Hi,
We are in the process of replacing a timing belt on a 1996 VW PAssat 2.0 ( 8 Valve ) gas and are having a problem lining up the timing marks. The Chilton manual we have is very vague on how all the marks line up? Can anyone help out with advice please?
Thanks,
Will
Real Cars ( and Trucks. ) Have 3 Pedals, 2 Shifters, and No Sparkplugs!!
Hey,
Well after getting a print out from a Mitchell manual, we are closer. The crank has to be at 12 oclock, and so does the cam. The intermediuate pulley has to line the distrubutor so that #1 cyl fires on TDC, which sets up the fuel & ignition timing.
Went for a test drive, and it must be out by a tooth because it is sltill a little hesitant, so we will be tinkering a little more tomorrow one tooth at a time untill it is right!!
Thanks for the replies.
you should have posted at the vwvortex - they would know more than people here.
R.I.P. Brian St.Germain
MS Walk April 21 - I HIT MY GOAL!!! thanks to those of you who have supported me!
I was gonna help you out untill I read "Thanks for the replies."
5 hours and you expect everyone to have seen it? hell I was at work working on VW's in that time span.... your on your own now
Hey,
You could have replied, more input is always welcome.
My cousin came over with a Mitchell print out which was way more detailed than the Chilton books!!
It runs great!
Thanks alot!!
