Help me how can I improve my 1/4 ET, I know this times are worst
My Specs:
1996 2.4L Cavalier
Pacesetter 4-1 Headers
2.25" Exhaust Pipe
Borla Pro XS Muffler
Cat & Resonator Removed
K&N 5" Cone Filter (With stock air filter box removed)
Stock S-Tube
Intake Air Resonator Removed
RK Sport Upper & Lower Motor Mounts
RK Sport Boot Inserts
Intrax Lowering Springs
225-50-16 Kumho Tires (25psi front)/(34 psi rear)
Guatemala Raceway Park (650ft OSL)
RT 0.642
60-feet 2.512
660-feet 10.546
1/4 ET 16.337
1/4MPH 84
* I need to replace front and rear struts
Added With
Stage I Bronze Clutch
185-60-14 Yokohama Tires (25psi) in FWD only
RT 0.758
60-feet 2.543
660-feet 10.396
1/4 ET 16.101
1/4MPH 86
is it a suto or 5-speed? how is you traction and stuff off the line?
You suck at driving. Nuff said. 2.5 60' is horrible. I dunno...maybe your clutch is junk (if you have manual which I assume you do). You might alos want to get a FULL intake instead of the stock crap with a filter on the end......especially to go with that nice free-flowing header back exhaust you have.
Seriously practice your launch....you'd be around 15.8 with a 2.2 60'.
edit:
I see your other time with a "bronze stage I clutch"? What kind of clutch is this. Also...you had a worse 60' in that run but a faster 1/4 time.
You just need to get better at driving. Faster shifting and a good launch is the key!
looks like his altitude was "Guatemala Raceway Park (650ft OSL)" or atleast thats how i took this as 650ft above sea level
<img src="http://www.j-body.org/registry/scoobyz24/personal_pic.jpg">
-Bryan Dube
Team Drop Zone
Vice President
practice, practice, and practice.
Your r/t's aren't too hot, If you get out of the hold faster, I think you'll be way better. Before you launch, rev up to about 2.5 or 3 grand and then dump the clutch. Worked for me (running a Daikin clutch).
02 Subaru Impreza WRX Wagon
R/T'S HAVE NOTHING TO DO WITH YOUR E/T'S!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
OMGWTFBBQ!!!111!!ONE!!!!!!!!!!1
For answer to all
Sean Minnis:
5-speed Manual
Lash:
This is a Performance Clutch with better grip than the stock clutch
theL61:
Yes the altitude is 650 feet over the sea level, hot weather
The car is slipping the wheels to much at launch. I'll gonna practice my launch to avoid slip wheels so much, and try'll to shift faster..
If your struts are bad (you mention they need replacing) then that will hurt you off the line. The weight transfer will cause bounce which kills traction.
Wild Weasel wrote:If your struts are bad (you mention they need replacing) then that will hurt you off the line. The weight transfer will cause bounce which kills traction.
thats probably your problem
i pull faster 60' times in my 2.2 OHV, and my best run is only 16.8....mostly low 17's
