2004 cavalier circle track set up - Racing Forum
Monday, April 03, 2017 12:36 PM
Man I need some advice.... I can't get my cav to go thru the turns it pushes hard.... It went from. The ass coming around on me to pushing I give up. I don't use sway bars I got 1 in of camber on rt ft. And got some rear steer and have played with different tire sizes. PLEASE HELP IF YOU CAN. THANK YOU IN ADVANCE
Re: 2004 cavalier circle track set up
Tuesday, May 02, 2017 5:01 PM
Could use some more info. LSD or welded diff. Stagger does help when your welded. Rear sway bar. Traction in the track. Wet or dry
Wednesday, June 07, 2017 6:12 AM
What rules? in Imca the guys cant weld, or stagger. legally. and yes they have checked and DQ at our local track.
Monday, October 09, 2017 3:38 PM
I drive on a quarter mile track that has good banking and I've had success with running 40 psi in RF 37 psi in RR 13 psi in LF and 17 psi in LR. With 1/8 to 1/4 inch toe out. And make sure ur rear stagger is close to even and maybe 1/4 inch stagger in the front.
Saturday, January 27, 2018 1:50 PM
are you still fighting with your cav. set up? We run a '02 sunflower that my daughter does pretty good with. Might be able to help.
