So here is the deal. Life kinda got in the way of this project and i never was really able to keep it running for 3 weeks cuz something always came up. In anycase. Car has not been run in 7 years. pulled apart engine since i was going to try and pull out engine but got as far as valve cover and headers. If you come and pick up the car as a whole it is FREE. Just need it gone by Wednesday. i will not part out as it requires me to work on car. 1997 Chevy Cavalier LN2 engine code If nobody picks up car I will junk the car as is.
Manley pushrods
Comp Cams 1.6 Rocker Arms
Comp Cams Poly loc
ARP rocker arm studs metric
Stage III Port and Polish
Three angle valve job
Hyper ground system wires
Weapon R Intake
9:1 compression
Venolia Pistons (Cavalier Connection)
total seal rings
eagle connecting rods (Cavalier Connection)
Underdrive pulleys (Cavalier Connection)
ARP head studs
Fel-pro gasket
high volume oil pump
heavy duty melling lifter
mild regrind of the cams
What I am selling shipping not included
Does not include shipping
OBX header new never installed $125
Spare head $100
Spare automatic tranny $100
Weapon R intake $100
MSD programmable used DIS 2 PN 6212--- $200
MSD coil interface block new PN 8870 -- $40
Front crossmember inserts RK sport poly urethane $50
Also have 2 diffrent sytle of altezza tailights one has a broken prong and chipped at corner $50
The other are perfectly fine let me know ASAP
I am interested in the crossmember inserts
