I know a 2.4 intake off a Chevy HHR will work on my motor but I heard that a mid or later 90s camaro throttle body is like 6 to 8 mm bigger. Does anybody know if will work and if it gives more hp? Can text/call at (712) 899-3584.
Cody"TheDirtRocket"Thompson #25
I also heard that a 2013 Impala injectors give it more fuel off the new ecotec???
The 2.4 eco (le5) manifolds will bolt on to the l61. You will need a tune and bigger injectors to really take advantage of any gains to be had. I believe the 2013 impala (or any gm) is direct injected, and no DI injectors are compatible. Cobalt as/sc injectors are plug and play, as well as ford color top injectors (easily found in 03-05 cobras as well as others. Again, a tune is needed with any change in injector.
You can use ls1 throttle body (98-02 f-bodies, vertex, etc) or the vortex tb with an adapter. May be adapters out there for lt1 tb's as well, but I'm not sure. CBM makes some adapters that I know off, and most machine shops should be able to fab something
