I am aiming for a 16.2-16.1 out of my auto cav. after adding new plugs o2 sensor 56MM Tb, and cat back. In addition I have a intake and lower motor mount. I plan on having the spare tire and jack out and am thinkin about running on steelies. best pass before was a 16.83 with spare in on steelies with intake muffler lower mount and TB spacer.
![](http://img.userbarz.com/49/9606.jpg)
plugs, wires, pulleys, flywheel and some weight reduction should get you there
I have yet to find 2200 pulleys! and my car is a auto so it's just a flexplate.
My 1st ever run with my 01 auto Cav was 16.2 and there's not a single part that's not stock....
Yea that was a Z24 is, I am running a 2.2OHV not a 2.4, I wish I was though.
Well I'm goin for it this friday we'll see how it does, New megan cat back, running steelies, no sub box or amp, no spare or jack or anything hopin that I can pull this off if I get down below 16.5 range I was faster than my 89 beretta gt with a 2.8 auto. so wish me luck!
I ran 16.2 in my LS convertible....so I am heavier but I have a bigger motor. Good luck. I don't see why you wouldn't be close or hit your times. I am going tomorrow to the track. Have fun!
Sam
Ban low-performance cars, not high-performance ones.
nos is your friend... 40 shot and b4 you know it you'll be hitting 15s
2.2 pulleys will be avalible soon.
well now that my exhaust will finally be here monday or tuesday, I can actually get it on and run the car and see how much better it is. Also no nitrous not gonna happen,
i ran a 16.7 with just intake and exhaust, and a 16.3 after my bf tuned with hp tuners. both with 2.2 - 60 foots. the run of the 16.3 was a bad run but the track was so packed i couldnt get another chance to go (it was also barely 40 degrees) lol. The 2200 is severly limited on stock tune. We advanced the timing 16 degrees before hitting knock retard in mine. and also the 2200 doesnt hit WOT until 5k RPMs, its much better to have it as soon as you punch it. makes a big difference.
