2007Jeep Wrangler Unlimited 4dr. - Other Cars Forum
Wednesday, April 12, 2006 5:52 AM
Wheelbase: 116"
Width: 73.9"
Engine: 3.8Lv6 205hp + 240lb-ft torque
Cargo capacity: 46.4 cu. ft
Trim levels: X, Sahara & Rubicon
Fuel Economy and Price : TBA at a later date
4dr with custom 3 peice removable hard top and soft top available
Electronic Stability Program
Full screen Navigation system
Removable doors
Re: 2007Jeep Wrangler Unlimited 4dr.
Wednesday, April 12, 2006 5:54 AM
Wednesday, April 12, 2006 7:04 AM
Where's the mud?
* Student of the University of Oklahoma. Go Sooners!
Wednesday, April 12, 2006 8:05 AM
that jeep aint going through any water crossings
Wednesday, April 12, 2006 8:18 AM
Ugly. Looks even worse with no doors. They also have some with color matched fenders that make it look H2ish IMO. I have like all the wranglers up to now. That thing is just ugly.
Wednesday, April 12, 2006 8:22 AM
YICK
Wednesday, April 12, 2006 8:47 AM
Let me help you out Spikej...
>>>For Sale? Clicky!<<<
Wednesday, April 12, 2006 9:14 AM
i don't like the hard top or full doors.
first one looks better (without top and dif doors)
Toon Gallery | Sig Gallery | MySpace Page
Wednesday, April 12, 2006 9:25 AM
^It is a photoshop.
Wednesday, April 12, 2006 12:38 PM
I can't believe my eyes, WTF is jeep thinking.
2012 HD VRSCF
2010 Ford Explorer
2006 Ford Ranger
2004 Chevy Cavalier
Wednesday, April 12, 2006 12:42 PM
i really hope they dont @!#$ up the wrangler...i mean seriously what the @!#$ are the guys at jeep thinking...
Wednesday, April 12, 2006 1:28 PM
2007 JEEP WRANGLER UNLIMITED SPECIFICATIONS
Dimensions are in inches (millimeters) unless otherwise noted.
GENERAL INFORMATION
Body Style........................................................................................................................4-Door Sport Utility
Assembly Plant ...........................................................................................................................Toledo, Ohio
EPA Vehicle Class…........................................................................................................Multi-purpose vehicle
ENGINE: 3.8-LITER, OHV, 12-VALVE SMPI V-6
Availability..............................................................................................................................................Std.
Type and Description............................................................................Six-cylinder, 60° V-type, liquid-cooled
Displacement….....................................................................................................230.5 cu. in. (3778 cu. cm)
Bore x Stroke….............................................................................................................. 3.78 x 3.43 (96 x 87)
Valve System........................................................................OHV, 12 valves, roller followers, hydraulic lifters
Fuel Injection.............................................................................................. Sequential, multi-port, electronic
Construction………………...................................................................... Cast-iron block, aluminum alloy heads
Compression Ratio…………..................................................................................................................... 9.6:1
Power (SAE net)…........................................................................ 205 hp (153 kW) @ 5,200 rpm (53.9 hp/L)
Torque (SAE net)...................................................................................... 240 lb.-ft. (325 N•m) @ 4,000 rpm
Fuel Recommendation..........................................................................Unleaded regular, 87 octane (R+M)/2
Oil Capacity....................................................................................................................6 qt. (5.7L) plus filter
Coolant Capacity........................................................................................................ 13.36 qt. (12.64L) Std.
Emission Controls…..............................................................................Three-way catalytic converter, heated
oxygen sensors, electronic EGR and internal engine features
Manual Transmission Meets Tier 2 Bin 5 (federal) and LEV II (CA) emission requirements
Automatic Transmission Meets Tier 2 Bin 5 (federal) and ULEV II (CA) emission requirements
ELECTRICAL SYSTEM
Alternator...............................................................................................................................................160A
Battery………………………………................................................................................600 CCA, maintenance-free
TRANSMISSION: NSG 370—MANUAL, SIX-SPEED OVERDRIVE
Availability…...........................................................................................................................Std.—All models
Description............................................................................. Synchronized in all forward gears and reverse,
multi-rail shift system with top-mounted shift lever
Clutch....................................................................................Hydraulic actuation
Gear Ratios
1st…......................................................................................................................................................... 4.46
2nd…......................................................................................................................................................... 2.61
3rd…......................................................................................................................................................... 1.72
4th…......................................................................................................................................................... 1.25
5th…......................................................................................................................................................... 1.00
6th….......................................................................................................................................................... 0.84
Reverse.................................................................................................................................................... 4.06
Axle Ratio.............................................................................................3.21 Std., 4.10 Opt. (Std. on Rubicon)
Overall Top Gear...................................................................................2.69 Std., 3.44 Opt. (Std. on Rubicon)
TRANSMISSION: 42RLE—AUTOMATIC, FOUR-SPEED OVERDRIVE WITH VARIABLE LINE PRESSURE
Availability………………........................................................................................................................Optional Description.....................................................Electronic governor, electronically controlled converter clutch
Gear Ratios
1st….. ....................................................................................................................................................... 2.84
2nd…......................................................................................................................................................... 1.57
3rd…............................................................................................................................................................1.0
4th….......................................................................................................................................................... 0.69
Reverse.................................................................................................................................................... 2.21
Axle Ratio................................................................................................................................................. 4.10
Overall Top Gear...................................................................................................................................... 2.83
TRANSFER CASE: NV241 COMMAND-TRAC
Type…………........................................................................................................................................Part-time
Operating Modes .........................................................................................................2WD High; 4WD High; Neutral; 4WD Low
Low Range Ratio................................................................................................................................... 2.72:1
Center Differential Type…….....................................................................................................................None
TRANSFER CASE: NV241OR ROCK-TRAC
Type............................................................................................................................... Part-time, heavy-duty
Low Range Ratio…….................................................................................................................................4.0:1
Center Differential Type…………..............................................................................................................................................None
DIMENSIONS AND CAPACITIES
General Overall Length.............................................................................................................173.4 (4404.4)
Overall Width (without mirrors)…................................................................................................73.9 (1877.1) Height........................................................................................................................................70.9 (1800.9) Wheelbase................................................................................................................................116.0 (2946.4)
Track, Front ...............................................................................................................................61.9 (1572.3)
Overhang, Front..........................................................................................................................26.7 ( 678.2)
Overhang, Rear...........................................................................................................................30.6 ( 777.2)
Maximum Payload (includes occupants and cargo)............................................................ 1000 lbs. (454 kg)
CLEARANCES
P225/75R16 Tire
P245/75R16 Tire
P255/75/R17 Tire
P255/70R18 Tire
LT255/75R17 Tire
Approach Angle Deg.
40.6
42.1
43.6
44.4
44.4
Breakover Angle Deg.
17.8
19
20.3
20.9
20.8
Departure Angle Deg.
37.5
38.8
40.3
40.7
40.5
Front Axle to ground
9.0 (228.6)
9.6 (243.8)
10.2 (259.1)
10.5 (266.7)
10.5 (266.7)
Rear Axle to ground
8.7 (221.0)
9.3 (236.2)
10.0 (254.0)
10.2 (259.1)
10.1 (256.5)
CURB WEIGHT
Wrangler Unlimited X, Man. Trans………………………………………………………………………………..4075 lbs. (1848 kg)
Wrangler Unlimited X Auto. Trans………………………………………………………………………………..4100 lbs. (1860 kg)
Wrangler Unlimited Sahara, Man. Trans……………………………………………………………………….4269 lbs. (1936 kg)
Wrangler Unlimited Sahara, Auto. Trans……………………………………………………………………….4294 lbs. (1948 kg)
Wrangler Unlimited Rubicon, Man. Trans………………………………………………………………………4315 lbs. (1957 kg)
Wrangler Unlimited Rubicon, Auto. Trans………………………………………………………………………4340 lbs. (1969 kg)
ACCOMMODATIONS
Seating Capacity, F/R.............................................................................................................................. 2/3
Front
Headroom……………………………............................................................................................41.3 (1049.0 mm)
Legroom…..........................................................................................................................41.0 (1041.4 mm)
Shoulder Room..................................................................................................................55.8 (1417.3 mm)
Hip Room...........................................................................................................................55.6 (1412.2 mm)
Seat Travel………………………................................Driver – 9.055 (230.0mm), passenger – 9.055 (230.0mm)
Front Volume Index, cubic ft. (cu. m)................................................................................. 54.6 (1.55 cu. m)
Rear
Headroom……………………………............................................................................................40.4 (1026.2 mm)
Legroom…..........................................................................................................................37.2 ( 944.9 mm)
Shoulder Room..................................................................................................................56.8 (1442.7 mm)
Hip Room......................................................................................................................... .56.7 (1440.2 mm)
Rear Seat Volume Index, cubic ft. (cu. m) ..........................................................................49.4 (1.40 cu. m)
Cargo Liftover Height ………...............................................................................................31.4 ( 797.6 mm)
Maximum Cargo Width at Swing Gate Opening.................................................................58.7 (1491.0 mm)
Minimum Cargo Width at Swing Gate Opening .................................................................41.2 (1046.5 mm)
Maximum Cargo Height at Swing Gate Opening................................................................37.1 ( 942.3 mm)
Minimum Cargo Height at Swing Gate Opening.................................................................37.0 ( 939.8 mm)
Distance between wheelhouses....................................................................................... 44.7 (1135.4 mm)
Cargo Volume cubic ft. (cu. m)
Rear seat folded….………….................................................................................................86.75 (2.46 cu. m)
Rear Seat Upright……………………….....................................................................................46.43 (1.31 cu. m)
BODY AND CHASSIS
Layout............................................................. Longitudinal front engine, four-wheel drive & two-wheel drive
Construction…..........................................................................................Ladder-type frame, open steel body
SUSPENSION
Front……………............................................Live axle, leading arms, track bar, coil springs, stabilizer bar,
low-pressure (on 16-inch wheel packages) gas-charged shock absorbers—std.;
Monotube high-pressure (on 17- and 18-inch wheel packages)
Electronic Sway Bar Disconnect System (ASDS) opt.
Rear .................................................................Live axle, trailing arms, track bar, coil springs, stabilizer bar,
STEERING
Type.......................................................................................................Power, recirculating ball with damper
Overall Ratio …..........................................................................................................................14.7:1 overall
Turning Diameter (curb-to-curb)…. ................................................. 41.2 ft. (12.56 m) with 225/75R16 tires
Steering Turns (lock-to-lock) ……….....................................................................................................3.5
BRAKES
Availability............................................................................................................................................Std. All
Power Assist Type............................................................................................ 8 x 9 dual-diaphragm vacuum
Four-Wheel Anti-Lock with on- and off-road calibrations……......................................................................Std.
Electronic Stability Program (ESP) …….......................................................................................................Std.
Parking Brake Type ......................................................................................................................Drum-in-hat
Front Size and Type………………………………………………………………………...........11.9 x 1.1 (302 x 28) vented rotor
with 2.6 (66) single-piston floating caliper
Swept Area (total front).....................................................................................220.6 inches/caliper
Rear Size and Type................................................................................... 12.44 x 0.47 (316 x 12) solid rotor
with 1.9 (48) single-piston floating caliper
Swept Area (total rear).......................................................................................... 207.7 inches/caliper
WHEELS
Availability……..............................................................................................................................X Standard
Type and Material ……................................................................................................................Painted Steel
Size………...........................................................................................................................................16 x 7.0
Availability.....................................................................................................................................X Optional
Type and Material.......................................................................................................Painted Cast Aluminum
Size ...................................................................................................................................................16 x 7.0
Availability........................................................................................................Sahara Standard
Size.....................................................................................................................................................17 x 7.5
Availability........................................................................................................Rubicon Standard
Type and Material...................................................................................................Machined Cast Aluminum
Availability…………..............................................................................................................Sahara Optional
Size……...............................................................................................................................................18 x 7.5
TIRES
Availability…….........................................................................................................................................X Std.
Size and Type ............................................................................ P225/75R16, On/Off-road, Black Side Wall
Mfr. and Model.............................................................................................................Goodyear Wrangler ST
Revs per Mile (km).........................................................................................................................712 (1146)
Availability…....................................................................................................................................X Optional
Size and Type….......................................................................... P245/75R16, On/Off-road, Black Side Wall
Mfr. and Mode...........................................................................................................Goodyear Wrangler SRA
Revs per Mile (km).........................................................................................................................687 (1106)
TIRES CONT…
Availability….........................................................................................................................Sahara Standard
Size and type….............................................................P255/75R17, On/Off-road, Outlined White Lettered
Mfr. and Model…......................................................................................................Goodyear Wrangler SRA
Revs per Mile (km).........................................................................................................................661 (1064)
Availability…….......................................................................................................................Sahara Optional
Size and Type……..........................................................P255/70R18, On/Off-road, Outlined White Lettered
Mfr. and Model……...................................................................................................Bridgestone Dueler 693
Revs per Mile (km)........................................................................................................................653 (1051)
Availability…........................................................................................................................Rubicon Standard
Size and Type……........................................................................... LT255/75R17, Off-Road, Black Side Wall
Mfr. and Model.......................................................................................................B.F. Goodrich Mud Terrain
Revs per Mile (km)……………….......................................................................................................650 (1046)
TOWING CAPACITIES
Little extra help!
Wednesday, April 12, 2006 1:30 PM
I like the idea behind it. But I dont think it needs the Wrangler name....
Wednesday, April 12, 2006 1:52 PM
looks its JEEP H3
LOL
looks better with out a top
Wednesday, April 12, 2006 4:58 PM
kinda looks like a wrangler, h3 and malibu maxx had a 3some
women are like cars you have to test drive the new one before you trade in the old one
Wednesday, April 12, 2006 5:12 PM
i just vomited a little
Wednesday, April 12, 2006 7:30 PM
just doesn't look right to me
Jabbles
Wednesday, April 12, 2006 7:44 PM
im diggin the hardtop, i like that a lot.
Sorry.....
You have been banned from posting on this site as of 2005-01-13 10:15:53.
This ban will expire 2005-01-14 10:15:35 Pacific Time.
Reason: Free 84 Cavi Drop Top!
Thursday, April 13, 2006 6:58 AM
Thanks for the help guys I would've eventually got around to listing everything today since I was quite busy with real world stuff yesterday. The pic I posted of the Soft top version is not a photoshop, if you look closely at the pic you'll see the reflection of the photographer. I like it but the only problem I see with it is Jeep releasing the Patriot & Compass which is basically a four door Wrangler without a removable top. They will all compete in the same category (small SUV) however the Wrangler will more offroadable.
Thursday, April 13, 2006 7:14 AM
i dont think its bad.
think of it this way you can sorta have your family vehicle and off road jeep at the same time
Thursday, April 13, 2006 9:45 AM
Jeep needs to come out with this concept. http://www.jeep.com/autoshow/concept_cars/gladiator/
I would so rock that in a heart beat.
Thursday, April 13, 2006 9:47 AM
VID GOD wrote:Jeep needs to come out with this concept. http://www.jeep.com/autoshow/concept_cars/gladiator/
I saw that in person at the cincy auto show and saw another Jeep concept at the dayton auto show
Friday, April 14, 2006 5:31 PM
it's not so bad. I'd rock a permanent hardtop version
[ o ][][][][][][][][ o ] coach built jeep
