's an idrive type system in there...
GO PATS!!!
Saturday, May 06, 2006 3:58 PM
hmmm I wonder how much thats gonna go for...
Saturday, May 06, 2006 5:02 PM
If you're talking about the thing on the right hand side of the shifter in the last picture....that's the controls for the navigation.
Saturday, May 06, 2006 5:47 PM
maybe for its class yea but for the fastest in the world i highly doubt that.
besides it wont be for long since the dodge caliber srt4 is coming with 300 hp from the factory
boost will be soon for me....
Saturday, May 06, 2006 6:11 PM
Z Speed Cavi wrote:New MAZDASPEED3 to be one of the quickest front-wheel drive cars in the world –
it will outhandle the caliber
and looks much better
Sunday, May 07, 2006 3:02 PM
What is the quickest FWD car right now?
SRT4 run what like the best 13.6-8?
mazda should be like mid 13 sec?
Real cars don't make power at the front wheels......
THEY LIFT THEM !!!
Sunday, May 07, 2006 4:56 PM
hope it comes in the 4 door too. Not a fan of the hatch.
"Custom cars, custom problems."-me
Sunday, May 07, 2006 5:35 PM
loving the hatch
Sunday, May 07, 2006 5:44 PM
yeah can you guys read? ONE OF THE
not THE
god
Sunday, May 07, 2006 5:45 PM
Z Speed Cavi wrote: New MAZDASPEED3 to be one of the quickest front-wheel drive cars in the world ďż˝
It says one of the quickest I don't find it that hard to bebelieve
I have liked the Mazda 3 since day one but I want something with a little more power I can't wait for this to come out.
Jabbles
Monday, May 08, 2006 6:43 AM
looks allright
Monday, May 08, 2006 6:50 AM
The problem Mazda has always had is not putting enough power into their cars. No one disputes their handling capabilities.
Looks like this may change that. Too bad I'd still rather have a mini cooper.
-Chris
Monday, May 08, 2006 9:08 AM
I once destroyed a Mazda 3 at work by neutral dropping it.
Monday, May 08, 2006 9:10 AM
wish it was offered in a 2dr hatchback
Spotabee Racing (The Fake Z24) wrote:
Sorry that you aren't fond of me... I guess you seem to be a loner in that crowd bud.
...i beg to differ
Monday, May 08, 2006 9:54 AM
The Redneck wrote:mmmmmm....6 speed. wait, i can't drive a stick, dammit!!
if you look more closely at that knob it looks like it says "water" in which I'm assuming that they have water cooled intercooler maybe??? at least it would make sence.
**changes are here**
Monday, May 08, 2006 10:01 AM
The knob says "Enter" and there's all sorts of menu buttons around it....definitely not a water-cooling control at all.
Monday, May 08, 2006 10:41 AM
SpcmnSpff302 (The Link Master) wrote:The knob says "Enter" and there's all sorts of menu buttons around it....definitely not a water-cooling control at all.
eh yeah... like i said it "looks" like it says, not knowing what it really said. but looking at the buttons around it I guess "enter" makes more sence
Monday, May 08, 2006 10:55 AM
what happened to making fast 2 DOOR cars... all of these cars (STI, EVO, SRT, MAZDASPEED 3 and 6, etc.) all seem to be 4 dr. Come on!
Monday, May 08, 2006 10:57 AM
and I know they make fast 2 drs but they are almost all more expensive cars (25K+)...
Monday, May 08, 2006 9:10 PM
well, looks like I should start saving now for a blue one with navigation
any idea of the price? I would guess $23-ish
Monday, May 08, 2006 11:52 PM
@!#$ navigation
youll be going to fast for the computer to keep up
Tuesday, May 09, 2006 10:13 AM
they have said it will be under 25000
13.91@102.77
