first time to the track! is it good??? - Racing Forum
Sunday, May 08, 2005 6:01 PM
well, this was my first time to the track.
I have header, full 2.25 exhaust with high flow cat, clutch kit stage 2, both motor mount, ebay crank pulley, intake with k&n. and its a 2.4L
also i took the spare and jack off.
here is my best time of the night, i think it is high for the mods i have, but not sure!!!!
R/T ... .142
60' ... 2.311
1/8 ... 9.983
1/4 ... 15.531
MPH ... 90.179
thanx!
Re: first time to the track! is it good???
Sunday, May 08, 2005 6:22 PM
also, i have a check engine for camshaft sensor, dont know if that would affect my times.
i also have brand new yokohama avs es100.
Sunday, May 08, 2005 8:06 PM
60' time is pretty slow get it in the 2.2 range and times will get better
i run 15.3 and have way less mods than you lol
but not bad for the first time out either
Tuesday, May 10, 2005 11:34 AM
wut are u launching at, wuts ur tire pressure, wuts ur shift points
Tuesday, May 10, 2005 12:44 PM
i lauched at about 3,5k
tire pressure is 32 i think!
and i shift at 6200rpm
maybe i should shift at 6500???
Tuesday, May 10, 2005 2:09 PM
put the tire pressure at 25
try a run shifting at 6500
then try a run shifting at 6000
Tuesday, May 10, 2005 2:13 PM
i launch right around 3500 too, i shift around 5600 to 5800 from 1st to 2nd.
then 2nd to 3rd at 6000 and so forth. i lose power when i shift past 6000.
i tried a run shifting at 6500 and ran slower then i did when i shifted at 6000
Tuesday, May 10, 2005 2:16 PM
ok thanx, i'll try that next time i go to the track!
Wednesday, May 11, 2005 6:08 AM
no problem
