Not a very good run but it's the best slip i got.
reaction-.6420
60 ft-2.26
330-.9889
et 594ft-9.29
1/8 et-9.9287
mph-70.90
Thanks for the help!
Should be like a low 15ish second pass .. 15.2 or 15.3 ?
I'd say more likely a 15.5 or somewhere in that ball park.
Smoked the tires on launch did you ? Next time try running about 20 psi so you hook up better. A 5spd ECO should do a little better then this. Don't sweat it man it takes practice, you'll get there.
Good Luck.
I think he just needs to calm down at the staring line. Semi-good reaction time, but bad 60 ft. this tells me he launched at a good RPM, just dropped the clutch and/or got on the throttle too quickly.
What tires are you using, tiresmoka? and waht size are they? Some tires will start cupping if you let too much air out of them.
I'll show you what I mean...
RIMRIMRIM
I TIRE I
I I I I I
I I I I
A little exadurated, but you get the idea
For the mods listed in the registry I think these times are awesome, nice MPH as well.
RT dont mean jack. unless its bracket. and as far as we know it could be a .500 tree
id say around a 15.3 pass
15.5-15.6
I had a run that was 9.86@ 72 mph and I got a 15.27 1/4 time. With the slower trap I say 15.5 and 1/10 slower time. It usually takes 9.8's or lower to get lower than a 15.2 in the 1/4.
RE Audio
15.5-15.6 range.............my PB is 9.76@71.....but my car has no top end.........still only did 15.32
Hey thanks for the input, that run was on the stock rsa's at I think 28psi. Recently I got some cheap z-rated rubber and man it made a huge difference,hell I can almost stand on the brake without the abs kicking in, and I pulled a 2.18 60'' but it was a @!#$ run. But thanks for the help maybe i'll be alittle quicker with some new mods go income taxes!!!
Probably like something close to 15.2 - 15.5, like most others have already stated.
generally its 1/8 time * 1.56 = 1/4 time so around a 15.5
1998 Cavalier
1995 Trans Am
1984 Camaro Z28
Your ET computed from your vehicle ET of 9.9287 seconds is 15.49 seconds in Quarter Mile.
and wow that's strange to see your 1/8 ET go so far out. 9.928715300214562677431 @ 70 mph
