wow..... sounds like its running about as well as our drag car has the last few times out. I just got home from work (last week on 2nd shift, WOOT), so I wont be much help right now...... I'll try to remember to post back in the morning. I do my best thinking while I'm sleeping
SPD RCR Z -
'02 Z24 420whp
SLO GOAT -
'04 GTO 305whp
W41 BOI -
'78 Buick Opel Isuzu W41 Swap
-The fuel is tuned with a rising-rate BEGi FMU
-There is no "electronic" tune (no reflash, no HPTuners, no MegaSquirt, but I do have an MS box sitting in my garage that I'll be installing soon...)
-Stock MAP sensor
There is your problem.
you are running 17psi of boost without any real tune? Get rid of the FMU and start the megasquirt install. Even without the Megasquirt controlling the spark.... just fuel, your going to see a massive improvement.
In addition your RC 320cc injectors are NEVER going to keep up with 17psi of boost. We are talking 550cc here. Your 320s would have to run at like 200% duty cycle (im exagerating they wont even function) to keep up!
To sumerise:
a) propper tunning, take out the FMU and thow it in the ditch if your running more than 5 psi of boost.
b) you need way bigger fuel injectors.... like waaaaaaaaay bigger (and for oversize injectors you needd accurate fuel control...... see "a")
"Go Before Show Yo."
CARCUSTOMS.NET, THE BEST SERVICE ON THE ORG!!!
Gameoverracing. wrote:Quote:
-Stock MAP sensor
To sumerise:
I concur.
Also, check into the MSD if installing megasquirt doesn't solve the problem. Backfires and loud pops are usually the ignition system retarding timing too much. Thats how I get the skwirl to shoot large flames out the exhaust. If the MSD has a reference for boost, it may be pulling WAY too much timing in relation to MAP sensor input.
in fact, you may want to start there first.
defiantly ditch the fmu and get some real type of tunning software aboard, you spent all that money on the motor shouldnt of bandaided it with a fmu and try and run 17psi, i would say with your setup you might be able to run 5-7psi safely, those 320s will never be enough to support 17psi, brian maxed out his 650s on 15psi...... so if i was you i would turn the boost down to 5-7psi for now to make the car driveable, buy new bigger injectors 750cc, and start installing your mega squirt
R.I.P. Brian Klocke, you will never be forgotten
DaFlyinSkwirl (PJ) - BPU++ wrote:Gameoverracing. wrote:Quote:
-Stock MAP sensor
To sumerise:
I concur.
No offense but 320cc's even with an fmu are laughable at least. I was running 650's and seeing 60% injector duty cycle at 18 psi... those injectors are like... heeelllpppp meeee....
lol yeah get your fuel straightened out and check the msd out
LE61T PTE6262 Powered
if you want to check the MSD first, thats fine. Its a little easier to check that out since all it is is some settings
but bear in mind, FMUs are difficult to tune since they're purely mechanical and don't compensate for slight changes in situation (weather, altitude, etc) nobody's saying this is making you run too lean.. it could be making you run way too rich.
also, anything over 100% duty cycle means you have an injector firing into a closed intake valve, which means once the exhaust stroke happens all that extra fuel is going to pre-load the cylinder and unburnt fuel will make its way out the exhaust and onto your O2 sensor (giving you rich codes) as well as fouling plugs and just making the car run like crap.
upgraded injectors would not hurt at all and wouldn't cost that much (ebay 650s or bigger go for what? $250 a set or so?)duty cycle HAS to stay below 80% so the injector can accurately control its pulsewidth and get the proper AFR you're looking for. anything more than 80% the injector is going to be rushing to get the fuel in that it gets backed up and is forced to "rush"
ever see the "I love Lucy" episode where she's on the assembly line making pies and it keeps going faster and faster? same principal with your injector. If there were more people on the line (bigger injector) the extra work load can be compensated for. your basically getting fuel everywhere because the injector is just blindly firing as fast as it can.
and FMUs just aren't flexible enough for a higher boost EFI car. a computer controlled injection system is a much, much better option
even tho you see the same afr no matter what psi doesnt mean your injectors are working in the proper way, im saying your injectors are probably only good for 5-7psi before you duty cycle is too high
i agree with running the 550s... a buddy of mine has an Integra LS b18b1 on RC330 injectors... and his boost controler went bad, so instead of maxing out at 10 lbs, it kept going... at about 15 lbs (around 5000 RPMs ) his car started to bog, and you can hear the blow off valve starting to blow off before he let off the pedal...so we ran it straight to the waste gate which defaults at 8 and the problem has gone away... hes waiting on getting his HonData installed to put in the 550 injectors....
i would agree too that you would want to be tuned before running the 550s
its not your msd,spark plugs,injectors,fmu or your tune. your leaning out or i should say running out of gas let me guess when u get on a dyno u have no problems getting good a.f ratios and pulls strong when u drive the car normal its fine but when u go to the track (with very little gas in the tank to save weight )it takes off good in first but than u run out of power at the end of each gear and it starts bogging and back firing. all these problems sound like some one has a blazer pump in there tank. when u take off all the gas goes to the back of the tank and the pump sucks the cup dry and u run out of power than the car slows down the gas runs back to the front than the pump gets its gas again it makes power again the car takes off and the gas runs to the back of the tank and on and on we go that why your getting the crazy a f readings. the easy way to make sure this is the problem is fill your tank as full as u can get it before u go to the track if its the problem ether swap in a new stock pump or put a low pressure pump under the car that sucks the gas from the bottom back corner of the tank and puts the gas back into the cup around the in-tank pump so its always primed. u will need a 2000 up pump cup that has not been cut up for this to work i did this to my car and it works perfect .
hot damn even i pull a 15.2 all day--14.976 best
injector clipping?
when you say it
it tosses me forward in my seat it bogs so hard....
does it feel like the car suddling stopped making power like a wall stopped it? or kinda slowly started to loose power and fell on its face then bogged.
from what you describbied, it sounds like it was running lean and starving from fuel.. 13s a/f isnt really safe at 17psi.. or any boost....
if u were running to rich it would bog down and kinda die out power wise but still semi pull.
sounds like injectors clipping possibly.
with that kind of boost, an fmu alone cannot supply a safe amount of fuel accross the rpms. it just increases fuel pressure.
11s a/f is perfect.. and the fact it still did it with meth injection (assuming 100% that the meth injection worked that pass) then it pretty much narrows it down to your fuel system.
12.5@116 2.0 60ft
what was the mph
i just looked at your mod list. u have a nice setup, why on earth would u even chance running at that kind of boost level with only a fmu!?
a built motor will last longer in dangerous conditions like that, but its not unbreakable.. id highly recomond not boosting until u get a real fuel sytem in there.... your gonna kick yourself in the ass hard if you toast a fully built motor because you didnt wanna wait to do it right or spend a few extra hundred bucks.
12.5@116 2.0 60ft
Tuning stages? You took it to the track on a half assed fueling setup.
For 350hp you don't need 1000cc injectors... 750cc will be fine up to 380ish horsies. You should also be actually happy that you were running rich, when I read up there that you were doing 13:1 a/f in some parts, that worried me. Personally I'd advise tuning your car to around 11.7-12.3 : 1 a/f's to be safe and still make plenty of power.
As everybody is saying get rid of the tiny 320cc injectors, that are probably burning themselves out from you making them run so hard and clip.
While you're at it, start saving money for a good clutch, you'll need it if you plan on pushing the power that your setup is capable............................... with the right tuning of course.
-Trailblazer SS - not so custom 6.0L - custom intake - custom tune
- (1) 2.4L on an engine stand (1) blown trans (2) good quad trans (1) eco trans = party
try SPEC Stage 3+................ there's not much to explain, you went to the track and ran what you ran by not going out with a proper setup.
Tell me everything you know about your fuel pump, your fuel pressure, and injector size... FUEL FUEL FUEL... just a thought, it was my issue again tonight, and I have a 255 intake and a 255 inline about 3" from my fuel rail.. DAMNIT
HELFENBEIN wrote:Have you owned/driven a SPEC Stage 3? If so, in comparison to the "+", is there a commanding difference, or is it negligible?
I've had the stock GM clutch, a SPEC stage 3, and a Clutch Masters twin disc.
The SPEC stage 3 and 3+.. the differences, one is technically able to hold more power than the other.
stage 3 I think is 400ft lbs
and stage 3+ is like 450ft lbs
I killed a 3 with three dyno pulls of 432hp 424tq, two pulls on the highway, and it died on the first run on the drag strip.
sorry to hear about your problem. I really hope you can get it sorted out. And when you do, make sure to post up some kick ass numbers!!!
Later
2004 Cavalier
13.2@105........
Mods...
BFG Drag Radials
Saab Turbo kit
2.5 exhaust, w/cutout
Spec Stage 2+ Clutch
