So Last Night I Ran A 13.83 @ 103.47 On Stock 14s With Some Cheap Tires On Them
60 Ft---------------2.1323
330Ft--------------5.9620
1/8ET--------------9.0333
1/8MPH-----------81.23
1/4ET--------------13.8349
1/4MPH-----------103.47
RIP Cpl Derek Kerns And Cpl Robby Reyes
24th MEU VMM-261 (REIN) V22 Crewchiefs
11 April 2012 Morocco (African Lion)
you are literally dead on with my times haha. i mean dead on.
mine:
01:13 AM - 24/May/08 - Cordova Dragway (13.804@103.91)
A set of drag radials would help your 60ft times and you could pick up as much as .5 sec off your 1/4 mile times.
I was around the same times as you before I got a set of BFG G-force drag radials.
very nice, how much psi were you running?
that was on a crappy tune and car would not hit 12psi after investigation found that i blew a wastegate gasket so after fixing that and everything the boost controller is now set at 16psi daily i plan to run the car again this friday but with a lil better tires. on wednesday i might be getting a set of slicks to use so if that happens then im off to a junkyard on wednesday to get two spare rims and order tubes offline lol
ah, i did mine on 6.5psi. on 13 i did a 12.8@106
but keep it up, while at the yard get some spare axles
Yeah Vince i def need to get someone to tune my car better cause i should be making alot more power but idk anyone around me in nc or indy that would be able to go over it for me im slightly pissed that i paid about 550 bucks to tune my car and its not even close to where it should be
if it makes you feel any better with drag radials in an 1/8th I can't for the life of me run any better then a 9.1 -9.2 now the drag radials are 17's which suck but my power is also at 260 at 10psi on the m62
i had a worse 60 ft then that on radials
![](http://i119.photobucket.com/albums/o160/cavaghini/WingedWarrior-1.jpg)
13.1 @ 115
